+nanochess Posted September 1, 2015 Share Posted September 1, 2015 Hi. Just I worked out this IntyBASIC demo of bats flying and attacking on screen. It uses the new structured programming features (block IF and DO loop) so when you check the source code, there are no labels! Also the SPRITE expr feature available now in IntyBASIC v1.2.3 Enjoy it! REM REM Bats REM Demo for IntyBASIC REM by Oscar Toledo G. http://nanochess.org/ REM Sep/01/2015 REM ' Note there is no use of labels, thanks to the use of the structured loops include "constants.bas" DIM x(,y(,f(,dx( ' Put in random coordinate each bat FOR a = 0 TO 7 x(a) = RANDOM(152) + 8 y(a) = RANDOM(48) + 24 f(a) = $2d ' Uses M and W letter ($2d and $37), V for attack ($36) dx(a) = 1 NEXT a bats = 8 ' Main loop DO ' Show bats FOR a = 0 TO 7 SPRITE a,x(a)+VISIBLE,y(a),f(a)*8+(a AND 1)*3+2 NEXT a WAIT ' Move bats FOR a = 0 TO 7 IF f(a) = $36 THEN ' Attacking? IF y(a) < 104 THEN y(a) = y(a) + 1:IF y(a) > 103 THEN bats = bats - 1 ELSE ' Bats goes left to right and back x(a) = x(a) + dx(a) IF x(a) = 8 OR x(a) = 160 THEN dx(a) = -dx(a) ' Vertical movement is random (-2 to +2) y(a) = y(a) + RANDOM(5) - 2 IF y(a) < 8 THEN y(a) = 8 IF y(a) > 80 THEN y(a) = 80 ' Move wings each 4 frames IF (FRAME AND 3) = 0 THEN IF f(a) = $2D THEN f(a) = $37 ELSE f(a) = $2d END IF NEXT a IF (FRAME AND 255) = 0 THEN ' Each 256 frames, a bat attacks FOR a = 0 TO 7 IF f(a) <> $36 THEN f(a) = $36:EXIT FOR NEXT a END IF LOOP UNTIL bats = 0 WAIT FOR a = 0 TO 7 SPRITE a,0 NEXT a bats.bas 7 Quote Link to comment Share on other sites More sharing options...
artrag Posted September 2, 2015 Share Posted September 2, 2015 (edited) Lovely ! PS Thanks for the new implementation. Now one can pass from this: sprite: procedure on n goto s0,s1,s2,s3,s4,s5,s6,s7 s0: SPRITE 0,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE: return s1: SPRITE 1,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE: return s2: SPRITE 2,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE: return s3: SPRITE 3,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE: return s4: SPRITE 4,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE: return s5: SPRITE 5,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE: return s6: SPRITE 6,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE: return s7: SPRITE 7,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE: return end to this: SPRITE n,x+VISIBLE,y+ZOOMY2,SPR00+SPR_BLUE Edited September 2, 2015 by artrag 1 Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted September 8, 2015 Share Posted September 8, 2015 Suddenly I had a thought of a port of the Atari 2600 version of Demon Attack... 1 Quote Link to comment Share on other sites More sharing options...
Kiwi Posted September 8, 2015 Share Posted September 8, 2015 You know what this sample needs? More bats!!! REM Bats REM Demo for IntyBASIC REM by Oscar Toledo G. http://nanochess.org/ REM Sep/01/2015 REM ' Note there is no use of labels, thanks to the use of the structured loops include "constants.bas" FLICKER=0 Timer=0 DIM x(16),y(16),f(16),dx(16) ' Put in random coordinate each bat FOR a = 0 TO 15 x(a) = RANDOM(152) + 8 y(a) = RANDOM(48) + 24 f(a) = $2d ' Uses M and W letter ($2d and $37), V for attack ($36) dx(a) = 1 NEXT a bats = 16 ' Main loop DO ' Show bats Timer=Timer+1 IF flicker=0 then FOR a = 0 TO 7 SPRITE a,x(a)+VISIBLE,y(a),f(a)*8+(a AND 1)*3+2 NEXT a END IF if flicker=0 then flicker=1:goto flick IF flicker=1 then FOR a = 0 TO 7 SPRITE a,x(a++VISIBLE,y(a+,f(a+*8+(a+8 AND 1)*3+2 NEXT a flicker=0 END IF flick: WAIT ' Move bats FOR a = 0 TO 15 IF f(a) = $36 THEN ' Attacking? IF y(a) < 104 THEN y(a) = y(a) + 1:IF y(a) > 103 THEN bats = bats - 1 ELSE ' Bats goes left to right and back x(a) = x(a) + dx(a) IF x(a) = 8 OR x(a) = 160 THEN dx(a) = -dx(a) ' Vertical movement is random (-2 to +2) y(a) = y(a) + RANDOM(5) - 2 IF y(a) < 8 THEN y(a) = 8 IF y(a) > 80 THEN y(a) = 80 ' Move wings each 4 frames IF (Timer AND 3) = 0 THEN IF f(a) = $2D THEN f(a) = $37 