+grips03 Posted October 5, 2015 Share Posted October 5, 2015 photos with hot glue mounted switch. 3 Quote Link to comment Share on other sites More sharing options...
santosp Posted October 5, 2015 Author Share Posted October 5, 2015 Congratulations!! Something like this I had in my mind! Thank you for share! P.S. Why this yellow glue tape is needed?? Quote Link to comment Share on other sites More sharing options...
jrose78 Posted October 5, 2015 Share Posted October 5, 2015 (edited) I decided to mount at the top. It might be in the way of the label a bit, but I think overall it works well. I got to get my hands on a hole puncher to finish the top and make it look good. The photos show the switch sticking out a lot but when I glued it I made sure it only stuck out a little bit and you can barely tell its there. Edited October 5, 2015 by jrose78 2 Quote Link to comment Share on other sites More sharing options...
santosp Posted October 5, 2015 Author Share Posted October 5, 2015 Its also a way! Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted October 5, 2015 Share Posted October 5, 2015 (edited) Very nice work guys and thanks for the photos. You can tell how impatient I am, because I can easily figure this out when I get my package but...what size bit did you use for the hole? Oh an, apparently I need a hot glue gun. I was going to superglue the thing but I learned on one of my previous projects, hot glue is kind of temporary, super glue is forever..... Edited October 5, 2015 by GoldenWheels Quote Link to comment Share on other sites More sharing options...
jrose78 Posted October 5, 2015 Share Posted October 5, 2015 Very nice work guys and thanks for the photos. You can tell how impatient I am, because I can easily figure this out when I get my package but...what size bit did you use for the hole? Oh an, apparently I need a hot glue gun. I was going to superglue the thing but I learned on one of my previous projects, hot glue is kind of temporary, super glue is forever..... I used super glue (does that not last?) . Also I think the bit I used was 15/64 . 1 Quote Link to comment Share on other sites More sharing options...
santosp Posted October 5, 2015 Author Share Posted October 5, 2015 Two friendly advises as for the hot glue. Buy not the usual cheap one, but this who after melt is like gum. Before you glue -for example- this micro switch on the shell, prepare both surfaces roughen them with a dremel tool. Thickness of cap is 6 millimeters. 1 Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted October 5, 2015 Share Posted October 5, 2015 I used super glue (does that not last?) . Also I think the bit I used was 15/64 . Hey, super glue is great and is super strong. What I've learned was, unlike hot glue which you can kinda sorta warm up again to remove...superglue simply RIPS the surface off of whatever you used it on if you try to move it later! You gotta get it right the first time. Two friendly advises as for the hot glue. Buy not the usual cheap one, but this who after melt is like gum. Before you glue -for example- this micro switch on the shell, prepare both surfaces roughen them with a dremel tool. Thickness of cap is 6 millimeters. Thanks santos! I would not have thought to roughen them to give them some grip for the glue, good tip. Quote Link to comment Share on other sites More sharing options...
jrose78 Posted October 5, 2015 Share Posted October 5, 2015 ok got the top label done. It was hard because all I had was a 3 hole puncher but it turned out ok. 2 Quote Link to comment Share on other sites More sharing options...
+Firedawg Posted October 5, 2015 Share Posted October 5, 2015 Received mine today Panos!!! Mike Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 6, 2015 Share Posted October 6, 2015 Congratulations!! Something like this I had in my mind! Thank you for share! P.S. Why this yellow glue tape is needed?? The cartridge shell's plastic ridge was rubbing against the solder mask, so I figured Kapton tape would help it out a bit. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted October 6, 2015 Share Posted October 6, 2015 The cartridge shell's plastic ridge was rubbing against the solder mask, so I figured Kapton tape would help it out a bit. Interesting, usually that type of tape is used to shield against heat, not contact friction. Is it working well? I need to order some of that tape for different reasons. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 6, 2015 Share Posted October 6, 2015 Interesting, usually that type of tape is used to shield against heat, not friction. true, but its super thin and it is what I had on hand and should work fine Quote Link to comment Share on other sites More sharing options...
