Guest Posted September 5, 2015 Share Posted September 5, 2015 quick (stupid) question: i have a couple of 5v DC adapters that i want to wire to some spare 7-pin DINs the DINs have a length of cable attached - the adapters have the usual red/black running thru them - which will be live/neutral is there a way to identify which is live on the atari DIN without forcing it open? ie does the cable with the printed text running along it always be LIVE or GND? and if so, is it just a simple job of attaching RED (adapter) to ATARI DIN live and BLACK adapter to ATARI DIN GND? thanks Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted September 5, 2015 Share Posted September 5, 2015 http://mixinc.net/atari/pinouts/powerxle.htm Follow this and you can't go far wrong (ensure orientation is correct, of course). Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 5, 2015 Share Posted September 5, 2015 Live/Neutral only applies with AC - the DIN equipped Ataris are all DC. As per usual standards, black would be GND, red for the +5V. Not sure if it's the case for all PSUs but on my one (trapezoid shape vented from 1984 XL) there's actually only 2 pins wired up. But since it's a low current product that's all it needs. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 5, 2015 Share Posted September 5, 2015 (edited) that's great guys, just didn't want to do any damage i take it that that pin-out is the view from the front of the connector (ie the pins) and not the wiring from the rear of it Edited September 5, 2015 by Guest Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted September 5, 2015 Share Posted September 5, 2015 that's great guys, just didn't want to do any damage i take it that that pin-out is the view from the front of the connector (ie the pins) and not the wiring from the rear of it NO, the view is the connector on the rear of the computer. The view is the same as the solder side of the DIN plug where the wires attach. 1 Quote Link to comment Share on other sites More sharing options...
