Wico Command Ball or Bat
Opry99er
I have a Wico Command Bat and a Ball, I recently picked up used off ebay...
I have mixed feelings about them... they look premium.. but I cannot get through the refueling tunnel in parsec with them...
Until tonight, the base button on the Ball didn't work at all... someone had swapped some wires around inside. I put them back and it now behaves just like the Bat.
I'm not sure if either of them behave correctly though... The base/stick switch seems to function only to disable the base, but never disables the stick button. Is that normal?
As I opened up the Ball to see why the base button didn't work, there was plenty of rubber dust. So maybe they just need the contacts cleaned...
I'd be up for a trade.
Here are some photos:
https://goo.gl/photos/ouKARrkurMrEUwBh9
Hi Matt,
Nice pics, thanks. I have one question.
Are these the right names for these Joysticks, "Command Bat" and "Ball" ?
(As I want to add them to "The List"....)
http://atariage.com/forums/topic/241978-ti-99-resources-lets-have-a-list-for-it/?p=3306338
thanks
schmitzi
PS: Maybe you hve a pic from the boxes, with the Wico´s part-numbers ?
PS2: ;) Maybe u have a pic with readable specs from the powersupplies, if exists ?
http://atariage.com/forums/topic/242092-ti-99-resources-requests-for-facts-specs-data/?p=3308313
WICO-Section from today:
Wico Command Bat
Wico Command Ball
I believe this is correct terminology.
Those are not normal behaviors, jedi.
The switch should engage the buttons as you think... Base should enable base button, stick should engage stick button. I currently use the ball version, always use stick button option. I earned a SubClub Activision patch on my 2600 scoring over 64,000 points on SeaQuest using the ball. Absolutely love these sticks.
Edited by Opry99er
Very good looking sticks there. The ball version is my absolute favorite. I have had the same one in my collection for 25+ years... Belonged to my dad before me.
  • 3 weeks later...
yes,
with my tester i have a 7.4v in output connecting the positive cable to the + that you have indicated in the picture. but if i will inverting the cables on the connector i have the same value, so i am not sure, just i suppose that it is right as the picture :)
Edited by ti99iuc
