aftyde Posted November 8, 2015 Share Posted November 8, 2015 (edited) Hi All, Have a TI controller with the 80 track mod in it and 2 Lotharek drives. Trying to sort out which images to run / get predictable working diskette images built would be so much easier if I knew which sets of roms were in the controller. I think I have 80 track DSSD on 1 and 2. I can read and write to diskette images but not format them... Any ideas??? Is it possible to dump the roms without a programmer and compare? Cheers, Arthur... --- This is a modification for the TI Disk Controller card which enables the use of 80 track drives for a total of 1440 sectors per 80 track drive. There are several configurations available. Please distribute this archive freely. Tony Knerr 07-15-01 The files in this archive are as follows: readme.txt This file. 80trackti.doc Instructions for installing 80 track eproms on the TI disk controller card. 80t1r1.bin Replacement for U26, 80 track drives on 2&3, 40 track on drive 1. 80t1r2.bin Replacement for U27, partner to 80t1r1.bin. 80t3r1.bin Replacement for U26, 80 track drives on 1&2, 40 track on drive 3. 80t3r2.bin Replacement for U27, partner to 80t3r1.bin. 40tk1.bin Original TI rom U26. 40tk2.bin Original TI rom U27. *end* Edited November 8, 2015 by aftyde Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted November 8, 2015 Share Posted November 8, 2015 hmm, without an eprommer, I would use one 80-track-drive with a 80T/DSSD-disk (maybe a HxC with 80T/DSSD-HFE-mounted, does not matter) and jumper this drive beginning from 1 up to 3, with trying to format an 80track-DSSD-disk in each step. The DSKs configured with only 40tracks will bring up an error, the one configured with 80 track will pass this normally. But this is trial-and-error only, of course Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted November 8, 2015 Share Posted November 8, 2015 I'm using a Gotek. With firmware from the same guy as the Lotharek drives. Formatting has never worked for me. So I use TiImageTool java app on PC to create a blank sector image, then I convert that to hfe with the hxc desktop software. Once there, TI software can read and write just fine, and rename the disk too. There was a thread on the hxc2001 forums about formatting on TI that never seemed to be resolved. Does anyone if formatting on the Lotharek drives works on TI now? Somewhere we must have a DSR rom image dumper? If aftyde had that, the image could be diffed against each of the available mod images. I'm assuming you already opened up the controller board and looks at the labels on the eproms? I'm pretty sure mine came labelled. ( I didn't burn them myself ) 1 Quote Link to comment Share on other sites More sharing options...
aftyde Posted November 14, 2015 Author Share Posted November 14, 2015 I can format disks on the Lotharek with my Myarc controller - DS/DD 80 track - no issues. Can't seem to make that work with a DSSD 80 Track TI controller. Otherwise, everything else works just fine. Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted November 14, 2015 Share Posted November 14, 2015 hmm, so you have an 80track-modded DDCC-1 and come to 2880 sectors and 720 KB ? (have this too Can (or did you?) try to use (read, write and then at last format) this HFE here with the DS/SD-80T-Controller: (But only if HFE like this was not part of your test up to here) 001_360K_80T_DSSD_E.dsk Quote Link to comment Share on other sites More sharing options...
aftyde Posted November 14, 2015 Author Share Posted November 14, 2015 Downloaded it - can save, delete files - can also rename the disk. John Birdwalls disk util 4.2 will verify all sectors. (0-059F) No 3rd party util with format the file, and Disk Manager 2.1 comes back with a Disk Error 43. (whatever that means) Quote Link to comment Share on other sites More sharing options...
aftyde Posted November 14, 2015 Author Share Posted November 14, 2015 Yep - love the Myarc 80 track DDCC-1, keep hoping someone will reverse engineer a SCSI card or decent floppy controller. Or even better - put a small Linux machine on the expansion bus that does everything... 1 Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted November 14, 2015 Share Posted November 14, 2015 Hmm, if we can believe on this errorlist here below, it means "Lost data on print" (=write?) Maybe you try this DiskMan here as it is a bit newer ? (From a 2nd floppy in HxC, if you have configured it this way) DM1000v61.dsk ErrorCodes (from DM2.0 I think): Quote Link to comment Share on other sites More sharing options...
aftyde Posted November 15, 2015 Author Share Posted November 15, 2015 I'll give it a shot - I have two disk controllers and have the same issue, and have a real SSSD drive - all the same. Have swapped the console - only thing left is the firehose. I'll give it a try! 1 Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted November 15, 2015 Share Posted November 15, 2015 Yep - love the Myarc 80 track DDCC-1 Sounds nice. I was hoping to get a cloned version once, but so much time has gone by I've given up on it. Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted November 15, 2015 Share Posted November 15, 2015 I'll give it a shot - I have two disk controllers and have the same issue, and have a real SSSD drive - all the same. Have swapped the console - only thing left is the firehose. I'll give it a try! hmm, 1. so there are 2 x 80track-modded TI-controllers with that problem ? 2. and the MyArc-80T is NOT involved in the problem ? 3. So, the very only problem here is that formatting does not work ? As I never have formatted .HFEs - better: the DSKs "inside" - on the TI, I should try that here for a first time....maybe this does not work in general with HxC, as Jedimatt described.... And yes, I remember this thread on the HxC-forum, but I thought it was "solved" with a new firmware froom Lotharek... I´ll revise that too, next days. Quote Link to comment Share on other sites More sharing options...
aftyde Posted November 16, 2015 Author Share Posted November 16, 2015 (edited) I have formatted disks on the Myarc controller - no problem. Yes, I have two modd'd TI controllers. One with the Guion mod, the other with th 80 track mod. Both will not format the Lotharek, or even a SSSD floppy in a physical TI floppy drive. (DSK1 and DSK2 are both Lotharek emulators, DSK3 is a genuine external TI SSSD Shugart drive.) When I had back to Manila in Dec - I am going to bring some of the .HFE files to see if I can format them with the Myarc. Edited November 16, 2015 by aftyde Quote Link to comment Share on other sites More sharing options...
