Emergency denial services / Cardinal arrested
This experimental apparatus monitors various types of events in your body and brain.
Get latest version of Classic99. Choose TurboForth 1.2.1 by Mark Wills.
Type, or copy and paste program listing. Enjoy. ;)
VARIABLE COL
CREATE COLS 30 CHARS ALLOT
: >COLS ( value offset -- ) COLS + C! ;
: <COLS ( offset -- n ) COLS + C@ ;
: CHART
  1 GMODE 14 SCREEN 4 4 0 COLOR 5 1 0 COLOR
  DATA 8 $0000 $0400 $0000 $0000 $0000 $0400 $0000 $1F1F 32 DCHAR
  DATA 8 $0000 $0400 $1F1F $0000 $0000 $1F1F $0000 $0000 34 DCHAR
  DATA 4 $1F1F $0400 $0000 $0000 36 DCHAR
  DATA 8 $040E $1F04 $0404 $0C04 $0404 $1C04 $0404 $0C04 40 DCHAR
  DATA 8 $0404 $1F04 $0400 $0000 $0000 $FF44 $0400 $0000 42 DCHAR
  DATA 4 $0406 $FF46 $0400 $0000 44 DCHAR
  40 0 V! 1 0 41 22 VCHAR 42 736 V! 23 1 43 30 HCHAR 44 767 V!
  30 0 DO
    30 I >COLS
  LOOP
  BEGIN
    30 RND COL !
    1 COL @ 1+ 32 22 VCHAR
    19 COL @ <COLS 2 >> -
    COL @ 1+
    COL @ <COLS 3 AND 33 +
    HCHAR
    2 RND 0 = IF -1 ELSE 1 THEN COL @ <COLS + 63 AND COL @ >COLS
  AGAIN
CHART
TF has a word called 0= which you can use to replace the 0 =
2 RND 0= IF -1 ELSE 1 THEN
Does exactly the same thing, but 0= is (probably) more than twice as fast as your code, which pushes 0 to the stack, then pops it off again with =
0= just does a direct comparison to tos (top of stack).
Here's a description. :grin:
Conventions:
In Forth speak, <cols would be more correctly written as cols>
If the > is before the word (example: >R ) then it's "to". So, >R is "to return stack"
If the > is after the word (example R> ) then it's "from". So, R> is "from return stack"
However, in the case of >cols and <cols in your above, I would name >cols as !cols and <cols as @cols respectively, because they are fetching and storing. If another Forther were reading your code, !cols and @cols would give him an immediate clue as to what is happening.
Just friendly advice - nothing wrong with your code! :thumbsup:
Thanks everyone. :)
Updated version:
VARIABLE COL
CREATE COLS 31 CHARS ALLOT
: !COLS ( value offset -- ) COLS + C! ;
: @COLS ( offset -- n ) COLS + C@ ;
: CHART
  31 0 DO
    31 I !COLS
  LOOP
  BEGIN
    31 RND COL !
    19 COL @ @COLS 2 >> -
    COL @ 1+
    COL @ @COLS 3 AND 33 +
    HCHAR
    2 RND 0= IF -1 ELSE 1 THEN COL @ @COLS + 63 AND COL @ !COLS
  AGAIN
CHART
