rgflores Posted October 18, 2015 Share Posted October 18, 2015 Hello I downloaded Kat5200 emulator, installed, put centipede rom inside Kat5200 main directory and comes a message "error loading bios image". Troubleshooting says it´s because I don´t have bios image. Ok, downloaded Atari 5200 bios from atari age (5200.zip), and put the bios inside Kat5200 directory main again, but the error message continues. Any idea? Thank you. Quote Link to comment Share on other sites More sharing options...
jblenkle Posted October 18, 2015 Share Posted October 18, 2015 You have to tell the emulator where to find the BIOS and other files. When you run the program, press ESC and it will bring up the menu. Click on MACHINE and then BIOS FILES and enter in where the BIOS file is. Hello I downloaded Kat5200 emulator, installed, put centipede rom inside Kat5200 main directory and comes a message "error loading bios image". Troubleshooting says it´s because I don´t have bios image. Ok, downloaded Atari 5200 bios from atari age (5200.zip), and put the bios inside Kat5200 directory main again, but the error message continues. Any idea? Thank you. Quote Link to comment Share on other sites More sharing options...
rgflores Posted October 21, 2015 Author Share Posted October 21, 2015 Thanks for your answer I have it working now. The only issue is that looks like it does not recognizing the joystick. Quote Link to comment Share on other sites More sharing options...
jblenkle Posted October 21, 2015 Share Posted October 21, 2015 Same deal...you have to configure the joystick too... It's under OPTIONS...then INPUT... Thanks for your answer I have it working now. The only issue is that looks like it does not recognizing the joystick. Quote Link to comment Share on other sites More sharing options...