gorfcadet Posted October 6, 2015 Share Posted October 6, 2015 (edited) I put the switch on the back. I used three pieces of double sided padded adhesive to pad and hold the button in place. Great work on the pcbs! So glad to have this in my collection! If only I wasn't completely terrible at Double Dragon! Seriously, what is the trick to that game? Ipads... of course the thumbnail is upside down. Edited October 6, 2015 by gorfcadet 1 Quote Link to comment Share on other sites More sharing options...
santosp Posted October 6, 2015 Author Share Posted October 6, 2015 @grips03 I saw once more carefully the picture from your cartridge inside, and try to understand what is so strange with this? Special Atari cart shell?? @gorfcadet Someone should catch a camera and make a video. One of the tricks. Stay on a place, and kick all the time. Enemies behind you will never touch you. A major update it would be a new combination between the joy and buttons. 1 Quote Link to comment Share on other sites More sharing options...
+swlovinist Posted October 6, 2015 Share Posted October 6, 2015 my cart arrived safely. Very professional. I cannot wait to check it out. Quote Link to comment Share on other sites More sharing options...
Jinks Posted October 6, 2015 Share Posted October 6, 2015 I just reverse elbow on the bad guys crossing the screen. They are trying to get on both sides of you doing their zombie walk mode they are harmless and like the elbow very much. I am going to try this on a centipede cart. Or maybe hat trick that game blows it. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 6, 2015 Share Posted October 6, 2015 @grips03 I saw once more carefully the picture from your cartridge inside, and try to understand what is so strange with this? Special Atari cart shell?? @gorfcadet Someone should catch a camera and make a video. One of the tricks. Stay on a place, and kick all the time. Enemies behind you will never touch you. A major update it would be a new combination between the joy and buttons. Cart shell is from Karateka Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted October 6, 2015 Share Posted October 6, 2015 One Hat Trick dead, Double Dragon/Rampage lives! Thanks Santos! 2 Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted October 6, 2015 Share Posted October 6, 2015 Just tossing it out there Santos....I myself would LOVE a similar combo cart version of Froggo's 7800 games: Water Ski and Tank Command.... 2 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted October 6, 2015 Share Posted October 6, 2015 Just tossing it out there Santos....I myself would LOVE a similar combo cart version of Froggo's 7800 games: Water Ski and Tank Command.... Me too, with Kev's background color mod on Tank Command. 1 Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted October 6, 2015 Share Posted October 6, 2015 (edited) Me too, with Kev's background color mod on Tank Command. Yes! BTW, Santos mistakenly sent me two end labels (I only got one of the larger front label). If anyone in the US butchers theirs during install (don't be embarrassed, I've done it too) let me know, I'll throw it in an envelope and send it to them. Edited October 6, 2015 by GoldenWheels Quote Link to comment Share on other sites More sharing options...
santosp Posted October 6, 2015 Author Share Posted October 6, 2015 Just tossing it out there Santos....I myself would LOVE a similar combo cart version of Froggo's 7800 games: Water Ski and Tank Command.... Are you perhaps a Prophet?? PCB design and GAL logic for this, sent to Kevin before 20 days. Now when and if he start this project its up to him. Maybe is time to tease him..... 2 Quote Link to comment Share on other sites More sharing options...
+GoldenWheels Posted October 6, 2015 Share Posted October 6, 2015 Are you perhaps a Prophet?? PCB design and GAL logic for this, sent to Kevin before 20 days. Now when and if he start this project its up to him. Maybe is time to tease him..... AWESOME! :thumbsup: This was simply the next combo that made the most sense to me. The ENTIRE Froggo 7800 library on one cartridge! And Tank Command is RIDICULOUSLY expensive on the aftermarket (one of the few 7800 games I still don't own, I refuse to pay the asking prices). Obviously, please consider me in for one Santos! Quote Link to comment Share on other sites More sharing options...
santosp Posted October 6, 2015 Author Share Posted October 6, 2015 (edited) No not I! Kevin must do it! Its his idea. Only the pcb design and pld logic is mine! Edited October 6, 2015 by santosp 1 Quote Link to comment Share on other sites More sharing options...
