Thekng123 Posted August 21, 2015 Share Posted August 21, 2015 i normally play ps3 through rca. but the tv in my bedroom only has coaxial input, and i want to play ps3 on it. can i use a rf switch made for ps1/ps2 (i already have that)? Quote Link to comment Share on other sites More sharing options...
Nutsy Doodleheimer Posted August 21, 2015 Share Posted August 21, 2015 Unfortunatley you aren't able to. It only inputs through AV composite or HDMI. You can't use RF. It's not compatible with the tv. That old analog tv doesn't have a converter for the ps3 digital signal - modern sets convert to a 50hz or 60hz signal through the input. Quote Link to comment Share on other sites More sharing options...
+MacRorie Posted August 21, 2015 Share Posted August 21, 2015 If you find an old VCR with RCA-Composite inputs and coax connectors, you could use that to connect the PS3 to the older TV. That *should* work. Just make sure you are able to change the input on the VCR, some of them need a remote to do so. Quote Link to comment Share on other sites More sharing options...
Giltygear Posted August 27, 2015 Share Posted August 27, 2015 i normally play ps3 through rca. but the tv in my bedroom only has coaxial input, and i want to play ps3 on it. can i use a rf switch made for ps1/ps2 (i already have that)? What year is this? How do you not have a TV with a composite input? Quote Link to comment Share on other sites More sharing options...
Thekng123 Posted August 28, 2015 Author Share Posted August 28, 2015 What year is this? How do you not have a TV with a composite input? i do but it's in the living room. Quote Link to comment Share on other sites More sharing options...
Tempest Posted August 28, 2015 Share Posted August 28, 2015 I'd think that even if you got coax working most of the text would be impossible to read. I hooked my PS3 up via composite once and even then the text was hard to read. Quote Link to comment Share on other sites More sharing options...