ELSE f(a) = $2d END IF NEXT a IF (Timer AND 255) = 0 THEN ' Each 256 frames, a bat attacks FOR a = 0 TO 15 IF f(a) <> $36 THEN f(a) = $36:EXIT FOR NEXT a END IF LOOP UNTIL bats = 0 WAIT FOR a = 0 TO 7 SPRITE a,0 NEXT a I would have got fired from Mattel for multiplexing sprites and get fired from nanochess for using a label in this sample. Anyway, I used label to do flickering routine for the Colecovision and decided to use it here since I didn't know a way to do flipflop. I changed FRAME to Timer since FRAME is a 16-bit variable and Timer is 8-bit. So the event of the bats to attack wasn't working properly with 16 bats. This is just a short exercise to test out multiplexing. 4 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted September 8, 2015 Author Share Posted September 8, 2015 Hehehe, pretty well done! BTW, as you increase timer in >each< frame, you get same behavior as with FRAME AND 255, besides as Timer is an 8 bits variable the AND 255 is unneeded. Furthermore, you could have created a constant called MAX_BATS = 16, and use it in the FOR loop as MAX_BATS - 1 Going further, you can delete the label using the IF block feature: IF flicker=0 then FOR a = 0 TO 7 SPRITE a,x(a)+VISIBLE,y(a),f(a)*8+(a AND 1)*3+2 NEXT a flicker = 1 ELSE FOR a = 0 TO 7 SPRITE a,x(a++VISIBLE,y(a+,f(a+*8+(a+8 AND 1)*3+2 NEXT a flicker=0 END IF 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted September 8, 2015 Share Posted September 8, 2015 While optimizing, you could replace this: FOR a = 0 TO 7 SPRITE a,x(a++VISIBLE,y(a+,f(a+*8+(a+8 AND 1)*3+2 NEXT a by the following code, that saves 8*4 = 32 additions at the cost of 8 subtractions FOR a = 8 TO 15 SPRITE a-8,x(a)+VISIBLE,y(a),f(a)*8+(a AND 1)*3+2 NEXT a 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted September 8, 2015 Author Share Posted September 8, 2015 While optimizing, you could replace this: FOR a = 0 TO 7 SPRITE a,x(a++VISIBLE,y(a+,f(a+*8+(a+8 AND 1)*3+2 NEXT a by the following code, that saves 8*4 = 32 additions at the cost of 8 subtractions FOR a = 8 TO 15 SPRITE a-8,x(a)+VISIBLE,y(a),f(a)*8+(a AND 1)*3+2 NEXT a In fact thanks to the new IntyBASIC optimizer, both code sequences run at same speed you can write it as you like most Quote Link to comment Share on other sites More sharing options...
artrag Posted September 8, 2015 Share Posted September 8, 2015 Impressive! Is it already released in the current intybasic or will it appear in the next versions ? Quote Link to comment Share on other sites More sharing options...
Kiwi Posted September 9, 2015 Share Posted September 9, 2015 (edited) Hehehe, pretty well done! BTW, as you increase timer in >each< frame, you get same behavior as with FRAME AND 255, besides as Timer is an 8 bits variable the AND 255 is unneeded. Furthermore, you could have created a constant called MAX_BATS = 16, and use it in the FOR loop as MAX_BATS - 1 Going further, you can delete the label using the IF block feature: IF flicker=0 then FOR a = 0 TO 7 SPRITE a,x(a)+VISIBLE,y(a),f(a)*8+(a AND 1)*3+2 NEXT a flicker = 1 ELSE FOR a = 0 TO 7 SPRITE a,x(a++VISIBLE,y(a+,f(a+*8+(a+8 AND 1)*3+2 NEXT a flicker=0 END IF FRAME variable I believe is increased at every interrupt. So if the game is at half speed, then it won't hit 255 or 3, so I think FRAME is increasing by 2. So the events weren't activating. Currently, I'm trying to figure out how to make it stop multiplexing when the bats are less than 9. Eventually I'll crack the code. And also I'm thinking of making a game based of this sample. Edited September 9, 2015 by Kiwi 1 Quote Link to comment Share on other sites More sharing options...
artrag Posted September 9, 2015 Share Posted September 9, 2015 (edited) I would avoid sprite multiplexing if you plan to run the main loop at 30Hz... Flickering would be too high. Btw There is also on frame gosub... It could be used to multiplex sprites independently of the main loop timings. Edited September 9, 2015 by artrag Quote Link to comment Share on other sites More sharing options...
