mehguy Posted September 10, 2015 Share Posted September 10, 2015 im trying to install visualbb on windows 10, im trying to compile a project but it just comes up as a black and screen and when i try to make a play field, im unable to make a play field as it is all black. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 10, 2015 Share Posted September 10, 2015 Have you tried compiling a program from the bB page without making any changes to it? And if you are talking about having a black screen when using the playfield editor, take a look at this: randomterrain.com/atari-2600-memories-batari-basic-vbb.html#trouble_black_editor Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 10, 2015 Author Share Posted September 10, 2015 well now, im getting an error that goes something like this: could not locate default.bas.bin and could not compile. please make sure it was compiled correctly. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 10, 2015 Share Posted September 10, 2015 See if this helps: randomterrain.com/atari-2600-memories-batari-basic-vbb.html#trouble_defaultbasbin Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 11, 2015 Author Share Posted September 11, 2015 Well the thing is, the error doesnt come up all the time. it only comes up when it feels like it. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 11, 2015 Share Posted September 11, 2015 Do your folder names and file names have spaces in them? If they do, try using no spaces or using underscores instead of spaces and see if anything changes. For example, if your folders look something like this: C:\Atari2600\bb\projects\super_alien_poop and your latest .bas file is called something like this: super_alien_poop_2015y_09m_11d_1946t.bas You shouldn't have any problems. Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 13, 2015 Author Share Posted September 13, 2015 alright thanks. there doesnt seem to be any spaces. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 13, 2015 Share Posted September 13, 2015 Have you looked at the whole troubleshooting section and the "installation" section? http://www.randomterrain.com/atari-2600-memories-batari-basic-vbb.html#troubleshooting http://www.randomterrain.com/atari-2600-memories-batari-basic-vbb.html#install_vbb Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 14, 2015 Author Share Posted September 14, 2015 (edited) was I suppose to run the "install_win" batch file in batari basic? Edited September 14, 2015 by mehguy Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 14, 2015 Share Posted September 14, 2015 was I suppose to run the "install_win" batch file in batari basic? Read this: randomterrain.com/atari-2600-memories-batari-basic-commands.html#gettingstarted Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 14, 2015 Author Share Posted September 14, 2015 (edited) Read this: randomterrain.com/atari-2600-memories-batari-basic-commands.html#gettingstarted yeah when i click on the install_win file, it comes up with this error: ECHO is off. The bB installation batch file v1.1 ----------------------------------- Permanently setting the bB variable to: C:\Atari 2600\bB\bB.1.1d.reveng37 ERROR: Invalid syntax. Default option is not allowed more than '2' time(s). Type "SETX /?" for usage. Setting the bB variable failed. This batch file requires SETX, which comes with WinXP SP2, Windows Vista, and later versions of the Windows. You should obtain a copy of SETX and re-run this script, or set the bB variable manually. Edited September 14, 2015 by mehguy Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 14, 2015 Share Posted September 14, 2015 RevEng said "install_win.bat requires SETX, which comes with Windows XP SP2 and later versions of Windows. If you don't have SETX on the system the batch file will let you know and explain the situation." Also, about an earlier question, take a look at this: C:\Atari 2600\bB\bB.1.1d.reveng37 Do you see a space? I do. Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 15, 2015 Author Share Posted September 15, 2015 Oh lol, I fixed the space. So now, the win_bat file is displaying this: ECHO is off. The bB installation batch file v1.1 ----------------------------------- Permanently setting the bB variable to: C:\Atari2600\bB\bB.1.1d.reveng37 SUCCESS: Specified value was saved. Updating the user PATH variable so this bB directory is your primary SUCCESS: Specified value was saved. You should re-open vbb or any command-line windows so they take on the new bB variable value. You should re-run this batch file if you ever change the location of the bB directory. I suppose thats correct right? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 15, 2015 Share Posted September 15, 2015 If it's not bitching, it's correct. Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 15, 2015 Author Share Posted September 15, 2015 If it's not bitching, it's correct. So then its fine? Im still getting that default.bas error that I mentioned above. Granted, it only happens when there is in error in the command line. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 15, 2015 Share Posted September 15, 2015 So then its fine? Success usually means everything is fine. I'm still getting that default.bas error that I mentioned above. Granted, it only happens when there is in error in the command line. What kind of error in the command line? If you are using VbB, you don't have to mess around with command line stuff. It's all done for you. Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 19, 2015 Author Share Posted September 19, 2015 no, i mean as a syntax error. At the bottom of the window there is a tab for "Error". Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 19, 2015 Share Posted September 19, 2015 That's probably normal then if it's just screwed up BASIC code. Quote Link to comment Share on other sites More sharing options...
