JasonlikesINTV Posted October 8, 2015 Share Posted October 8, 2015 3 Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted October 8, 2015 Share Posted October 8, 2015 Looks reasonable to me. :-P Quote Link to comment Share on other sites More sharing options...
+doctorclu Posted October 8, 2015 Share Posted October 8, 2015 Ok what I don't get, while I'll like this a bunch, is why 10 hits in you get a spray effect rather than the one off? Quote Link to comment Share on other sites More sharing options...
JasonlikesINTV Posted October 8, 2015 Author Share Posted October 8, 2015 Each hit knocks loose a new ball. It falls to the bottom, then takes off. At one point one creates a gap that gets filled/attacked pretty quickly. All hell breaks loose. Or did I misunderstand the question? 1 Quote Link to comment Share on other sites More sharing options...
+5-11under Posted October 8, 2015 Share Posted October 8, 2015 It looks like I won! Quote Link to comment Share on other sites More sharing options...
JasonlikesINTV Posted October 8, 2015 Author Share Posted October 8, 2015 It looks like I won! I think you win a copy of Piggy Bank. Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted October 8, 2015 Share Posted October 8, 2015 This looks wild, wow! Quote Link to comment Share on other sites More sharing options...
+doctorclu Posted October 8, 2015 Share Posted October 8, 2015 (edited) Each hit knocks loose a new ball. It falls to the bottom, then takes off. At one point one creates a gap that gets filled/attacked pretty quickly. All hell breaks loose. Or did I misunderstand the question? About the 12th hit it goes from a hit knocking off a single brick to knocking off a cluster of bricks. That part doesn't make sense. However I can understand if this demonstration wanted to speed things up a bit. Edited October 8, 2015 by doctorclu Quote Link to comment Share on other sites More sharing options...
JasonlikesINTV Posted October 8, 2015 Author Share Posted October 8, 2015 Ahh, maybe it's a power-up that can go through bricks instead of deflecting 1 Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted October 8, 2015 Share Posted October 8, 2015 About the 12th hit it goes from a hit knocking off a single brick to knocking off a cluster of bricks. That part doesn't make sense. However I can understand if this demonstration wanted to speed things up a bit. There was already a gap in that spot, so entering the gap diagonally causes the ball to bounce against the other blocks surrounding it. This releases one ball per block hit, opening the gap even more, which causes the original ball to "burrow" through the wall, releasing more blocks as it goes through the tunnel. -dZ. 1 Quote Link to comment Share on other sites More sharing options...
freewheel Posted October 8, 2015 Share Posted October 8, 2015 I started programming a port over to the Intellivision, but ran out of MOBs. 3 Quote Link to comment Share on other sites More sharing options...
Intymike Posted October 8, 2015 Share Posted October 8, 2015 Looks like a nuclear chain reaction. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted October 8, 2015 Share Posted October 8, 2015 Imagine playing this with one ball and a normal size paddle bar. It would take forever to beat one level. Quote Link to comment Share on other sites More sharing options...
+doctorclu Posted October 8, 2015 Share Posted October 8, 2015 There was already a gap in that spot, so entering the gap diagonally causes the ball to bounce against the other blocks surrounding it. This releases one ball per block hit, opening the gap even more, which causes the original ball to "burrow" through the wall, releasing more blocks as it goes through the tunnel. -dZ. Ahh, maybe it's a power-up that can go through bricks instead of deflecting I think the powerup is more likely. Eventually you get horizontal lines in the wall. Quote Link to comment Share on other sites More sharing options...
+5-11under Posted October 8, 2015 Share Posted October 8, 2015 I think the powerup is more likely. Eventually you get horizontal lines in the wall. No, it's what dZ said. You get the effect in most breakout games where it can bounce internally. However, in this "game", every hit adds another ball, so the effect is compounded. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted October 8, 2015 Share Posted October 8, 2015 (edited) I think the powerup is more likely. Eventually you get horizontal lines in the wall. The horizontal line is a side effect/glitch done with one ball. It happens in brickout for the intellivision with one ball as well. Edited October 8, 2015 by pimpmaul69 Quote Link to comment Share on other sites More sharing options...
