+jedimatt42 Posted July 31, 2015 Share Posted July 31, 2015 So, I've just gathered a pile of hardware. Including a PEB with TI (32k, rs323, floppy disk controller) and drive. I've picked up an NEC 3-1/2" floppy drive, and some blank disks. But I don't have Disk Manager 2 to format them with... There are things like dm2k that are EA5 programs... I have extended basic, and editor assembler cartridges... Is there any creative way to load a disk manager? Can EA5 load from RS232 connected to a PC, or should I try the .wav to cassette route? Can EA load from cassette? Can an emulator copy a file from disk to cassette/wav? I've actually ordered Disk Manager 2 and Terminal Emulator II cartridges off the great and wonderful e-bay, but that's no fun. and requires waiting. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted August 1, 2015 Share Posted August 1, 2015 you can load things from CS1, but I am not sure if you can load an EA5 program that has more than one file name. I have never tried that. Typically on programs that are EA5 files they will have at least 1 file, most have more and go up in number, 1,2,3, or A,B,C, etc.. If you have access to an older PC that can do DS/SD @ 40 tracks then you can you TI99-PC with OmniFlop to write actual TI disks on the PC then use them on the TI. Also, if your 3.5 drives you have has drive select jumpers then you will not have to modify your cable. If not, then the standard straigh through cable will see the drive as DSK2. You can see the drive cable mods on mainbyte.com Hope this helps. Quote Link to comment Share on other sites More sharing options...
Gazoo Posted August 1, 2015 Share Posted August 1, 2015 you can load things from CS1, but I am not sure if you can load an EA5 program that has more than one file name. I have never tried that. Typically on programs that are EA5 files they will have at least 1 file, most have more and go up in number, 1,2,3, or A,B,C, etc.. If you have access to an older PC that can do DS/SD @ 40 tracks then you can you TI99-PC with OmniFlop to write actual TI disks on the PC then use them on the TI. Also, if your 3.5 drives you have has drive select jumpers then you will not have to modify your cable. If not, then the standard straigh through cable will see the drive as DSK2. You can see the drive cable mods on mainbyte.com Hope this helps. Yes, you can load an EA5 set of files like DSKU from cassette. It will just take a while. Gazoo Quote Link to comment Share on other sites More sharing options...
TI-GAMER Posted August 1, 2015 Share Posted August 1, 2015 Where is the TI99-PC program on Whtech?... I found a broken link and could not find the actual program to download. Quote Link to comment Share on other sites More sharing options...
Shift838 Posted August 1, 2015 Share Posted August 1, 2015 Where is the TI99-PC program on Whtech?... I found a broken link and could not find the actual program to download. in the PC Utilities directory Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted August 1, 2015 Share Posted August 1, 2015 Or, you can use PC-TRANSFER and dump the contents from a PC-formatted 3.5" drive to your TI. Quote Link to comment Share on other sites More sharing options...
TI-GAMER Posted August 1, 2015 Share Posted August 1, 2015 in the PC Utilities directory Got it!!! Thank You as the link I found was sending me to the Utilities Dir and not the PCUtilities Dir Thanks Quote Link to comment Share on other sites More sharing options...
