LEDartist Posted November 10, 2015 Share Posted November 10, 2015 I'm looking to find the first/earliest handheld devices that shipped with an LED backlight. More than likely, they would have had a lightguide. Is anyone aware of which were the earliest products and what was the year they were introduced? Thanks! Quote Link to comment Share on other sites More sharing options...
7800fan Posted November 10, 2015 Share Posted November 10, 2015 Atari, Sega, and NEC never had any product with built in LED backlight. Nintendo was the first when they released Gameboy SP and Nintendo DS. Sony followed along with PSP. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 10, 2015 Share Posted November 10, 2015 (edited) White leds didn't come to the market until the very late 90's Edited November 10, 2015 by Osgeld Quote Link to comment Share on other sites More sharing options...
LEDartist Posted November 11, 2015 Author Share Posted November 11, 2015 The white LEDs opened up everything to LED backlighting and color backlighting, but prior to that one could use monochrome LEDs (typically green) for backlighting or frontlighting a small display. Is anyone aware of monochrome LEDs being used in small devices prior to the white LEDs of the late 1990's? I believe some industrial products used small LCDs that were backlit/frontlit by monochrome LEDs well before the mid-1990's. Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted November 11, 2015 Share Posted November 11, 2015 (edited) As far as I know, most or all devices did not use LEDs for the lighting(front or back). I'm not completely sure why, but my guess would be that it would be hard to defuse the light of the LEDs in those days. LED's were a lot more primitive and less efficiënt. Often the angle of the light was too limited making it hard to fully lighten a surface from the sides. And lighting from the back(which to my knowlage was never done in those days), would result in spots. I'm sorry... but I think your quest for such devices will end up in failure. As far as backlighting goes without leds, the first one that comes to my mind is the game-gear. But I don't think you want that. Edited November 11, 2015 by DrWho198 Quote Link to comment Share on other sites More sharing options...
7800fan Posted November 11, 2015 Share Posted November 11, 2015 Gas station pump and cash registers did use back lighting LED with the LCD. Usually green or orange, never red as it's often too dark. There may have been handhelds with red, amber, or green LED but I know of only one and they used incandescent bulb rather than LED. Most fixed game handheld were without internal light. Premium digital watches used indiglo (or other type of electroluminescent) which had bright white-green shade but had limited half-life of a few hundred hours. That is, they start to lose brightness over use to about half brightness after some hundred hours, down to 1/4 remaining after another few hundred, etc. Cheaper watches used regular bulb. I am not aware of any handheld LCD games that used electroluminescent. It wasn't power efficient, requiring fairly high AC power to drive and sucked battery more the larger the display got. Like white LED, blue didn't come into wide use until late 90's when the inventor finally developed cheap and stable element that makes blue light work. White LED are actually blue LED with yellow filter. I do remember some 10 years ago many cheap handheld system used white LED like Coleco systems and other systems. Cell phone, PDA, and other devices started using white LED for backlighting. Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted November 11, 2015 Share Posted November 11, 2015 (edited) I guess it all comes down to what LEDartist is looking for. If the devices need to be from the previous millenium then chances are small to find anything game related (besides game watches, which only had lighting when you held the button). And as you were saying they did not use leds in watches. Edited November 11, 2015 by DrWho198 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 11, 2015 Share Posted November 11, 2015 (edited) White LED are actually blue LED with yellow filter. not to nitpick but there's white emitting LED's (gallium nitride which can also produce blue, green and uv depending) and then there's phosphor converted which are more UV than blue Edited November 11, 2015 by Osgeld Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted November 11, 2015 Share Posted November 11, 2015 We were talking about LED's from the 80's and early 90's. True white LED's were invented later on. LED's have come a long way the past 30 years. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 11, 2015 Share Posted November 11, 2015 I know, white LEDs didnt exist 30 years ago the only thing you may see is some backlights on text LCD screens like on machinery from back then, thought we moved on Quote Link to comment Share on other sites More sharing options...
