RSS Bot Posted August 3, 2015 Share Posted August 3, 2015 One of the limitations of Stella is it doesn't emulate the jitter that occurs if overscan runs longer/shorter than normal. This is a quick attempt to address this. TIA.hxxChange currentFrameBuffer // contains the difference between the scanline counts of the // last two frames. If non-zero the image should jitter. Int32 myVariableScanlineJitter; TIA.hxxLocate this bit of code in endFrame() and add this directly above it Stella OS Jitter Test.app.zip (3.54MB)Number of downloads: 0 http://atariage.com/forums/blog/148/entry-12205-overscan-jitter/ Link to comment Share on other sites More sharing options...
