Willsy Posted December 10, 2015 Share Posted December 10, 2015 Here's a tested Forth Assembler version. variable BITMSK $8000 BITMSK ! asm: doRLE ( rleSrcAddress vdpDestAddress -- ) *sp+ r0 mov, \ get vdp address r0 $4000 ori, \ set vdp write bit r0 swpb, \ get low byte r0 $8c02 @@ movb, \ write to vdp address reg r0 swpb, \ get high byte r0 $8c02 @@ movb, \ write to vdp address reg r0 6144 li, \ counter r1 clr, r9 $8c00 li, \ vdp write register *sp+ r8 mov, \ get pointer to rle data begin, r8 *+ r1 movb, \ get control byte BITMSK @@ r1 coc, \ packed or unpacked? eq if, \ packed r1 $7f00 andi, \ get count r1 swpb, \ move to low byte r1 r0 s, \ update counter begin, r8 ** r9 ** movb, \ write a byte r1 dec, \ decrement counter eq until, \ loop if not finished r8 inc, \ point to next control byte else, \ unpacked sequence - r1 contains count r1 swpb, \ move count to low byte r1 r0 s, \ update counter begin, r8 *+ r9 ** movb, \ write a byte r1 dec, eq until, endif, r0 r0 mov, \ check count eq until, \ loop if not finished ;asm Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 10, 2015 Share Posted December 10, 2015 Tursi, I'd be interested to see the RLE compression code, if you don't mind sharing? Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 10, 2015 Share Posted December 10, 2015 Like all the code in Convert9918, it's going to be really, really ugly. // Inputs: // pbuf - pointer to bytes to be packed // nSize - pointer to integer to receive the final packed size (does not need to be initialized) // InSize - size of the input buffer to be packed // Returns: // An oversized malloc'd buffer containing the RLE'd data - caller must free. // The int at nSize is filled in with the number of valid bytes in the returned memory. unsigned char *CTIPicViewDlg::RLEEncode(unsigned char *pbuf, int *nSize, int InSize) { int nOffset=0; int nOutputSize=0; unsigned char *pRet = (unsigned char*)malloc(InSize*2); // worst case while (nOffset < InSize) { // decide whether to do a run or data if ((pbuf[nOffset]==pbuf[nOffset+1]) && (pbuf[nOffset] == pbuf[nOffset+2])) { // worth doing an RLE run // work out for how far! int i=nOffset+3; while (pbuf[i] == pbuf[nOffset]) { i++; if (i>=InSize) break; if (i-nOffset >= 127) break; } pRet[nOutputSize++] = 0x80|(i-nOffset); pRet[nOutputSize++] = pbuf[nOffset]; nOffset=i; } else { // not worth doing RLE -- see for how long int i=nOffset+1; while ((pbuf[i]!=pbuf[i+1]) || (pbuf[i] != pbuf[i+2])) { i++; if (i>=InSize) break; if (i-nOffset >= 127) break; } pRet[nOutputSize++] = i-nOffset; for (int c=0; c<i-nOffset; c++) { pRet[nOutputSize++] = pbuf[nOffset+c]; } nOffset=i; } } *nSize = nOutputSize; if (cmdFileIn[0] == '\0') printf("RLE compress table from %d to %d bytes\n", InSize, nOutputSize); return pRet; } The function doesn't know or care what type of data is passed it, it's just taking a pointer to a memory array of bytes. It's straight forward enough - it looks at the next three bytes. If they are the same, it will encode it as a run of that single byte, otherwise it will encode a run of data. Once it makes that decision, both paths look ahead to see how many bytes before the pattern breaks (ie: for a run of the same byte, the first different byte, and for a run of data, the first place where 3 bytes the same are found). Both cases also stop if they reach the end of data or count up to 127, which is the maximum count. Once determined, it fills in the output data. I didn't account for the common case of getting one more byte out of a run by letting 0 mean 1... 0 means 0, so count bytes of >00 and >80 are meaningless in this one. 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 11, 2015 Author Share Posted December 11, 2015 Okay, here is the high-resolution (revised) JetPac label. I uploaded it in a .ZIP because Atari Age has a habit of degrading images and even re-sizes them down, which can really make them 'kinda sucky' if you plan to print them. Thanks again Looks great! Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 16, 2015 Author Share Posted December 16, 2015 Jet Pac version 0.95 Splash screen in place as well as most sounds except for the rocket takeoff and landing. Some tweaking is still needed. Getting there https://youtu.be/HT5i0YXi6Mc 7 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted December 17, 2015 Share Posted December 17, 2015 WOWZA!!!! Great stuff! Quote Link to comment Share on other sites More sharing options...