LEDartist Posted November 11, 2015 Author Share Posted November 11, 2015 Thank you everyone for your comments. From your comments, it doesn't appear as though there were any in handheld gaming products. I do know that monochrome LEDs were used to backlight LCDs using a lightguide in old Motorola two-way radios and bag phones in the early 1990's. 7800fan, your comments regarding gas pumps is helpful. I had thought of them but wasn't sure they were LED. I think the temperature requirements for the gas station pumps made fluorescent backlights less than ideal (didn't work well in cold climates back then) and the incandescent bulbs would burn out and be expensive to change (and make the pump unusable at night). Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 11, 2015 Share Posted November 11, 2015 Neon is another option in old items as they last a very long time and are compact and bright Often used in movie theater flooring and elevators buttons my 1987 vintage Kenwood oscope still has all 4 of its original yellow neon bulbs in working g order Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted November 11, 2015 Share Posted November 11, 2015 (edited) What did exist though are handheld games with special leds that would light up to show the characters, a bit like led displays. these for example, but many of these kind of games exist: All characters are led displays that can be switched on and off, a bit like an LCD screen but instead every image had a dedicated led. Is that close enough of what you are looking for? edit: Here is an image of a donkey kong screen Edited November 11, 2015 by DrWho198 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 11, 2015 Share Posted November 11, 2015 (edited) Those are not led those are vfd displays tiny flourecent elements in a vacuum tube https://en.m.wikipedia.org/wiki/Vacuum_fluorescent_display Edited November 11, 2015 by Osgeld Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted November 11, 2015 Share Posted November 11, 2015 really? I Always thought they were leds ^^" Never too old to learn something new Quote Link to comment Share on other sites More sharing options...
7800fan Posted November 13, 2015 Share Posted November 13, 2015 Yep, VFD. The blue light are the dead giveaway since blue LED weren't available for consumer toy back in mid 80s Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted November 13, 2015 Share Posted November 13, 2015 (edited) I Always assumed that it was a led in a colored casing which was masked to the right shape. A bit like how you would put a led after a slide. I never gave it a second thought. Do those vfd's consume much power? And are they expensive? Edited November 13, 2015 by DrWho198 Quote Link to comment Share on other sites More sharing options...
+save2600 Posted November 13, 2015 Share Posted November 13, 2015 Some home audio CD players and DAC's of the 80's-90's used red, green, blue and orange LED's for backlighting their monochrome LCD displays. Seem to remember some tuners did as well. Red 'was' ugly and dark though, but that didn't stop some manufacturers from using them. Blue might have been fluorescent (or something else like a painted incandescent bulb) come to think of it. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 13, 2015 Share Posted November 13, 2015 (edited) I Always assumed that it was a led in a colored casing which was masked to the right shape. A bit like how you would put a led after a slide. I never gave it a second thought. Do those vfd's consume much power? And are they expensive? you know those novelty light bulbs with a flame in them or some other shape, almost identical except have a bunch of elements in a grid = yes VFD's consume a decent amount of power, they take upwards of 60 volts, and yea they are expensive, a 16x2 text one on digikey is like 40 bucks. though that specific one is fairly nice since it has the boost regulator on board ( so you dont have to make your own high voltage) and only consumes 250mA in comparison a LED backlit LCD screen with 16x2 text is about 10 bucks and would suck less than 30mA Edited November 13, 2015 by Osgeld Quote Link to comment Share on other sites More sharing options...
BladeOfOsiris Posted November 17, 2015 Share Posted November 17, 2015 What about the Sega Game Gear? Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 17, 2015 Share Posted November 17, 2015 Cold cathode fluorescent tube Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted November 17, 2015 Share Posted November 17, 2015 (edited) if only that one would have been led, then it would not eat up so much power. Still, I can't get myself to mod one of my gamegears to led. It just isn't original. I'll have to wait till one of them dies before I try the LED mod. Edited November 17, 2015 by DrWho198 Quote Link to comment Share on other sites More sharing options...
BladeOfOsiris Posted November 18, 2015 Share Posted November 18, 2015 Yeah Id like to LED mod my Game Gear, as well. But first I have to change the damn capacitors Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 18, 2015 Share Posted November 18, 2015 (edited) Pic of my gamegear (which I no longer own) with my own custom led strip to avoid the "cones of lame" Been on the fence about making a pile of them and selling them bit it seems like a lot of effort for a very small market Edited November 18, 2015 by Osgeld Quote Link to comment Share on other sites More sharing options...
