Fastmath OS?
Larry
I just checked, and the Fastmath OS gives about 15% or so faster execution time for Ahl's Benchmark than does the RamRod XE (aka OSN XL) OS. Does anyone know where the Fastmath OS came from? I know that quite a few folks have tinkered with the math pack going back to Wes Newell and Charles Marslett. Perhaps the Fastmath comes from Marslett's code?
-Larry
To follow up -- I used Drac030's UBI Basic (1st version) which uses the C. Marslett fast math package, and it gives the same execution time as the Newell OS, so that means that the Fastmath OS has a different math pack in it. The actual times for Rev C Basic are
Fastmath OS 117 sec.
Newell/Marslett 144 sec.
XLOS 405 sec. (for comparison)
So Fastmath OS is actually right at 19% faster -- quite significant at least in this type benchmark.
-Larry
If it is the same fastmath.rom I have here, it is probably faster just because it contains the same Marslett's FPP just with many (all?) loops unrolled. The FPP thus is faster, but occupies more ROM space: 3k instead of 2k. The additional code has been inserted instead of the CHARSET 2, do a POKE 756,204 and see what happens...
Edited by drac030
Fairly sure the original fast FP was marketed as a Newell product and available early 1980s as a 2K drop-in replacement for the 400/800 FP chip.
At some stage it was integrated into the Omnimon/Omniview OS - whether that OS ever came without it, unknown.
But both were fairly heavily advertised in the likes of Antic, Compute, Creative Computing, Byte etc.
I had just been trying to piece together what I could about the OS replacement chip products from Computer Support in the UK. I think I can characterize most of them to a basic extent, but I really can only guess about their "Super-Chip" or "Superchip" chips for the 400/800, 600XL/800XL, or 130XE. My best guess so far is that these might have been fast math offerings, but that's really only speculation. Anyone know what they really were? They were advertised for quite a while so I think they were probably real. These ads are all I have to go on.
Computer Support Atari-User-Vol-1-No-12.pdf
Computer Support Atari-User-Vol-2-No-04.pdf
  • 4 weeks later...
-Larry
Tom Hunt's Fast BASIC (FB.COM) does an Ahl's in 144 seconds. I tried MMG compiled on Ahl's and it got 360 seconds.
I see Newell/Marslett (what BASIC?)does 144 seconds. Hunt may have used the same code, or maybe they
are the same thing. I'm using Altirra.
FB.zip
MYAHL.BAS
Edited by russg
MMG compiled in 360 seconds would be reasonable since it is using the stock floating point package. There is another whole thread on the Ahl benchmark with many timings but I don't remember MMG in the mix. And we do have a plethora of Basics!
Did you try MMG with another math pack? I don't know/remember if the MMG compiler f.p. code is stand-alone or still needs the math pack to execute. You don't hear much about MMG any more.
Larry
I put the fast math chip, along with a custom character set, in my custom 400/800 16K eprom that I have in my 600XL. It's Rev. A. Built in basic doesn't work, but the cart works ok, like it that way. Also, when I hit reset, it resets completely, just like turning it off and off!
I was hoping someone would hack the XL/XE OS so it doesn't do the power-up test, bypass if you will. Then I could make the same changes to it!
One day I plan to hack my XE-Game system OS and change out the built in Basic/Missile Command to something else. 2 other games, 8K, or one 16K game.
Larry
I did stock MMG. ABC compiler I like better, but it doesn't do floating point. I don't know where I'd get a different math pack for MMG.
  • 1 year later...
The OS Image dumped in http://atariage.com/forums/topic/246862-more-questions-than-answers/contains the text "SUPER CHIP! ©1986 COMPUTER SUPPORT (UK) LTD" and is an OS hack with a built-in memory dumper.
Try this http://atariage.com/forums/topic/229116-modification-of-xl-os-rom-triggered-memory-test/?hl=%2Bos+%2Bchecksum+%2Bbob&do=findComment&comment=3060464
At least a couple of other things you may want to do like make the left margin 0 and change the default color of the screen at startup so you know your mod is active. I think I ran into one or two seldom used BASIC programs that didn't allow for changes to the left margin but it wasn't critical.
