Mad Pascal
http://mads.atari8.info
https://github.com/tebe6502/Mad-Pascal/releases
https://mads.atari8.info/library/doc/index.html
http://bocianu.atari.pl/blog/blibs
https://github.com/Ripjetski6502/A8MadPascalLibrary
Mad Pascal 1.6.8
Based on Sub-Pascal 32-bit real mode compiler for 80386+ processors v. 2.0 by Vasiliy Tereshkov, 2009
Mad-Pascal is a subset of Pascal programming language. It includes:
1. If, Case, For, While, Repeat statements.
2. Compound statements.
3. Label, Goto statements.
4. Records, Objects.
5. Arithmetic and boolean operators.
6. Procedures and functions with up to 8 parameters. Returned value of a function is assigned to a predefined Result variable.
7. Static local variables.
8. Primitive data types (All types except the ShortReal/Real type are compatible. Pointers are dereferenced as pointers to Word):
 + Cardinal Word, Byte
 + Integer, SmallInt, ShortInt
 + Char, PChar
 + Boolean
 + Pointer
 + File, Text
 + ShortReal/Real (fixed-point), Single (IEEE-754), Float16 (Half Single)
9. One-dimensional and Two-dimensional arrays (with zero lower bound) of any primitive type. Arrays are treated as pointers to their origins (like in C) and can be passed to subroutines as parameters.
10. Predefined type string [N] which is equivalent to array [0..N] of Char.
11. Separate program modules.
12. Recursion.
PasIntro.zip
Edited by tebe
update
  • Like 9
That's MEGA fascinating!!! Tebe, you are absolutely amazing, making even Turbo Pascal-like cross compiler available to Atari developers. I tried it and it works great. I like the way you mirrored the structure of Turbo Pascal units: crt, graph, math, system. It moves me to those nostalgic days of programming in TP in DOS :). Firstly I thought you used Free Pascal as the base compiler core but I read your information about Sub-Pascal. Just great! And congratulations for winning the Głuchołazy 2015 intro contest!!!
Gury
use graph.pas and crt.pas
begin
 InitGraph(;
 SetColor(1);
 Circle(250,60,90);
 SetBkColor($86);
 MoveTo(10,10);
 LineTo(300,15);
 Circle(110,160,150);
 LineTo(22,190);
 SetBkColor($c6);
 Line(5,85, 311,190);
 repeat until keypressed;
end.
Hi, I prepared some simple examples demonstrating P/M graphics with Mad-Pascal. Code is simplified for clarity and readibility. I think there is still a bug in my code because of little garbage on-screen. Anyway, here it is.
First example with simple static player 0 on-screen and second example, which shows how to move player 0 with joystick. Source code is included in this post. Just invoke command prompt window and type pm or pm2 (and press enter key :))
post-7301-0-47233500-1438015561_thumb.png post-7301-0-02551600-1438015578_thumb.png
// P/M Graphics demonstration
// by Bostjan Gorisek 2015
// Developed in Mad-Pascal by Tebe / Madteam
const
  max = 10;  // Number of player 0 data values
var
	p0Data : array [0..max] of byte;
  px0 : byte;  // Sprite X position
  py0 : byte;  // Sprite Y position
  pmgMem : Word;
  i : Byte;
begin
  // Set graphics mode and playfield colors
  InitGraph(0);
  Poke(710, 0); Poke(712, 0);
  Poke(752, 1);  // Cursor off
  writeln(eol,'P/M Graphics demonstration');
  writeln(eol,'by Bostjan Gorisek 2015',eol);
  // Initialize P/M graphics
  Poke(53277, 0);
  pmgMem := Peek(106) - 4;
  Poke(54279, pmgMem);
  pmgMem := pmgMem * 256;
  Poke(559, 46);
  // Set player 0 coordinates
  px0 := 120; py0 := 60;
  // Draw player 0 image
  p0Data[0] := 60;
  p0Data[1] := 66;
  p0Data[2] := 129;
  p0Data[3] := 165;
  p0Data[4] := 129;
  p0Data[5] := 153;
  p0Data[6] := 129;
  p0Data[7] := 165;
  p0Data[8] := 153;
  p0Data[9] := 66;
  p0Data[10] := 60;
  // Clear player 0 memory
  fillchar(pointer(pmgMem+512), 128, 0);
  // Draw player 0
  // Vertical position of player 0
  //Move(pointer(p0Data), pointer(pmgMem+512+py0), 10);
  for i := 0 to max do begin
    Poke(pmgMem+512+py0+i, p0Data[i]);
  end;
  Poke(53277,3);  // Turn on P/M graphics
  Poke(53256,1);  // Size of player 0 (double size)
  Poke(704,183);  // Player 0 color
  Poke(53248,px0);  // Horizontal position of player 0
  // Reset P/M graphics
  InitGraph(0);
  Poke(53277, 0);
end.
