spookt Posted July 14, 2015 Share Posted July 14, 2015 Hi Folks I feel like a noob all over again! Trying to get my system back up and sorted after a year away. I have an Incognito 800 with SDX 4.47 (PBI BIOS 1.0) here and I'm trying to use the command line version of the SIDE loader. I can run the XEX and I see the SIDE menu and a directory of the CF card, but if I hit space to mount an ATR or try to boot one by hitting return I get one of two messages: No PBI driver found, aborting ... (when pressing space) D1: Not mounted, aborting boot ... (when pressing return) I'm 99% sure I used to be able to do this no problem, but it seems my Atari foo is weak Help! Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 14, 2015 Share Posted July 14, 2015 Have you tried using the XEX loader in ROM (invoked by pressing "L" in the setup menu)? Quote Link to comment Share on other sites More sharing options...
spookt Posted July 14, 2015 Author Share Posted July 14, 2015 (edited) Yes, that works fine, I did like being able to get there from DOS though. Edited July 14, 2015 by spookt Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 14, 2015 Share Posted July 14, 2015 And you're in XL/XE mode of course. Presumably some API incompatibility between the disk version of the loader and the PBI BIOS??? Quote Link to comment Share on other sites More sharing options...
spookt Posted July 14, 2015 Author Share Posted July 14, 2015 Yes, guess so. I'm using the latest version of the Incognito loader I could find. It's not a big deal since as you rightly point out I can get there with Inverse+Reset and L which is probably just as quickly. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 14, 2015 Share Posted July 14, 2015 Yes, guess so. I'm using the latest version of the Incognito loader I could find. Can you send it over? I'd like to give it a go here. Quote Link to comment Share on other sites More sharing options...
spookt Posted July 14, 2015 Author Share Posted July 14, 2015 Sure. Here's the version I'm using: fat32-incognito.xex Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted July 14, 2015 Share Posted July 14, 2015 Thanks - I'll check it out tomorrow. 1 Quote Link to comment Share on other sites More sharing options...
