What is a good benchmark for comparing the speed of languages?
I want to do a benchmark that shows the speed of Action! versus compiled Turbo Basic XL. I also plan to show the added speed available from an accelerator, but that is easier to compare. There are many benchmarks, but some really don't show much about a language. For instance, Ahl's Simple Benchmark mostly shows the speed of the math pack. Benchmarks that mostly just write to the screen in loops largely show the speed of the E: or S: devices.
What are some other benchmarks that might better show the inherent speed of Action!?
Any ideas?
Thanks,
Larry
ACTION!
; ERATOSTHENES SIEVE BENCHMARK
MODULE
BYTE SIZE=[255]
CARD SIZEPL=[256]
BYTE ITER_MAX=[10]
;VAR:
BYTE ARRAY FLAGS(SIZEPL)
BYTE RTCLOK=20, RTP
, ITER, A
CARD I,K,COUNT
,PRIME
PROC BEGIN()
PRINT("ITERATIONS: ")
PRINTBE(ITER_MAX)
A=RTCLOK
DO
IF A=RTCLOK THEN EXIT FI
OD
RTCLOK=0
POKE(19,0)
POKE(18,0)
ITER=1
WHILE ITER<=ITER_MAX
DO
 COUNT = 0
 I = 0
 WHILE  I <= SIZE  DO
     FLAGS(I) = 1
     I==+1
 OD
 I  = 0
 WHILE  I <= SIZE  DO
  IF FLAGS(I)=1 THEN
        PRIME  =(I LSH 1)+ 3
        K  = I + PRIME
        WHILE  K <= SIZE  DO
          FLAGS(K)  = 0
          K==+PRIME
        OD
        COUNT==+1
  FI
  I==+1
  OD
  ITER==+1
 OD
RTP=RTCLOK
PRINT("PRIMES: ") PRINTCE(COUNT)
PRINT("FPS: ") PRINTBE(RTP)
[96]
Mad Pascal
// Eratosthenes Sieve benchmark
const
 size = 255;
 sizepl = 256;
 iter_max = 10;
var
  flags: array [0..sizepl] of boolean;
  iter: byte;
  i,k,count: word;
  prime: word;
function time: byte;
begin
asm
{ mva rtclok+2 Result
end;
begin
writeln(iter_max,' iterations');
asm
lda:cmp:req rtclok+2 ; reset clock
lda #0
sta rtclok
sta rtclok+1
sta rtclok+2
iter := 1;
while (iter <= iter_max) do begin
count := 0;
i := 0;
while (i <= size) do begin
flags[i] := true;
inc(i);
end;
i := 0;
if flags[i] then begin
prime := i shl 1 + 3;
k := i + prime;
while (k <= size) do begin
flags[k] := false;
k := k + prime;
end;
inc(count);
end;
inc(i);
end;
inc(iter);
end;
 writeln(count, ' primes');
 writeln(time, ' fps');
 repeat until keypressed;
end.
ACTION! is 3x faster then Mad Pascal
Edited by tebe
Any ideas?
Thanks,
Larry
A good start is the article about it in BYTE magazin, Sept. 1981: A High-Level Language Benchmark.
As far as I remember back then mostly the ERATOSTHENES SIEVE BENCHMARK was standard.
If you look at Draco's SysInfo maybe you get some ideas how to put such things to a high level language.
The Action! language is very closely designed around the particulars of the 6502 specifically, so the object code it makes is often tighter, faster, and more efficient than other high level languages that compile for the 6502. On the other hand, Action does not even natively support real (floating point) numbers. There is a library to add the capability, but it is a bit unwieldy.
A lot of software really doesn't require real number support though, and unwieldy or not, if you do need it you can "bolt it on." In all, Action is a great language for 6502 based machines and is the one I always hope to see get the most attention and effort in enhancing. A cross (or native) compiler that could output object code directly to disk would be wicked for example. There is... anyway I'm digressing. For a lot of tasks, you will be hard pressed to beat Action! for speed of high level language.
