ascrnet Posted September 24, 2015 Share Posted September 24, 2015 (edited) Hi all, I'm trying to pass the bookstore IOMAC.LIB mac/65 operating in mads Original .TITLE "IOMAC.LIB -- OSS system I/O macros" .PAGE " Support Macros" .IF .NOT .DEF IOCB .ERROR "You must include SYSEQU.M65 ahead of this!!" .ENDIF ; ; These macros are called by the actual I/O macros ; to perform the rudimentary register load functions. ; ; ; MACRO: @CH ; ; Loads IOCB number (parameter 1) into X register. ; ; If parameter value is 0 to 7, immediate channel number ; is assumed. ; ; If parameter value is > 7 then a memory location ; is assumed to contain the channel number. ; .MACRO @CH .IF %1>7 LDA %1 ASL A ASL A ASL A ASL A TAX .ELSE LDX #%1*16 .ENDIF .ENDM ; ; ; MACRO: @CV ; ; Loads Constant or Value into accumultor (A-register) ; ; If value of parameter 1 is 0-255, @CV ; assumes it's an (immediate) constant. ; ; Otherwise the value is assumed to ; be a memory location (non-zero page). ; ; ; .MACRO @CV .IF %1<256 LDA #%1 .ELSE LDA %1 .ENDIF .ENDM ; ; ; ; ; MACRO: @FL ; ; @FL is used to establish a filespec (file name) ; ; If a literal string is passed, @FL will ; generate the string in line, jump ; around it, and place its address ; in the IOCB pointed to by the X-register. ; ; If a non-zero page label is passed ; the MACRO assumes it to be the label ; of a valid filespec and uses it instead. ; ; ; .MACRO @FL .IF %1<256 JMP *+%1+4 @F .BYTE %$1,0 LDA # <@F STA ICBADR,X LDA # >@F STA ICBADR+1,X .ELSE LDA # <%1 STA ICBADR,X LDA # >%1 STA ICBADR+1,X .ENDIF .ENDM .PAGE " XIO macro" ; ; MACRO: XIO ; ; FORM: XIO cmd,ch[,aux1,aux2][,filespec] ; ; ch is given as in the @CH macro ; cmd, aux1, aux2 are given as in the @CV macro ; filespec is given as in the @FL macro ; ; performs familiar XIO operations with/for OS/A+ ; ; If aux1 is given, aux2 must also be given ; If aux1 and aux2 are omitted, they are set to zero ; If the filespec is omitted, "S:" is assumed ; .MACRO XIO .IF %0<2 .OR %0>5 .ERROR "XIO: wrong number of arguments" .ELSE @CH %2 @CV %1 STA ICCOM,X ; COMMAND .IF %0>=4 @CV %3 STA ICAUX1,X @CV %4 STA ICAUX2,X .ELSE LDA #0 STA ICAUX1,X STA ICAUX2,X .ENDIF .IF %0=2 .OR %0=4 @FL "S:" .ELSE @@IO .= %0 @FL %$(@@IO) .ENDIF JSR CIO .ENDIF .ENDM .PAGE " OPEN macro" ; ; MACRO: OPEN ; ; FORM: OPEN ch,aux1,aux2,filespec ; ; ch is given as in the @CH macro ; aux1 and aux2 are given as in the @CV macro ; filespec is given as in the @FL macro ; ; will attempt to open the given file name on ; the given channel, using the open "modes" ; specified by aux1 and aux2 ; .MACRO OPEN .IF %0<>4 .ERROR "OPEN: wrong number of arguments" .ELSE .IF %4<256 XIO COPN,%1,%2,%3,%$4 .ELSE XIO COPN,%1,%2,%3,%4 .ENDIF .ENDIF .ENDM .PAGE " BGET and BPUT macros" ; ; MACROS: BGET and BPUT ; ; FORM: BGET ch,buf,len ; BPUT ch,buf,len ; .MACRO @GP2 @CH %1 LDA #%4 STA ICCOM,X LDA # <%2 STA ICBADR,X LDA # >%2 STA ICBADR+1,X LDA %3 STA ICBLEN,X LDA %3+1 STA ICBLEN+1,X JSR CIO .ENDM ; and actual value...never a memory address ; buf must be the address of an appropriate ; buffer in memory ; ; puts or gets length bytes to/from the ; specified buffer, uses binary read/write ; ; ; first: a common macro ; .MACRO @GP @CH %1 LDA #%4 STA ICCOM,X LDA # <%2 STA ICBADR,X LDA # >%2 STA ICBADR+1,X LDA # <%3 STA ICBLEN,X LDA # >%3 STA ICBLEN+1,X JSR CIO .ENDM ; .MACRO BGET .IF %0<>3 .ERROR "BGET: wrong number of parameters" .ELSE @GP2 %1,%2,%3,CGBINR .ENDIF .ENDM ; .MACRO BPUT .IF %0<>3 .ERROR "BPUT: wrong number of parameters" .ELSE @GP %1,%2,%3,CPBINR .ENDIF .ENDM ; .PAGE " PRINT macro" ; ; MACRO: PRINT ; ; FORM: PRINT ch[,buffer[,length]] ; ; ch is as given in @CH macro ; if no buffer, prints just a RETURN ; if no length given, 255 assumed ; ; used to print text. To print text without RETURN, ; length must be given. See OS/A+ manual ; ; EXCEPTION: second parameter may be a literal ; string (e.g., PRINT 0,"test"), in which ; case the length (if given) is ignored. ; .MACRO PRINT .IF %0<1 .OR %0>3 .ERROR "PRINT: wrong number of parameters" .ELSE .IF %0>1 .IF %2<128 JMP *+4+%2 @IO .BYTE %$2,$9B @GP %1,@IO,%2+1,CPTXTR .ELSE .IF %0=2 @GP %1,%2,255,CPTXTR .ELSE @GP %1,%2,%3,CPTXTR .ENDIF .ENDIF .ELSE JMP *+4 @IO .BYTE $9B @GP %1,@IO,1,CPTXTR .ENDIF .ENDIF .ENDM ; .PAGE " INPUT macro" ; ; MACRO: INPUT ; ; FORM: INPUT ch,buf,len ; ; ch is given as in the @CH macro ; buf MUST be a proper buffer address ; len may be omitted, in which case 255 is assumed ; ; gets a line of text input to the given ; buffer, maximum of length bytes ; .MACRO INPUT .IF %0<2 .OR %0>3 .ERROR "INPUT: wrong number of parameters" .ELSE .IF %0=2 @GP %1,%2,255,CGTXTR .ELSE @GP %1,%2,%3,CGTXTR .ENDIF .ENDIF .ENDM .PAGE " CLOSE macro" ; ; MACRO: CLOSE ; ; FORM: CLOSE ch ; ; ch is given as in the @CH macro ; ; closes channel ch ; .MACRO CLOSE .IF %0<>1 .ERROR "CLOSE: wrong number of parameters" .ELSE @CH %1 LDA #CCLOSE STA ICCOM,X JSR CIO .ENDIF .ENDM ; ;;;;;;;;;;; END OF IOMAC.LIB ;;;;;;;;;;;; ; Modified ; .TITLE "IOMAC.LIB -- OSS system I/O macros" ; .PAGE " Support Macros" .IF .NOT .DEF IOCB .ERROR "You must include SYSEQU.M65 ahead of this!!" .ENDIF ; ; These macros are called by the actual I/O macros ; to perform the rudimentary register load functions. ; ; ; MACRO: @CH ; ; Loads IOCB number (parameter 1) into X register. ; ; If parameter value is 0 to 7, immediate channel number ; is assumed. ; ; If parameter value is > 7 then a memory location ; is assumed to contain the channel number. ; .MACRO @CH .IF :1>7 LDA :1 ASL A ASL A ASL A ASL A TAX .ELSE LDX #:1*16 .ENDIF .ENDM ; ; ; MACRO: @CV ; ; Loads Constant or Value into accumultor (A-register) ; ; If value of parameter 1 is 0-255, @CV ; assumes it's an (immediate) constant. ; ; Otherwise the value is assumed to ; be a memory location (non-zero page). ; ; ; .MACRO @CV .IF :1<256 LDA #:1 .ELSE LDA :1 .ENDIF .ENDM ; ; ; ; ; MACRO: @FL ; ; @FL is used to establish a filespec (file name) ; ; If a literal string is passed, @FL will ; generate the string in line, jump ; around it, and place its address ; in the IOCB pointed to by the X-register. ; ; If a non-zero page label is passed ; the MACRO assumes it to be the label ; of a valid filespec and uses it instead. ; ; ; .MACRO @FL .IF :1<256 JMP *+:1+4 @F .BYTE :1,0 LDA # <@F STA ICBADR,X LDA # >@F STA ICBADR+1,X .ELSE LDA # <:1 STA ICBADR,X LDA # >:1 STA ICBADR+1,X .ENDIF .ENDM ; .PAGE " XIO macro" ; ; MACRO: XIO ; ; FORM: XIO cmd,ch[,aux1,aux2][,filespec] ; ; ch is given as in the @CH macro ; cmd, aux1, aux2 are given as in the @CV macro ; filespec is given as in the @FL macro ; ; performs familiar XIO operations with/for OS/A+ ; ; If aux1 is given, aux2 must also be given ; If aux1 and aux2 are omitted, they are set to zero ; If the filespec is omitted, "S:" is assumed ; .MACRO XIO .IF :0<2 .OR :0>5 .ERROR "XIO: wrong number of arguments" .ELSE @CH :2 @CV :1 STA ICCOM,X ; COMMAND .IF :0>=4 @CV :3 STA ICAUX1,X @CV :4 STA ICAUX2,X .ELSE LDA #0 STA ICAUX1,X STA ICAUX2,X .ENDIF .IF :0=2 .OR :0=4 @FL "S:" .ELSE @@IO = :0 @FL @@IO .ENDIF JSR CIO .ENDIF .ENDM ; .PAGE " OPEN macro" ; ; MACRO: OPEN ; ; FORM: OPEN ch,aux1,aux2,filespec ; ; ch is given as in the @CH macro ; aux1 and aux2 are given as in the @CV macro ; filespec is given as in the @FL macro ; ; will attempt to open the given file name on ; the given channel, using the open "modes" ; specified by aux1 and aux2 ; .MACRO OPEN .IF :0<>4 .ERROR "OPEN: wrong number of arguments" .ELSE .IF :4<256 XIO COPN,:1,:2,:3,:$4 .ELSE XIO COPN,:1,:2,:3,:4 .ENDIF .ENDIF .ENDM ; .PAGE " BGET and BPUT macros" ; ; MACROS: BGET and BPUT ; ; FORM: BGET ch,buf,len ; BPUT ch,buf,len ; .MACRO @GP2 @CH :1 LDA #:4 STA ICCOM,X LDA # <:2 STA ICBADR,X LDA # >:2 STA ICBADR+1,X LDA :3 STA ICBLEN,X LDA :3+1 STA ICBLEN+1,X JSR CIO .ENDM ; and actual value...never a memory address ; buf must be the address of an appropriate ; buffer in memory ; ; puts or gets length bytes to/from the ; specified buffer, uses binary read/write ; ; ; first: a common macro ; .MACRO @GP @CH :1 LDA #:4 STA ICCOM,X LDA # <:2 STA ICBADR,X LDA # >:2 STA ICBADR+1,X LDA # <:3 STA ICBLEN,X LDA # >:3 STA ICBLEN+1,X JSR CIO .ENDM ; .MACRO BGET .IF :0<>3 .ERROR "BGET: wrong number of parameters" .ELSE @GP2 :1,:2,:3,CGBINR .ENDIF .ENDM ; .MACRO BPUT .IF :0<>3 .ERROR "BPUT: wrong number of parameters" .ELSE @GP :1,:2,:3,CPBINR .ENDIF .ENDM ; ; .PAGE " PRINT macro" ; ; MACRO: PRINT ; ; FORM: PRINT ch[,buffer[,length]] ; ; ch is as given in @CH macro ; if no buffer, prints just a RETURN ; if no length given, 255 assumed ; ; used to print text. To print text without RETURN, ; length must be given. See OS/A+ manual ; ; EXCEPTION: second parameter may be a literal ; string (e.g., PRINT 0,"test"), in which ; case the length (if given) is ignored. ; .MACRO PRINT .IF :0<1 .OR :0>3 .ERROR "PRINT: wrong number of parameters" .ELSE .IF :0>1 .IF :2<128 JMP *+4+:2 @IO .BYTE :$2,$9B @GP :1,@IO,:2+1,CPTXTR .ELSE .IF :0=2 @GP :1,:2,255,CPTXTR .ELSE @GP :1,:2,:3,CPTXTR .ENDIF .ENDIF .ELSE JMP *+4 @IO .BYTE $9B @GP :1,@IO,1,CPTXTR .ENDIF .ENDIF .ENDM ; ; .PAGE " INPUT macro" ; ; MACRO: INPUT ; ; FORM: INPUT ch,buf,len ; ; ch is given as in the @CH macro ; buf MUST be a proper buffer address ; len may be omitted, in which case 255 is assumed ; ; gets a line of text input to the given ; buffer, maximum of length bytes ; .MACRO INPUT .IF :0<2 .OR :0>3 .ERROR "INPUT: wrong number of parameters" .ELSE .IF :0=2 @GP :1,:2,255,CGTXTR .ELSE @GP :1,:2,:3,CGTXTR .ENDIF .ENDIF .ENDM ; .PAGE " CLOSE macro" ; ; MACRO: CLOSE ; ; FORM: CLOSE ch ; ; ch is given as in the @CH macro ; ; closes channel ch ; .MACRO CLOSE .IF :0<>1 .ERROR "CLOSE: wrong number of parameters" .ELSE @CH :1 LDA #CCLOSE STA ICCOM,X JSR CIO .ENDIF .ENDM ; ;;;;;;;;;;; END OF IOMAC.LIB ;;;;;;;;;;;; ; As I have some errors, for example OPEN 1,6,0,"D:*.*" .IF D:*.*<256 IOMAC.asm (148) ERROR: Undeclared label D (BANK=0) It is taking the parameters differently. Any idea how I can fix?regards Edited September 24, 2015 by ascrnet 1 Quote Link to comment Share on other sites More sharing options...
tebe Posted October 28, 2015 Share Posted October 28, 2015 (edited) remove .IF .IF :4<256 XIO COPN,:1,:2,:3,:$4 .ELSE XIO COPN,:1,:2,:3,:4 .ENDIF = XIO COPN,:1,:2,:3,:4 Edited October 28, 2015 by tebe 1 Quote Link to comment Share on other sites More sharing options...
ascrnet Posted November 2, 2015 Author Share Posted November 2, 2015 remove .IF .IF :4<256 XIO COPN,:1,:2,:3,:$4 .ELSE XIO COPN,:1,:2,:3,:4 .ENDIF = XIO COPN,:1,:2,:3,:4 Hi tebe, thank you very much for your answer now pass without problem. Now I have a new problem with the print macro .MACRO PRINT .IF :0<1 .OR :0>3 .ERROR "PRINT: wrong number of parameters" .ELSE .IF :0>1 .IF :2<128 JMP *+4+:2 @IO .BYTE :$2,$9B @GP :1,@IO,:2+1,CPTXTR .ELSE .IF :0=2 @GP :1,:2,255,CPTXTR .ELSE @GP :1,:2,:3,CPTXTR .ENDIF .ENDIF .ELSE JMP *+4 @IO .BYTE $9B @GP :1,@IO,1,CPTXTR .ENDIF .ENDIF .ENDM by eliminating the previous time equal if not now do not like the JMP *+4+:2 regards 2 Quote Link to comment Share on other sites More sharing options...
Atari_Force Posted December 22, 2015 Share Posted December 22, 2015 (edited) This is very interesting. This can be very useful for me. Edited December 22, 2015 by Atari_Force Quote Link to comment Share on other sites More sharing options...
dogdark Posted August 25, 2022 Share Posted August 25, 2022 (edited) Is there any workaround for JMP *+4+:2 Edited August 25, 2022 by dogdark Quote Link to comment Share on other sites More sharing options...
