utri007 Posted August 21 Share Posted August 21 (edited) On 6/25/2017 at 7:18 AM, Bruce Abbott said: Aquaman requested a cable to connect Aquarius gamepads to my Micro-Expander. This turned out to be a bit trickier than I thought because the mini-expander schematic doesn't show which pins the port bits are connected to. I managed to figure it out from a photo of the PCB and a post by jaybird3rd. Then I 'just' had to map the Micro-expander's 20 pin connector pins to the D9 joystick socket. Micro-Expander 20 pin parallel Port Socket (external view) ========================================================== .---------------------- KEY -----------------------. | PB0 PB2 PB4 PB6 +5V PA7 PA5 PA3 PA1 GND | | 19 17 15 13 11 9 7 5 3 1 | | | | 20 18 16 14 12 10 8 6 4 2 | | GND PB1 PB3 PB5 PB7 +5V PA6 PA4 PA2 PA0 | '--------------------------------------------------' D9 Socket (external view) ========================= .----------------. \ 1 2 3 4 5 / \ 6 7 8 9 / '------------' D9 D9 20P 20P PORT A/B wire ATARI AQUARIUS JOY1 JOY2 RAD38910 color ====== ======== ==== ==== ======== ===== 2 DN 9 P5/DN 2 19 D0 Slate 4 RT 8 P1/RT 3 18 D1 White 1 UP 7 P13/UP 4 17 D2 Black 3 LT 6 P9/LT 5 16 D3 Brown - 5 P2-15 6 15 D4 Red 5 B IN 4 K4 7 14 D5 Orange 6 FIRE 3 K1 8 13 D6 Yellow 9 A IN 2 K2-6 9 12 D7 Green 8 GND 1 GND 1 20 GND Violet 7 +5V - 10 11 +5V Blue Aquarius Joypad #1 to Micro-Expander ==================================== Func D9 Color UEX 20P ==== == ====== ======= GND 1 Violet 1 K2-6 2 Green 9 K1 3 Yellow 8 K4 4 Orange 7 P2-15 5 Red 6 LEFT 6 Brown 5 UP 7 Black 4 RIGHT 8 White 3 DOWN 9 Slate 2 Atari Joystick to Micro-Expander ================================ Func D9 Color UEX 20P ==== == ====== ======= UP 1 Black 4 DOWN 2 Slate 2 LEFT 3 Brown 5 RIGHT 4 White 3 B IN 5 Green 9 FIRE 6 Yellow 8 +5V 7 Blue 10 GND 8 Violet 1 A IN 9 Green 7 Wire colors refer to the ribbon cable I used to make the adapter. The cable is reversed on each side of the 20 pin IDC plug, so the colors are the same for both joysticks. If you only have one gamepad or joystick then only the right-hand cable and D9 socket are required. Photos below show the adapter I made for Aquarius gamepads. An Atari joystick cable would be the same except for connections to the D9 sockets. I also made an Atari joystick adapter with the 20 pin plug and D9 socket connected via a small piece of matrix board. Using this I was able to play some games with my joystick, but Night Stalker needs 4 buttons to fire in different directions (perhaps it can be hacked to work with a single fire button?). Is this correct? Are those pin numbers for a male of female connectori? Edited August 21 by utri007 Quote Link to comment Share on other sites More sharing options...