Asmusr Posted December 18, 2015 Share Posted December 18, 2015 There is an issue, which is also visible on the video, where a meteor sprite appear very briefly at the side of the screen and then disappears. Have you figured out the reason for that? Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 20, 2015 Author Share Posted December 20, 2015 All monsters start off on the left side of the screens, but some move left and others move right. The left moving ones disappear from the left side of the screen and reappear on the right side as sprites normally do Quote Link to comment Share on other sites More sharing options...
Asmusr Posted December 20, 2015 Share Posted December 20, 2015 Is it possible to use early clock for sprites in TF? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 20, 2015 Share Posted December 20, 2015 Is it possible to use early clock for sprites in TF? With sprites moving in both directions, won't using the early clock just change which side of the screen the edge "anomaly" occurs. ...lee Quote Link to comment Share on other sites More sharing options...
Tursi Posted December 20, 2015 Share Posted December 20, 2015 With sprites moving in both directions, won't using the early clock just change which side of the screen the edge "anomaly" occurs. ...lee The trick is you change the clock based on which side of the screen it's on. Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 21, 2015 Share Posted December 21, 2015 TF doesn't use early clock. I've never used it ever! At what point should it be switched on? Quote Link to comment Share on other sites More sharing options...
Asmusr Posted December 21, 2015 Share Posted December 21, 2015 The trick is you change the clock based on which side of the screen it's on. Exactly. Lets say you have a sprite with horizontal position X that can also be negative (X >= -32). A position of -16 means that the sprite is just out of screen to the left and a position of 256 means that it's just out of screen to the right. To convert this into a sprite attribute you decide on an arbitrary breakpoint, say 128, below which you adjust the attribute and set the early clock (EC): IF X < 128 ATTR_X = X + 32 ATTR_EC = 1 ELSE IF X > 255 ATTR_X = 0 ATTR_EC = 1 ELSE ATTR_X = X ATTR_EC = 0 ENDIF 2 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted December 21, 2015 Author Share Posted December 21, 2015 Or I can just have the left moving sprites appear on the right edge of the screen This should be fairly simple to implement. 2 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 21, 2015 Share Posted December 21, 2015 IIRC, the early clock is a setting for each sprite, right? Why not just directly manipulate the sprite table? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 21, 2015 Share Posted December 21, 2015 IIRC, the early clock is a setting for each sprite, right? Why not just directly manipulate the sprite table? It is, indeed, a setting for each sprite in the Sprite Attribute Table—4 bytes for each of 32 sprites. The MSb (80h) of the 4th byte sets or resets the early clock for that sprite. ...lee Quote Link to comment Share on other sites More sharing options...
Willsy Posted December 21, 2015 Share Posted December 21, 2015 The early clock would make collision detection with background a real pita as you'd have to correct for the early clock before checking background characters. It would be best implemented at the TF kernel level rather than the application level. The kernel could account for early clock and do the horizontal correction such that it's transparent to the application. The application does not want a sudden jump in horizontal coordinates by 32 pixels. It needs a logical horizontal coordinate system implementation on top of the physical system. Perfectly doable with relatively little impact. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted December 21, 2015 Share Posted December 21, 2015 (edited) TF doesn't use early clock. I've never used it ever! At what point should it be switched on? I would think it is not a good idea to set the early clock when the sprite is visible because it will jump 32 pixels left at the moment it is set—unless you can change its position fast enough to not notice it, which I doubt is probably possible in TF. ...lee [EDIT: I'm too slow!] Edited December 21, 2015 by Lee Stewart Quote Link to comment Share on other sites More sharing options...
Asmusr Posted December 21, 2015 Share Posted December 21, 2015 Or I can just have the left moving sprites appear on the right edge of the screen This should be fairly simple to implement. Yes I think that would be a good and easy solution. Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted January 5, 2016 Author Share Posted January 5, 2016 Good news! Willsy's sound player works like a charm, so we are back in business I have also corrected the monster spawning issue pointed out by Asmusr-M. Just waiting on the last 2 sound effects from OLD CS1 and the game will be officially done. I should be posting the version 1.0 binary pretty soon. Yay! 5 Quote Link to comment Share on other sites More sharing options...
Iwantgames:) Posted January 5, 2016 Share Posted January 5, 2016 Nice Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted January 14, 2016 Author Share Posted January 14, 2016 Teaser... First Jet Pac cart 8 Quote Link to comment Share on other sites More sharing options...
Iwantgames:) Posted January 14, 2016 Share Posted January 14, 2016 Quote Link to comment Share on other sites More sharing options...
Willsy Posted January 14, 2016 Share Posted January 14, 2016 Oh my. How frikken' cool is that? Put me down for one! Quote Link to comment Share on other sites More sharing options...
Imperious Posted January 14, 2016 Share Posted January 14, 2016 Looking forward to this. Have played the Vic-20 and Amstrad CPC464 (Spectrum emulated) versions on real hardware lately. Quote Link to comment Share on other sites More sharing options...