Edited by fujidude
Actually, Ahl's benchmark was also designed to do a lot of looping because that is a performance issue with some BASIC interpreters.
But looping is kind of a given for benchmarks in general.
The biggest problem with Ahl's benchmark is that he ignored string handling entirely.
Microsoft BASIC wasn't the fastest one out there but it did have excellent string handling.
And when it came to formatted numerical output, a BASIC with PRINT USING required a lot less code.
On that benchmark. The difference may be different for another one.
Since Mad Pascal is new I'm sure there is room for improvement.
Edited by JamesD
I get these results:
1899 primes in 89 jiffies (Altirra 1.79MHz 65C816)
1899 primes in 7 jiffies (Altirra 21.48MHz 65C816)
A jiffie on my NTSC emulated system is 1/60th of a second. So 89 jiffies = 1.48S, and 7 jiffies = 0.11S.
Yes, Sieve sounds like a winner. Thanks!
Larry
As always ... ;-)
But it's a very syntetic benchmark.
In the 1980s I was playing around with tests more oriented to practical issues: Moving memory content, calculating print data for graphical printouts in A3 and A4, converting pictures in memory, kaleidoscopes, etc. All routines done in the respective high level language without any tricks or subroutines in assembler. To me back then this was a more realistic approach to benchmark our A8.
  • 2 years later...
Performance compare of various Atari 800 programming languages
The Task: Fill a GRAPHICS 7 or GRAPHICS 15 screen
All programs except the last use built-in Atari graphics routines like
  • Graphics N
  • Position
  • Plot
Basic program: Graphics 7 takes the computer 103 seconds
Pascal program: Graphics 7 takes the computer 26 seconds. Used Kyan Pascal
ACTION! program: Graphics 15 takes the computer 45 seconds. Converted to Graphics 7 transforms to 23 seconds
Assember version 1: Graphics 7 takes the computer 18 seconds. I used ATMAS II
Assember version 2: Graphics 15 takes the computer 2 seconds!!! I used ATMAS II without the libraries
Graphical display of the time in seconds:
------------------------------------------------------------------------------------------------------- (Atari Basic)
-------------------------- (KYAN Pascal)
----------------------- (ACTION!)
------------------ (Assember version 1)
-- (Assember version 2)
The listings for Basic, PASCAL and ACTION! aren’t shown here, as they are basically the same. You know…
  • set GRAPHICS mode,
  • two encapsuled FOR-Loops x,y
  • plot
  • END.
That’s a bit boring.
Maybe Assembler is more interesting
Here’s my lisiting: Assember version 1 program
* MICHAEL SANDAU *
* PERFORMANCE ATARI 800 *
* TASK:FILL A *
* GRAPHICS 7 SCREEN *
* using a modified library *
* GRAFLIB.SRC mod is passing *
* x,y parameters in *
* X,Y registers direct *
* FILE: SPL.SRC *
* GRAFLIB.SRC
* Makro-Bibliothek
* GRAPHIK
* Fuer ATMAS-II
* PETER FINZEL
ZPXPOS EQU $C0 * ZERO PAGE X
ZPYPOS EQU $C1 * ZERO PAGE Y
* IOCB-Struktur:
ICCOM EQU $342
ICSTA EQU $343
ICBAL EQU $344
ICBAH EQU $345
ICBLL EQU $348
ICBLH EQU $349
ICAX1 EQU $34A
ICAX2 EQU $34B
CIOV EQU $E456
* CIO-Befehle
COPEN EQU 3
CCLSE EQU 12
CGTXT EQU 5
CPTXT EQU 9
CGBIN EQU 7
CPBIN EQU 11
CDRAW EQU $11
* ATARI Graphik-Variable
ATACHR EQU $2FB
ROWCRS EQU $54 CURSOR-
COLCRS EQU $55 POSITION
* GRAPHICS-Befehl
* Aufruf: GRAPHICS <stufe>
* <stufe> 0 bis 15 (XLs)
* 0 bis 11 (400/800)
GRAPHICS MACRO STUFE
JMP GR1
DEV@ ASC "S:"
GR1@ LDX #$60
LDA #CCLSE ZUERST KANAL 6
STA ICCOM,X SCHLIESSEN
JSR CIOV
LDA #STUFE JETZT NEUE GRAPHIK
STA ICAX2,X STUFE ANWAEHLEN
AND #$F0
EOR #$10
ORA #$0C
STA ICAX1,X
LDA #COPEN
STA ICCOM,X
LDA #DEV@
STA ICBAL,X
LDA #DEV@/256
STA ICBAH,X
JSR CIOV
MEND
* Auswahl der Zeichenfarbe
* Aufruf: COLOR <farbe>
* <farbe> von 0 bis 255, je nach
* Graphikmodus, muss eine
* Konstante sein.
