NinjaWarrior Posted August 30, 2015 Share Posted August 30, 2015 I been watching Videos on YouTube about the Mods, Looks kinda easy if you do it alot of times One guy was making a switch on the Controller for the Master System & the C64, I wonder if you can do the same with Master System & the 7800...Having a switch for 7800 mode to SMS mode on the Controller Quote Link to comment Share on other sites More sharing options...
Andromeda Stardust Posted August 30, 2015 Share Posted August 30, 2015 (edited) I created a schematic for a 2-in1 joystick, but due to the fact the 7800 fire buttons share a separate ground plane from the joystick, and the SMS fire buttons share the same ground plane with the joystick, a third button is required. I don't think it would work well as a pad hack, but here is my design: http://atariage.com/forums/topic/241814-universal-joystick-schematic-for-2600-7800-sms-untested/?hl=%2B7800+%2Bsms+%2Bschematic This uses a DPDT switch to change the function. The 7800 buttons act as dual fire on 2600 and both function as button 1 on SMS, necessitating adding a third button for button 2 in SMS mode. In addition the schematic adds a diode and pullup resistor which holds pins 5 and 9 high when connected to Atari in SMS mode, enabling 2600 homebrew that detects Genny controllers to utilise the extra button. But sadly I don't see cramming this into a controller pad conversion, although a 3-button Genesis would be the perfect candidate. It may be easier to do separate controller mods for NES-to-7800 and NES-to-SMS and use a stock Genesis controller for the 2600 homebrews. The diode and pullup resistor from my 2-in-1 design could be incorporated into the NES-to-SMS mod to allow 2600 homebrews to read the second button (the homebrews that read Genesis will not work with stock SMS due to the lack of pullup resistors), although I have not created a wiring diagram for this nor tested the design. Unless you loathe using a Genesis controller to play SMS/Atari, it can be made compatible with the few SMS games that don't respond well to Genesis by disconnecting SELECT pin 7. You could wire a SPST switch inside the 3-button Genesis controller to restore pin 7 when playing Genesis games so you don't lose use of the controller. Alternately you could sever this connection using an extension plug. Due to a programming bug, certain SMS games pull the Select line low which switches B/C inputs to Start/A and disables half of the Dpad. Select pin 7 is not connected on SMS controllers by default so the state of this line should in theory have no effect on gameplay, but in practice it will screw up proper operation when a Genesis controller is connected. Pin 7 needs to be connected for the Genesis controller to work on a 2600 because that is Atari VCC and the logic chip needs a power source to function. Pin 7 Select is connected to Sega VCC pin 5 via a pullup resistor which somehow passes enough current for the controller to operate. Edited August 30, 2015 by stardust4ever 1 Quote Link to comment Share on other sites More sharing options...
NinjaWarrior Posted August 31, 2015 Author Share Posted August 31, 2015 I only want pictures of the NES Controller Mod for the Master System Quote Link to comment Share on other sites More sharing options...
NinjaWarrior Posted January 13, 2016 Author Share Posted January 13, 2016 I have the Mayflash SNES/NES to Wii/Wii U adapter that came with this, Can and Adapter be wired up to plug in Master System and a NES Controller? Quote Link to comment Share on other sites More sharing options...
Osgeld Posted January 13, 2016 Share Posted January 13, 2016 if it has all 9 wires yes Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted January 14, 2016 Share Posted January 14, 2016 That's not going to work at all since the NES controller is multiplexed and you'd need to build a decoding circuit so the button inputs will actually register. This page describes how to use an NES controller on a PC gameport, but the principles are pretty much the same: http://www.tredonox.com/temp/nescontrollerdecoder/NEStodiscreetadapter.htm Quote Link to comment Share on other sites More sharing options...
NinjaWarrior Posted January 17, 2016 Author Share Posted January 17, 2016 Thanks Ben Just going to get a NES Controller Modded anyways Quote Link to comment Share on other sites More sharing options...
Dennis90 Posted April 7, 2018 Share Posted April 7, 2018 That mod diagram is pretty neat Kosmic Stardust! But is there not a way tho to only use two buttons, like B and A on a NES controller? Mabye if you add more switches or something to chane between the modes? Quote Link to comment Share on other sites More sharing options...