mehguy Posted September 20, 2015 Author Share Posted September 20, 2015 (edited) Ignore this reply. Edited September 20, 2015 by mehguy Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted September 20, 2015 Share Posted September 20, 2015 See if this video helps: youtube.com/watch?v=tsnP1PWpPas https://www.youtube.com/watch?v=tsnP1PWpPas That's for a playfield with a single foreground color and a single background color. Quote Link to comment Share on other sites More sharing options...
freshbrood Posted March 20, 2021 Share Posted March 20, 2021 v568 will immediatly close a couple seconds after loading. v554 works but it no longer remembers the path variable. Every time I open it, it thinks it's the first time. Running the winbat gives me a "missing SETX" error. This is driving me insane. I'm really hating Win10. It ran well at first. There also seem to be some odd issues with the score, where it no longer recognizes the default files as valid .asm files. I don't know for certain but I believe it's now causing programs that used to compile to crash now. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 20, 2021 Share Posted March 20, 2021 4 hours ago, freshbrood said: v568 will immediatly close a couple seconds after loading. v554 works but it no longer remembers the path variable. Every time I open it, it thinks it's the first time. Running the winbat gives me a "missing SETX" error. This is driving me insane. I'm really hating Win10. It ran well at first. There also seem to be some odd issues with the score, where it no longer recognizes the default files as valid .asm files. I don't know for certain but I believe it's now causing programs that used to compile to crash now. Are you following step 3? https://www.randomterrain.com/atari-2600-memories-batari-basic-vbb.html#install_vbb Quote Link to comment Share on other sites More sharing options...
+kisrael Posted March 21, 2021 Share Posted March 21, 2021 I feel at sometime people might be better served moving on to Atari Dev Studio. It's been a while since Visual BB has had an update? I recently updated my "batari BASIC kickstart" to explain how to set up and run Atari DeV Studio. https://alienbill.com/2600/bbkickstart/ I know I'm biased: I really love making tools for graphics and sound (https://alienbill.com/2600/ has 'em) and I think people are better served treating atari source code as text... or at least i could never get my head around what was going on in Visual BB. 1 Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted March 21, 2021 Share Posted March 21, 2021 10 hours ago, kisrael said: I know I'm biased: I really love making tools for graphics and sound (https://alienbill.com/2600/ has 'em) and I think people are better served treating atari source code as text... or at least i could never get my head around what was going on in Visual BB. I still use VbB on my Windows 10 computer. It has so many tools that Atari Dev Studio doesn't have so far. One thing that VbB has that I don't like is the stupid ancient built-in browser that you need to disable the first time you run VbB. After you get past that, it has a code editor, a sprite editor, a playfield editor, a score editor, a music and sound effects editor, a graphics converter, a Title Screen Kernel editor, and probably a few other things that I'm forgetting. It would also be hard to give up all of the code editor options in the right click menu that include Audit Variables, Audit Goto/Gosub, Find Next, Find Label, Identify Current Bank, Force Minimum Spacing, Flip Text, and Add Bookmark. 3 Quote Link to comment Share on other sites More sharing options...
+kisrael Posted March 21, 2021 Share Posted March 21, 2021 Yeah, I know it's a different approach to thinking about code that I don't quite "get". Since I've been programming for a long time, "the code is basically text" is very deeply intuitive to me. (I did use actual Visual Basic for a while, so I kind of understand the goal of making things "visual"... but it always has to get filtered down into something DASM can understand) I do worry a lot of people find VbB overwhelming, my self included, even after the broken browser thing. And of course, Mac users are out of luck. Still, ADS is so easy to install! I really would like to see Atari Dev Studio + my tools (and others) have full capabilities of VbB, it's great that you can list them out. Quote Link to comment Share on other sites More sharing options...