+nanochess Posted September 9, 2015 Author Share Posted September 9, 2015 Impressive! Is it already released in the current intybasic or will it appear in the next versions ? Already supported since v1.2 FRAME variable I believe is increased at every interrupt. So if the game is at half speed, then it won't hit 255 or 3, so I think FRAME is increasing by 2. So the events weren't activating. Currently, I'm trying to figure out how to make it stop multiplexing when the bats are less than 9. Eventually I'll crack the code. And also I'm thinking of making a game based of this sample. Yes, but you were updating the variable in each frame or maybe simply the program went slow and you were losing frames. You can use the 'bats' variable as reference counter as the bats are deleted in sequence. Quote Link to comment Share on other sites More sharing options...
intvnut Posted September 9, 2015 Share Posted September 9, 2015 (edited) Currently, I'm trying to figure out how to make it stop multiplexing when the bats are less than 9. Eventually I'll crack the code. And also I'm thinking of making a game based of this sample. The trick I use is to keep track of the "first not displayed" sprite when scanning the list of active sprites, and display the first 8 active sprites after that. Then I update the "first not displayed" variable, so the next frame picks up where I left off. This results in gradual multiplexing as the scene gets busier. I whipped up a really crude demo just now to demonstrate. Buttons 0..7 on the two controllers will toggle 16 different sprites on/off. Once 9 go active, it starts multiplexing, but only one sprite gets left off of each screen, and the unlucky sprite rotates through the whole list. . ' Multiplexing demo with up to 16 sprites ' An inactive sprite sets x(i) = 0 ' ' Demo by J. Zbiciak ' Hereby placed in public domain DIM x(16), y(16), #a(16) first_not_displayed = 0 CLS ' Initially all sprites are off FOR i = 0 TO 15 x(i) = 0 NEXT i WHILE 1 WAIT ' Keys 0 .. 7 on each controller toggle which sprites are active IF bounce_counter = 0 THEN IF CONT1.KEY < 8 THEN snum = CONT1.KEY : GOSUB ToggleSprite IF CONT2.KEY < 8 THEN snum = 8 + CONT2.KEY : GOSUB ToggleSprite ELSE IF CONT.KEY = 12 THEN bounce_counter = bounce_counter - 1 END IF ' Multiplex loop: Scan starting at 'first not displayed' until up to ' 8 active sprites are found active = 0 FOR i = 0 to 15 ii = (i + first_not_displayed) AND 15 IF x(ii) <> 0 THEN SPRITE active, x(ii) + $200, y(ii) + $100, #a(ii) active = active + 1 IF active = 8 THEN first_not_displayed = (ii + 1) AND 15 EXIT FOR END IF END IF NEXT i WEND ToggleSprite: PROCEDURE bounce_counter = 5 IF x(snum) > 0 THEN x(snum) = 0 RETURN END IF x (snum) = 9 * snum + 9 y (snum) = 6 * snum + 6 #a(snum) = ($41 + snum) * 8 + 7 RETURN END Edited September 9, 2015 by intvnut 2 Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted September 9, 2015 Share Posted September 9, 2015 That's neat, intvnut. Do you mind if we add it to the SDK "Examples" folder? Quote Link to comment Share on other sites More sharing options...
intvnut Posted September 9, 2015 Share Posted September 9, 2015 That's neat, intvnut. Do you mind if we add it to the SDK "Examples" folder? Certainly! Be my guest! I'll leave it as an "exercise for the reader" to fold this approach into the Bats program that started the thread. Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted September 9, 2015 Share Posted September 9, 2015 Certainly! Be my guest! I'll leave it as an "exercise for the reader" to fold this approach into the Bats program that started the thread. Cool, thanks. 1 Quote Link to comment Share on other sites More sharing options...
+Rev Posted February 28, 2016 Share Posted February 28, 2016 How about a mode where we can shoot the bats? Quote Link to comment Share on other sites More sharing options...
+nanochess Posted February 28, 2016 Author Share Posted February 28, 2016 How about a mode where we can shoot the bats? Possible. It would look a lot like Galaxian Quote Link to comment Share on other sites More sharing options...
carlsson Posted February 28, 2016 Share Posted February 28, 2016 Indeed! The demo reminds me a bit of the second level in Arcadia by Imagine Software, for the ZX Spectrum, VIC-20, C64 and Dragon 32. The game is said to borrow from both Galaxian and Gorf. https://en.wikipedia.org/wiki/Arcadia_(video_game) Quote Link to comment Share on other sites More sharing options...
