Mad Pascal
  • 2 weeks later...
Mad Pascal Compiler version 1.6.1 [2019/08/07] for 6502
Compiling pacmad.pas
d:\!Delphi\PAS6502\lib\graph.inc (672) Warning: lo/hi(dword/qword) returns the upper/lower word/dword
d:\!Delphi\PAS6502\lib\graph.inc (673) Warning: lo/hi(dword/qword) returns the upper/lower word/dword
interrupts.inc (1) Note: Use assembler block instead pascal
interrupts.inc (13) Note: Use assembler block instead pascal
interrupts.inc (26) Note: Use assembler block instead pascal
interrupts.inc (43) Note: Use assembler block instead pascal
interrupts.inc (64) Note: Use assembler block instead pascal
interrupts.inc (76) Note: Use assembler block instead pascal
interrupts.inc (89) Note: Use assembler block instead pascal
interrupts.inc (111) Note: Use assembler block instead pascal
dlist.inc (2) Note: Local const 'DL_NULL' not used
1599 lines compiled, 5.80 sec, 22861 tokens, 1667 idents, 374 blocks, 10 types
2 warning(s) issued
9 note(s) issued
d:\!Delphi\PAS6502\test\games\PacMad>mads pacmad.a65 -x -i:..\..\..\base\
ZPFREE: $0000..$007F ; $00D8..$00FF
$R RCDATA  $C400..$C7FF 'assets/pacmad8solid.fnt'
$R RCDATA  $C800..$CBFF 'assets/NC5.FNT'
$R RCASM   $8000..$8437 'assets/pacmad.logo'
LEVELS SIZE: $10A7
LEVELS:  $8438..$94DF
$R RCASM   $8438..$94DE 'assets/levels.asm'
STRINGS SIZE: $0120
STRINGS : $B000..$B120
$R RCASM   $B000..$B11F 'assets/strings.asm'
$R RMTPLAY $B1E0..$B817 'assets/rmt.feat'
$R RMT     $B900..$BFB5 'assets/pacmad_strip_mono.rmt'
SYSTEM: $23E8..$2567
GRAPH: $2568..$2569
DATAMATRIX: $256A..$27DF
MYPMG: $27E0..$28A5
RMT: $28A6..$2982
CODE: $2000..$6F05
DATA: $6F06..$746C
Writing listing file...
Writing object file...
26963 lines of source assembled in 12 pass
32616 bytes written to the object file
  • 3 weeks later...
Hi there, I'm tryin to port source from ACTION! to MP.
var colcrs: byte absolute $55;
var savmsc: ^byte absolute $58; << FAIL: tsystem.pas (9,23) Error: not possible in this case
How can I declare a pointer to a byte array (here screen) that is located in a fixed location (here $58)?
- Peter.
54 minutes ago, bocianu said:
var vidmem: array [0..0] of byte absolute $a000;
this array is located at fixed location.
btw: savsmc is already declared in atari unit.
Thanks for the hint, you example is not what I need because I need the pointer at a fixed address. But the Atari Units solves it:
savmsc: word absolute $58;        // (2) adres pamieci obrazu
Hey.
Thanks to the developers of MAD Pascal!
I found out that there are problems in working with pointers.
For example:
program TestProgram;
var
  PA, PB: ^Word;
begin
  PA: = Pointer($1111);
  PB: = @PA; // Error: PB = PA {=$1111}, but should be PB = Addr(PA)
end.
Similarly, the problem is when calling a procedure with a var parameter pointer:
  procedure Tst(var P:Pointer);
  var
    TP: Pointer;
  begin
    TP:= Pointer(Word(P) + $123);
    //Error: TP <> ($1111+$0123) since in this case "Word (P)" is executed as "Word (P ^)"
    P:= TP;
  end;
var
  PA, PB: Pointer;
  PC: Pointer;
begin
  PA:= Pointer($1111);
  PC:= PA;
  Tst(PC);
  //Error: PC = PA {$1111}, but should be PC = $1234
  PB:= PC;
end.
If the type "pointer" is replaced by a "word", then the program runs correctly.
On 7/28/2015 at 10:17 PM, funkheld said:
Hello, good evening.
what is missing are file commands (GET, PUT ...)
greeting
Hi,
the are there, they are called BlockRead/BlockWrite. You can use them like BGET/BPUT in Turbobasic.
var file f;
begin
  Assign(result, 'D1:EXAMPLE.TXT');
  Reset(f,1);
  Blockread(f,target,length);
  if (IOResult>=127) then beep;
  Close(f);
there are more detailed example in the MP download.
On 7/28/2015 at 10:24 PM, funkheld said:
hello tebe.
what this: ???
fpc -Mtp filename.pas
greeting
That is how you compile the same on a PC using "FPC.EXE". On the Atari use mp.exe and then mads.exe on the result of mp.exe.
@tebe: Mad Pascal is REALLY cool. I love static type checking, boolean and enums. My ACTION! project is now converted and basically runs.
I have added support for Mad Pascal in WUDSN to the todo list ?
Can you please add the orignal File/line/code in the ".a65" file as comment?
Otherwise debugging is really hard.
Thanks, I knew they exist, but I didn't have the time to look at them yet. My focus is getting my game to work.
