palmheads Posted September 27, 2015 Share Posted September 27, 2015 Hi all Is it possible to load a EA5 Program file (Editor/Assembler option 5) from DSK using the mini-memory module? Am assuming its not possible. cheers Daryn Quote Link to comment Share on other sites More sharing options...
Shift838 Posted September 27, 2015 Share Posted September 27, 2015 Hi all Is it possible to load a EA5 Program file (Editor/Assembler option 5) from DSK using the mini-memory module? Am assuming its not possible. cheers Daryn I have never seen it done. You can load EA #5 via Extended Basic though. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted September 27, 2015 Share Posted September 27, 2015 Hi all Is it possible to load a EA5 Program file (Editor/Assembler option 5) from DSK using the mini-memory module? Am assuming its not possible. cheers Daryn There's a playground loader for this.. Gazoo was using it for his updater for xb2.7.. should work with any cartridge installed to load an ea5.. http://atariage.com/forums/topic/218904-playground/page-4?do=findComment&comment=3254554is his grom loader post Quote Link to comment Share on other sites More sharing options...
palmheads Posted September 30, 2015 Author Share Posted September 30, 2015 Found one lads! See the attached DSK - works great!!! MINI -Todd Kaplan E/A5 (Program Image) file loader that allows programs that run under Editor/Assembler Option #5 to also be launched from Mini Memory. >Select MM LOAD & RUN >Type in DSK1.MINI, >Type in the path and program to RUN. MMProgs.dsk 2 Quote Link to comment Share on other sites More sharing options...
Opry99er Posted September 30, 2015 Share Posted September 30, 2015 Hey, that's pretty cool! Quote Link to comment Share on other sites More sharing options...
palmheads Posted September 30, 2015 Author Share Posted September 30, 2015 (edited) Hey, that's pretty cool! Yeah, was able to load the mini memory EA5 loader, then load PARSEC from another DSK using js99er. Will try it for real in the weekend with my real TI, mini-memory module & nanoPEB! Edited September 30, 2015 by palmheads 2 Quote Link to comment Share on other sites More sharing options...
palmheads Posted October 1, 2015 Author Share Posted October 1, 2015 Yeah, was able to load the mini memory EA5 loader, then load PARSEC from another DSK using js99er. Will try it for real in the weekend with my real TI, mini-memory module & nanoPEB! Tried it on my physical TI - worked! Mini memory now fits all my needs. What a damn cool module! 3 Quote Link to comment Share on other sites More sharing options...