COLOR MACRO COL
LDA #COL
STA ATACHR
MEND
* Positionierung des Cursors
* Aufruf: POSITION <x>,<y>
* <x>,<y> je nach Graphikmodus, beide
* UEBERGEBEN IN X UN Y REGISTER
POSITION MACRO
* LDA #X
TXA
STA COLCRS
* LDA #X/256 ONLY 320 PIX MODE
LDA #$0
STA COLCRS+1
* LDA #Y
TYA
STA ROWCRS
MEND
* Graphik-Punkte setzen
* Aufruf: PLOT <x>,<y>
* VOR AUFRUF IN X UND Y REGISTER
* BEFINDEN
PLOT MACRO
LDX #$60 KANAL 6
LDA #CPBIN
STA ICCOM,X
LDA #0
STA ICBLL,X
STA ICBLH,X
LDA ATACHR
JSR CIOV
MEND
* MICHAEL SANDAU *
* MAIN PROGRAM comes here: *
ORG $A800
GRAPHICS 7
COLOR 2
LDY #$0
STY ZPYPOS
OUTERY LDX #$0
STX ZPXPOS
INNERX POSITION * position in x and y register
PLOT
* GET POSITIONS BACK
LDX ZPXPOS
LDY ZPYPOS
INX
STX ZPXPOS
CPX #159
BNE INNERX
INY
STY ZPYPOS
CPY #95
BNE OUTERY
GRAPHICS 0
Assember version 2 program :
- saves current display list
- creates new display list for GRAPHICS 15
- does the performance by writing the pixels directly to screen memory
- restores previos display list for GRAPHICS 0
The fastest performing program is written completely by me. The comparison to the other programs is not fair. The program is so specialized that it ONLY works for this particular GRAPHICS mode.
* MICHAEL SANDAU *
* TASK:FILL A *
* GRAPHICS 15 SCREEN *
* FILE: SPD.SRC *
OLOOP EQU $B0 ; OUTER LOOP SHADOW
SDLISTL EQU $230 ; DL PTR LOW
SDLISTH EQU $231
DL1LEN EQU 32 ; LENGTH OF 1. DL
DL2LEN EQU 192 ; LENGTH OF 2. DL
ZPDLL EQU $B1 ; DL PTR IN ZERO PAGE
ZPDLH EQU $B2
ZPSPL EQU $B3 ; SCR PTR FOR COUNT
ZPSPH EQU $B4
PIXCNT EQU $B5 ; COUNTER FOR PIX/BYTE
SCRMEML EQU $00 ; SCREEN MEMORY GRAPHICS
SCRMEMH EQU $80
SDLISTC EQU $AA00 ;COPY OF DL
* AdresS OF CODE
ORG $A800
* PERFORMANCE TEST
JSR SAVEDL * SAVE DISPLAY LIST
JSR SETDL * SET DL TO GRAPHICS 15
JSR PERF * do perf test
JSR PERF
JSR RESTDL * restore DL
RTS
* **** END ******
PERF LDA #SCRMEML ; CREATE A PTR
STA ZPSPL ; TO LOOP THRU
LDA #SCRMEMH ; SCREEN MEMORY
STA ZPSPH
* OUTER LOOP 1: X REGISTER
LDX #0
LOOPXS NOP
* INNER LOOP 2: Y REGISTER
LDY #0
* ** SELECTING PIXELS *****
* ** AND STORE THEM IN SCREEN MEM
LOOPYS LDA #$40
STA (ZPSPL),Y ; 1 PIXEL
LDA #$50
STA (ZPSPL),Y
LDA #$54
STA (ZPSPL),Y
LDA #$55
STA (ZPSPL),Y ; 4 PIXELS
* STA $D40A ; wait wsync
INY
CPY #39 ; NEXT BYTE
BNE LOOPYS
* END INNER LOOP 2
* ADD 40 TO ZERO PAGE SCREEN POINTER
CLC
LDA ZPSPL
ADC #39 ;ADD 40 COLUMNS
STA ZPSPL
LDA ZPSPH
ADC #0 ;ADD CARRY IF NEEDED
STA ZPSPH
* CONTINUE OUTER LOOP
INX
CPX #191
BNE LOOPXS
* END OUTER LOOP 1
* END PERFORMANCE
RTS