I just tried to implement a minimal MP syntax highlighting that can be integrated in my WUDSN IDE using the new Eclipse 4.7 generic editor.  And I am very statisfied with the (not yet 100% of course) result from just around 80 lines of Java code.
  var
    TP: Pointer;
  begin
    P:= TP;
  end;
var
  PA, PB: Pointer;
  PC: Pointer;
begin
  PC:= PA;
  Tst(PC);
  PB:= PC;
end.
fixed
https://github.com/tebe6502/Mad-Pascal
Rectangle Overlap, Which Side Was Hit
use joy in port 0
uses crt, joystick, fastgraph;
type
TColision = (left=1, right, top, bottom);
 TTile = record
     width, height, centerX, centerY: byte;
    end;
var
 A,B: TTile;
 Hero: record x,y, _x, _y: byte end;
 hit: byte;
function CollisionTile(var B: TTile): byte;
var w,h: byte;
    dx,dy,wy,hx: smallint;
begin
Result:=0;
w := (A.width + B.width) shr 1;
h := (A.height + B.height) shr 1;
dx := A.centerX - B.centerX;
dy := A.centerY - B.centerY;
if (abs(dx) <= w) and (abs(dy) <= h) then begin
    (* collision! *)
    wy := w * dy;
    hx := h * dx;
    if (wy > hx) then begin
        if (wy > -hx) then
            (* collision at the bottom *)
        Result := ord(bottom)
        else
            (* on the left *)
        Result := ord(left);
    end else
        if (wy > -hx) then
            (* on the right *)
        Result := ord(right)
        else
            (* at the top *)
        Result := ord(top);
end;
end;
procedure DrawTile(var a: TTile; color: Byte);
var px,py,x,y,w,h: byte;
begin
  w:=A.width;
  h:=A.height;
  x:=w shr 1;
  y:=h shr 1;
  px:=A.CenterX - x;
  py:=A.CenterY - y;
  SetColor(color);
  Rectangle(px,py,px+w,py+h);
end;
procedure HeroMovement;
begin
 case joy_1 of
   joy_left: dec(Hero.X);
  joy_right: inc(Hero.X);
     joy_up: dec(Hero.Y);
   joy_down: inc(Hero.Y);
 end;
 if (Hero.x <> Hero._x) or (Hero.y <> Hero._y) then begin
  DrawTile(A, 0);
  A.CenterX := Hero.X;
  A.CenterY := Hero.Y;
  DrawTile(A, 1);
  Hero._x := Hero.x;
  Hero._y := Hero.y;
  DrawTile(B, 3);
 end;
end;
begin
InitGraph(7);
A.width:=8;
A.height:=8;
A.CenterX:=84;
A.CenterY:=53;
Hero.X:=A.CenterX;
Hero.Y:=A.CenterY;
B.width:=32;
B.height:=16;
B.CenterX:=93;
B.CenterY:=45;
repeat
 HeroMovement;
 hit:=CollisionTile(B);
 case hit of
    ord(left): writeln('left');
   ord(right): writeln('right');
     ord(top): writeln('top');
  ord(bottom): writeln('bottom');
 else
  writeln;
 end;
until false;
end.
rect_overlap.pas
On 9/15/2019 at 1:43 AM, tebe said:
I successfully compiled and run mentioned game code with new version of Mads and Mad Pascal.
You already have compiled version of Mad Assembler on github, but I compiled it also anyway, with Free Pascal 3.0.4.
Thank you!
mads209.zip
  • 3 weeks later...
Hello.
The MADPascal compiler removes unused procedures without checking their use in assembler inserts.
For example:
program TestProject;
  procedure TestProc;
  var
    a: Byte;
  begin
    a:= 10;
  end;
begin
//  TestProc;
  asm
    jsr  TestProc
end.
mp generates note: "Note: Local proc 'TESTPROC' not used"
and mads generates error: "TestProject.a65 (185) ERROR: Undeclared label TESTPROC (BANK=0)",
but if you uncomment the call to the TestProc procedure, then mads compiler will be successful. Is there any way around this problem?
And another question: will the procedural type be implemented in MADPascal in the future?
3 hours ago, pvaWatson said:
Hello.
For example:
  procedure TestProc;
  var
    a: Byte;
  begin
    a:= 10;
  end;
begin
//  TestProc;
  asm
    jsr  TestProc
end.
It is a known and documented limitation, as Mad Pascal doesn't interpret the contents of the asm {} blocks at all.
I guess a circumvention would be to place an unreachable call to the procedure somewhere, so it is not removed by the pascal compiler.
Ok! Thanks for the answer.
I will do so. I thought that maybe there is a more beautiful solution, but if not, then no. ;-)
  • 1 month later...
http://mads.atari8.info/
Mad Pascal 1.6.2
- new unit EFAST, accelerated E:
- SYSTEM: function Copy(var S: String; Index: Byte; Count: Byte): String;
- SYSTEM: Palette, HPalette
- added support for 'array [0..x] of ^RECORD'
- new optimization for conditional blocks
- add PChar, https://www.freepascal.org/docs-html/rtl/system/pchar.html
- new switch -define:symbol
- new switch -ipath:includepath
example: plasma from Rascal Tutorials
plasma_2.obx plasma_2.pas
Edited by tebe
  • 1 month later...
On 8/26/2017 at 10:17 PM, bocianu said:
I think there is no problem using memory above A000.
You can take a look into sources of PacMad,
I'm switching off OS (procedure SystemOff), taking over vblank, and using all memory above A000 (except D000-D800).
In MadPascal examples, system is also switched off in 'pasintro'.
There is a little problem when BASIC is not switched off when starting a game. I am talking about additional code which would do that automatically, by not needing to press Option key.
I took bocianu's example on using special graphics mode 10++ (resolution 80x48, 9 colors) and modified it to show graphics similar to graphics mode 7 screen (pixel 2 scanlines high), but with more colors. It uses gr10pp unit and the most important procedure is Gr10Init, where you can set graphics mode 10 screen in different ways. I set it to 2 blank mode lines on top, 2 scanline mode line with effective resolution of 80x102.
I designed a set of alphanumeric and other characters, which can be used on the screen. These are collections of PutPixel, Line and Rectangle combinations.
nyan10p7.zip
nyan10p7.xex
Edited by Gury
  • Haha 1
