CoolCV emulator for Mac OS X, Linux, Windows and Raspberry
nanochess
  • 2 weeks later...
6 minutes ago, J.R. Voigtschild said:
OK so i got the CoolCV downloaded. I am trying to put it on my Rasberry PI 3 B+. where in the world do i put the files, and what files go where. I am so lost on this one :P
Hi, there is a section in the manual (coolcv.txt) that explains what to do with Raspberry, it depends on your operating system. (easier with Retropie, harder with Raspbian)
  • 5 months later...
  • 1 month later...
For whatever reason, CoolCv does not create a mapping file coolcv_mapping.txt when I first use CoolCV. Is there a mapping text file for PC I can copy or download for my ColecoVision controller so I am not muddling around from scratch? Also do you just put it in the same folder space as coolcv.exe? Surprising that all I can find is about people using it in retropie.
Edit: gahhh, never mind! I just read a post that said it goes to mydocuments and found it there.
Hi nanochess, I'm not sure if you've been following the CollectorVision Club 2020 thread, but as part of the club the ROM file for "The CAT Scheduled Oil Sampling Game" was provided.  I've been doing some testing of the ROM and found a really bizarre issue with CV software emulators and this game.  Basically, the game does not work in any ColecoVision emulator that I've tried.  I've tried CoolCV (v6.6), ColEm and blueMSX and H.E.R.O. also found that vdmgr64 behaves the same.  When the game starts press any keypad key to get to the game menu and then press * to start a game.  All of that works fine, but when the game screen with the CAT starts it seems to just freeze with white noise.  No joystick or keypad entries do anything.
The main reason I'm posting this here is that Swami discovered that CAT works in CoolCV v6.2 to v6.5 but NOT in v6.6.  So, could you shed any light on what the issue may be?
Hey all,
Trying to get CoolCV running on a RetrOrange PI setup.  I copied the coolcv_pi executable into place, but when I run it from the command line I get this error:
/opt/retropie/emulators/coolcv/coolcv_pi: error while loading shared libraries: libbcm_host.so: cannot open shared object file: No such file or directory
I've installed what I thought was the correct version of this file in /usr/lib, /usr/local/lib, and even in the same directory as coolcv itself, but it still complains about this lib being missing.  Any suggestions?
On 2/8/2020 at 7:11 PM, SJD69 said:
Any plans to support pi shaders?
As I'm doing a multiplatform release, I find hard to do specific platform optimization.
23 hours ago, Rick Reynolds said:
Hey all,
No idea. Never tested with that distribution.
1 hour ago, zzip said:
Any plans to allow specifying the path to the config file on the command line?
Maybe later.
  • 2 months later...
This one is for nanochess, any chance of this happening? This is from the retropie forum for the newly released beta for the RPI4.
I've got jzintv running on the Pi4 - it will probably be added to the development branch soon(ish).
For coolcv, it's a different story, since it's not an open source emulator and the binary distributed is using the (legacy) Broadcom GL libraries. Porting it to the new Mesa GL driver might need some changes to the emulator, which only its author can do.
Not for RetroPie, but for Pi...
FWIW, not out yet, but we do have Coleco support in early stages in Project Argon, and have it working on RPI3+ and RPI4. We will post here (and on our social media) when we are ready for an open beta later this year. Some behind the scenes pics here...
https://www.instagram.com/markspaceinc/
  • 2 weeks later...
23 hours ago, VectorGamer said:
Has anyone gotten this to work on Raspberry Pi with an Xbox controller? Just looking for a ready made coolcv_mapping.txt file but I can't find one uploaded anywhere. Are there instructions anywhere on how to edit this file?
Never mind. Found it after a lot of digging.
  • 1 month later...
At last found time to update CoolCV to version 0.6.7, few changes but useful. Distro in first post. Pi cannot be updated this time because I cannot locate my Pi!!! ;)
Now support for random number generation on games like Word Feud (using RAND_GEN from Coleco BIOS).
Paused windows doesn't show trash if minimized/maximized or something passes over.
Pause shows a message.
Added Mecha-9 to the game collection included.
Edit: Now including libsdl in the Mac OS X application bundle, so you don't have to install it.
Edited by nanochess
  • Thanks 3
Great! Thanks!
The issue still remains with the bundled SDL framework (see posts #338 - #340 in this thread) not loading in macOS (for me, macOS 10.14.6), so users on that platform still have to install the framework independently to use CoolCV.
Looks like the version string in Info.plist also needs to be bumped to 0.6.7, unless it's 0.6.6 in the "almost all" zip archive for macOS?
Crashlog attached.
crash.txt
Edited by mumbai
grammar
1 hour ago, mumbai said:
Great! Thanks!
Crashlog attached.
Wow! Thanks for re-finding it! Forgot completely about it.
Now apparently got right the libsdl embedding. Also bumped version to v0.6.7.
21 minutes ago, ColecoJoe said:
If you're running Mac OS Catalina and are getting the "can’t be opened because the identity of the developer cannot be confirmed" error, run this in terminal.
sudo xattr -d com.apple.quarantine Path-To/CoolCV.app
Added your tip to the manual. Thanks!