***** SAVES THE ORIGINAL DISPLAY
***** LIST
SAVEDL LDY 0
LDA #$01
STA $C1 ; TRACE
LDA SDLISTL
STA ZPDLL
LDA SDLISTH
STA ZPDLH
LOOPDLS LDA (ZPDLL),Y
STA SDLISTC,Y
INY
CPY #DL1LEN
BNE LOOPDLS
RTS
SETDL LDY #6
LDA #$E ; antic mode
LPDL1S STA (ZPDLL),Y
INY
CPY #198 ; 192 TIMES
BNE LPDL1S
LDA #$41 ; SET END OF DL
STA (ZPDLL),Y
INY
LDA ZPDLL
STA (ZPDLL),Y
LDA ZPDLH
STA (ZPDLL),Y
LDY #3 ; LMS POS
LDA #$4E ; ANTIC MODE + LMS
STA (ZPDLL),Y
LDA #SCRMEML ;SET SCREEN MEMORY
INY ;SCREENMEM LOW
STA (ZPDLL),Y
LDA #SCRMEMH
INY
STA (ZPDLL),Y
RTS
*** RESTORES THE OPRIGINAL DISPAY LIST
RESTDL LDY #0
LDL1R LDA SDLISTC,Y
STA (ZPDLL),Y
INY
CPY DL1LEN
BNE LDL1R
RTS
******* END **********************
  • 2 weeks later...
Can anyone elaborate on the floating point library for Action? Where can it be found and is there any documentation for using it?
There's one including docs here and probably more on the same website. It's also included in GoodByteXL's Action! documentation that can be found one level up on the same website.
If your purpose is speed (which is what Action is for) you should probably think long and hard before using floating point.
Unless you're writing numerical analysis software for the 6502, in which case - good luck with that!
BugBear
SIX, thanks for the reply, i'll definitely check it out.
bugbear, I'm also interested in bench-marking the various languages available on the 8-bit Atari, but I feel to get an over-all bench mark you have to test more than just the fastest features. I feel that a good graphical routine that uses floating point gives you a more realistic bench mark than just finding primes with integer math...plus, it's slightly less boring having something to look at.
My benchmark of choice is that old chestnut the 3-D hat (Sine) program. It really stresses the system, and any improvement over the box stock basic or floating point routines sticks out like a sore thumb.
And thanks in advance for any speed up tips for the Hat program itself, but that's not really what I'm looking for. I just want to as directly as possible translate the original program code into each programming language using floating point so that I'm comparing apples to apples.
Altirra Basic and floating point routines are pretty quick and point to the biggest speed up for the Atari. Replace your OS ROM and Basic ROM with the Altirra versons and you almost tripled the speed of your Atari's Basic performance.
Of course you can get the same results by running Turbo Basic XL
Edited by Geister
