three2em Posted September 28, 2015 Share Posted September 28, 2015 (edited) Hey all, I'm new here, and have been getting along well reading through the massive information on this forum. Thanks! I'm building a game for the Atari 2600 and have accomplished quite a lot in one weekend considering I haven't programmed in ASM in over a decade. I'm trying to implement a 6 digit score, and while I've been able to find a lot of information about how to, and I understand the VDELPx method, the only thing I can't figure out is how to position the Players 8 pixels apart. What I'm currently doing is running several NOPs until the P0 sprites work, then doing a call to RESP0, then the very next line of code doing a RESP1. This gets me very close, as I'm able to display all 6 digits, but P0 and P1 are 9 pixels apart rather than 8, so the alignment is just off. All the algorithms I can find online only show the loop to display 6 sprites in a row, but all assume that the Players have been positioned correctly. Any help would be great. Thanks Quick Edit: Figured some code might help: BeginScore ; Wait X cycles then reset P0/P1 NOP ; 2 (2) NOP ; 2 (4) NOP ; 2 (6) NOP ; 2 ( NOP ; 2 (10) NOP ; 2 (12) NOP ; 2 (14) NOP ; 2 (16) NOP ; 2 (18) NOP ; 2 (20) NOP ; 2 (22) NOP ; 2 (24) NOP ; 2 (26) NOP ; 2 (28) NOP ; 2 (30) NOP ; 2 (32) STA RESP0 STA RESP1 LDY #7 STY temp ScoreLoop LDY temp LDA (scoreDigits+$A),Y ; 6th STA temp2 STA WSYNC LDA (scoreDigits),Y ; 1st STA GRP0 LDA (scoreDigits+$2),Y ; 2nd STA GRP1 LDA (scoreDigits+$4),Y ; 3rd STA GRP0 LDA (scoreDigits+$,Y ; 5th TAX LDA (scoreDigits+$6),Y ; 4th LDY temp2 NOP STA GRP1 ; 4th STX GRP0 ; 5th STY GRP1 ; 6th STA GRP0 DEC temp BPL ScoreLoop Edited September 28, 2015 by three2em Quote Link to comment Share on other sites More sharing options...
PolygonPizza Posted September 28, 2015 Share Posted September 28, 2015 You need to do a fine-grain adjustment using HMP1 and HMOVE. Write #$10 into HMP1, and then call HMOVE. So lda #$10, then sta HMP1, then on the next line (after sta WSYNC), call HMOVE. If you need to avoid black bars on the left of the screen, you can write #$90 into HMP1 and call HMOVE starting on cycle 70 or 71. Hope this answers your question. 1 Quote Link to comment Share on other sites More sharing options...
three2em Posted September 28, 2015 Author Share Posted September 28, 2015 (edited) Thanks for the quick response PolygonPizza. I didn't get it at first, but then after I coded what you recommended, it finally clicked in how all this repositioning stuff works. Thanks! Edit: Forgot the code again. This is what works for me, hopefully it will help others. BeginScore ; Wait X cycles then reset P0/P1 LDA #3 ; 2 (2) STA NUSIZ0 ; 3 (5) STA NUSIZ1 ; 3 ( LDA #1 ; 2 (10) STA VDELP0 ; 3 (13) STA VDELP1 ; 3 (16) LDA #0 ; 2 (18) STA COLUBK ; 3 (21) LDA #CSCORE ; 2 (23) STA COLUP0 ; 3 (26) STA COLUP1 ; 3 (29) NOP ; 2 (31) NOP ; 2 (33) STA RESP0 STA RESP1 LDA #%11110000 STA HMP1 LDA #%11100000 STA HMP0 ; Shift scores slightly to the center of the screen STA WSYNC STA WSYNC STA WSYNC STA WSYNC ; Additional WSYNCs for vertical alignment, only one necessary for HMOVE STA WSYNC STA HMOVE LDY #7 STY temp ScoreLoop LDY temp LDA (scoreDigits+$A),Y ; 6th STA temp2 STA WSYNC ; Twelve Cycles to spare when WSYNC is called LDA (scoreDigits),Y ; 1st STA GRP0 LDA (scoreDigits+$2),Y ; 2nd STA GRP1 LDA (scoreDigits+$4),Y ; 3rd STA GRP0 LDA (scoreDigits+$,Y ; 5th TAX LDA (scoreDigits+$6),Y ; 4th LDY temp2 NOP STA GRP1 ; 4th STX GRP0 ; 5th STY GRP1 ; 6th STA GRP0 DEC temp BPL ScoreLoop Edited September 28, 2015 by three2em Quote Link to comment Share on other sites More sharing options...
iesposta Posted September 28, 2015 Share Posted September 28, 2015 (edited) You are already way beyond my basic programming ability. Don't you just set P0 and P1 NUSIZ0, NUSIZ1 for 3 copies close, and update the data during display? Three copies close side-by-side line up to 48 pixels wide. Oh, I see you are doing that. I first saw reset player and thought you were just starting over without the hardware copy. Edited September 28, 2015 by iesposta Quote Link to comment Share on other sites More sharing options...
