AtariLeaf Posted September 22, 2015 Share Posted September 22, 2015 Anyone have any ideas, suggestions, or methods for straightening or fixing Atari game boxes that have crushed, bent, or smooshed? I've thought of putting pieces of styrofoam or something similar cut to the size of the box and stuck in the tops and bottoms to help them regain their shape over time. Or if they have tops or bottoms that don't want to stay closed, sitting them up straight on a desk or table and placing an object like a book on top for a day or so. I put 5 in between two book ends with a book on top so we'll see if it helps that. Just looking for any suggestions to help possibly regain their shape, even a little. Quote Link to comment Share on other sites More sharing options...
nofrills100 Posted September 22, 2015 Share Posted September 22, 2015 Buy some rigid card and make a marginally smaller box to slide inside which will prop up the original box into shape. If you have a bunch to make - then create a template so that you can pencil the cut lines to save time. 1 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted September 22, 2015 Share Posted September 22, 2015 Propping up sides or ends with something stiff sounds reasonable. Could glue card stock to the inside and maybe use Popsicle sticks for the really wrinkled spots? Never tried it myself, but seems like that would work too. 1 Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted September 22, 2015 Share Posted September 22, 2015 I've never done it, but I've heard of people unglueing the box at all seams and flatten it out, spray it and saturate with water, then let it dry between two flat boards. Then you can refold it, re-glue it and make it look almost new. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted September 22, 2015 Share Posted September 22, 2015 Flatten them and put them in between two slabs of heavy marble. 1 Quote Link to comment Share on other sites More sharing options...
Schitti Posted September 22, 2015 Share Posted September 22, 2015 unglueing or flatten the box. ironing works perfect for me. (not to hot. you have to find out the best setting with a old box.) important! place a cloth over it only recommendable with 100% cardbord boxes. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted September 22, 2015 Share Posted September 22, 2015 If you use the iron technique, practice on dummies, that are close to what you wish to correct. Quote Link to comment Share on other sites More sharing options...
AtariLeaf Posted September 22, 2015 Author Share Posted September 22, 2015 Thanks everyone. I'm going to try this, this weekend Quote Link to comment Share on other sites More sharing options...
moknbyrdx1 Posted November 8, 2018 Share Posted November 8, 2018 Anyone have any ideas, suggestions, or methods for straightening or fixing Atari game boxes that have crushed, bent, or smooshed? It's time consuming, but I used cardboard. Measured strips to slide into the gaps of the cartridge braces. It takes between four and five layers to match the depth of the Atari box. The good thing is, after you've finished, it feels like you could drive a car over it. HA. Quote Link to comment Share on other sites More sharing options...
+Muddyfunster Posted November 8, 2018 Share Posted November 8, 2018 unglueing or flatten the box. ironing works perfect for me. (not to hot. you have to find out the best setting with a old box.) important! place a cloth over it only recommendable with 100% cardbord boxes. This worked for me too, I had some really crushed boxed that I brought back to life this way. I found that if you are careful, you can significantly reduce the appearance of bad creasing and restore most of the shape. Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted November 9, 2018 Share Posted November 9, 2018 Please take a quick look at these two posts: http://atariage.com/forums/topic/275958-restored-diner-box/ http://atariage.com/forums/topic/260704-turbo-box-restoration/ Quote Link to comment Share on other sites More sharing options...
Video Posted November 10, 2018 Share Posted November 10, 2018 I take boxes apart, flatten them out, spray the cardstock side with water to relax the board and sandwich the flat box between layers of was papers and heavy books to dry. It works well for me and unless they actually have fold marks on the flat sides, they typically come out looking almost new, at least presentable. Quote Link to comment Share on other sites More sharing options...