// P/M Graphics demonstration 2
const
  _max = 7;     // Number of player 0 data values
  _speed = 40;  // Player 0 movement speed
var
	p0Data : array [0.._max] of byte;
  pmgMem : Word;
  i : Byte;
begin
  InitGraph(;
  Poke(710, 122); Poke(712, 130);
  Poke(709, 64);
  // Set playfield graphics
  SetColor(1);
  MoveTo(10,10); LineTo(300,10);
  Line(30,50,100,50); Line(100,50,100,130);
  Line(30,130,100,130); Line(30,130,30,50);
  Circle(250,60,20);
  Poke(53277, 0);
  Poke(559, 46);
  p0Data[0] := 48;
  p0Data[1] := 120;
  p0Data[2] := 252;
  p0Data[3] := 48;
  p0Data[4] := 48;
  p0Data[5] := 48;
  p0Data[6] := 48;
  p0Data[7] := 48;
  // Draw player 0
  //Move(pointer(p0Data), pointer(pmgMem+512+py0), _max);
  for i := 0 to _max do begin
  end;
  Poke(53256,0);  // Size of player 0 (normal size)
  Poke(704,44);  // Player 0 color
  repeat
    // Move player 0 left
    if Peek(632)=11 then begin
      Dec(px0);
      if px0 < 45 then px0 := 45;
      Poke(53248,px0);
      Delay(_speed);
    // Move player 0 right
    end else if Peek(632)=7 then begin
      Inc(px0);
      if px0 > 203 then px0 := 203;
      Poke(53248,px0);
      Delay(_speed);
    // Move player 0 up
    end else if Peek(632)=14 then begin
      Dec(py0);
      if py0 < 16 then py0 := 16;
      Poke(pmgMem+512+py0-1, 0);
      Poke(pmgMem+512+py0+_max+1, 0);
      end;
      Delay(_speed-;
    // Move player 0 down
    end else if Peek(632)=13 then begin
      Inc(py0);
      if py0 > 97 then py0 := 97;
      end;
      Delay(_speed-;
    end;
  until keypressed;
  InitGraph(0);
  Poke(53277, 0);
end.
pmgdemos.zip
hello, what happens next if I have the "pmgdemo.obx".
as it is a xex?
.OBX is to .OBJ as .XEX is to .EXE. Although the Atari doesn't care what extension you use, usually .OBJ (and presumably then .OBX), is usually object code that is not yet in a final executable application form. For example for languages which first compile object code, then link the object code to a run time or library (which is itself plain object code) that is needed to make a full working program, it would be best practice to choose an .OBJ extension. Once you have various object code components linked together in a complete executable though, you would use .EXE. The .COM extension is typically for .EXE files that are external commands for a CLI driven DOS.
I think the main (only?) reason some people are using .OBX or .XEX on Atari now days, is to make it easier to distinguish such files from DOS/WIN files with the extensions of .EXE or.COM.
It can get confusing! Especially when the extensions are used somewhat willy nilly without care as to differences of meaning. The computer itself cares little what you use though. The differences are for people's benefit of understanding.
Edited by fujidude
loops
if INDEX is BYTE
 for i:=0 to 255 do      // infinite loop
 for i:=15 downto 0 do   // infinite loop
 while i<=255 do inc(i); // infinite loop
REPEAT UNTIL, is safe
 i:=0;
 repeat
 inc(i);
 until i=0;  // 256x
Edited by tebe
how can you please fill an array of pointers?
there is an error message.
thank you
var
dlist: array [0..110] of byte;
dl_idx : word;
begin
dl_idx= @dlist;
Poke(dl_idx+0,255);
Poke(dl_idx+1,23);
DPoke(dl_idx+2,476);
Poke(dl_idx+4,76);
repeat
until keypressed;
end.
Edited by funkheld
i have an own dplist designed with the image address: 36960
this is dplist stored here: dlist: array [0..110] of byte;
here the dplist describes: procedure initdlist (a: word);
dl_idx is taken for poke / peek.
then follows the poken in the screen and the graphics commands are through this
command set to the new dplist: dpoke ($58,36960);
this order is important:
init graph (7);
dpoke (560,word(dlist));
dpoke ($58,36960);
greeting
var
dl_idx: word;
procedure DLByte(a: byte);
begin
Poke(dl_idx, a);
inc(dl_idx);
end;
procedure DLWord(a: word);
begin
DPoke(dl_idx, a);
inc(dl_idx, 2);
end;
procedure InitDlist(a: word);
begin
DLByte($70); DLByte($70); DLByte($70); DLByte($4d);
DLWord(36960);
DLByte($0d);DLByte($0d);DLByte($0d);DLByte($0d);DLByte($0d);DLByte($0d);DLByte($0d);DLByte($0d);DLByte($0d);DLByte($0d);
DLByte($41); DLWord(a);
end;
begin
dl_idx:= word(@dlist);
InitDlist(word(@dlist));
InitGraph(7);
DPoke(560,word(@dlist));
DPoke($58,36960);
SetColor(1);
MoveTo(5,5);
LineTo(159,95);
SetColor(2);
MoveTo(159,0);
LineTo(0,95);
SetColor(3);
Circle(80,50,45);
Poke(36960,129);
Poke(36961,255);
Poke(36962,129);
repeat
until keypressed;
end.
I really liked the idea, I hope that in the future contains everything you need to develop a game or application quickly as serious a framework.
Here I made a small test example.
// Show colors
// AsCrNet
var
	num : byte;
begin
	ClrScr;
	TextColor(15);
	GotoXY(14,9);
	write('Show colors');
	repeat
		num := Random(255);
		TextBackground(num);
		Delay(900);
	until keypressed;
end.
greetings
Edited by ascrnet
fpc -Mtp filename.pas
// Show colors
// AsCrNet
uses crt;
var
num : byte;
begin
ClrScr;
TextColor(15);
repeat
            num := Random(255);
            GotoXY(14,9);
            Delay(900);
until keypressed;
end.
run application on PC and XE/XL :)
Edited by tebe
