Rob Mitchell Posted November 11, 2015 Share Posted November 11, 2015 After using a hairdryer to heat the adhesive glue and removing the labels very gently, I sprayed the silver parts using Rust-Oleum American Accents 2x Ultra-Cover and got pretty good results .. Because my Odyssey 2 Microprocessor is stamped on the plastic, I had to mask over it. Below it is the O2 Voice which does have a removable badge logo. 5 Quote Link to comment Share on other sites More sharing options...
forrestsmith Posted November 11, 2015 Share Posted November 11, 2015 That's going to look good, I was afraid to take the keyboard off so I masked it off. Forrest Quote Link to comment Share on other sites More sharing options...
Nutsy Doodleheimer Posted November 11, 2015 Share Posted November 11, 2015 Awesome!! Thanks for showing us! :thumbsup: Quote Link to comment Share on other sites More sharing options...
mtshark7 Posted November 15, 2015 Share Posted November 15, 2015 That's awesome Rob! I used a grey sharpee paint pen one one I got on ebay that was scratched up. Even tho the Grey is slightly lighter color I was able to blend it in rather well. Sent from my SM-G900V using Tapatalk Quote Link to comment Share on other sites More sharing options...
ls650 Posted November 16, 2015 Share Posted November 16, 2015 Cool. When you're done, maybe you could post some before and after photos. I've thought of doing the same with mine, because although it works great, the silver shell is scratched and scrapped pretty harshly from the previous owners. Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted October 4, 2016 Share Posted October 4, 2016 How did this work out? I am thinking about painting mine. 1 Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted October 7, 2016 Share Posted October 7, 2016 TOO LATE!!! I went for it with Krylon Fusion for Plastic® Metallic Shimmer - Nickel Shimmer... ...and it now looks like this: Edit: Added photo of console after some 2000 grit wet-dry sanding and with label back on it: It hasn't completely cured yet (needs 7 days, was painted this afternoon) and I think I'm going to sand it ever-so-lightly with high-grade wet sandpaper (2000ish) to smooth it out a tiny bit after it is fully cured. Take it from me, if you are going to paint your O2 or Videopac make sure you've filled any deep pits or gouges and then sanded the plastic nice and smooth with progressively higher-grade wet sandpaper. I started sanding with 220 wet-dry (wet) and moved to 600, then 1500, and topped off with a 2000 (all wet sanding, none dry) before spraying. This is my second attempt since my first attempt was done without filling and sanding and let me tell you, the first attempt did not turn out nearly as good. Yes, there is a slight color difference from the original silver but it looks WAY, WAY, WAY better than before I painted it. Actually, it may look better than it did new. On the first attempt I had masked off the Odyssey2 logo in the top left corner but I didn't like how it came out so I decided to paint over it (after sanding ) and silkscreen it back later. You can see the original silver still on the controllers except for the action buttons that I hit with the Krylon after I carefully removed them. The buttons on this unit had obviously seen some serious play-time. They were bare plastic and a bit worn down. As I said, I am planning on silk-screening (not sure how yet) the Odyssey2 logo back in the top left corner I made this one and it is really pretty close to the original but not 100% perfect: I saved the label that surrounds the cartridge slot for reapplication after the paint is completely finished. Be careful removing that thing. It is metal but you don't want to bend it. Who knows how to shine/polish the clear, shiny plastic covering the keyboard? It's super easy to get to the whole surface once you have the plastic face-plate off and I'd like to get it super shiny and coated with a protectant of some sort to avoid future scratches/discoloration before I claim that I am done with my refurb. I think I'll clean and spray the controllers with the Krylon, too, so they match perfectly. 4 Quote Link to comment Share on other sites More sharing options...
metarog Posted October 7, 2016 Share Posted October 7, 2016 Wow, that looks great. I am going to try this myself eventually but I think I will be going all black. Thanks again for all the nice tips too. Quote Link to comment Share on other sites More sharing options...
metarog Posted November 5, 2016 Share Posted November 5, 2016 I finally got around to painting my test console that had a really scratched up and faded silver cover. This was a cheap paint job with a couple cans of flat black I bought at a garage sale. It didn't come out perfect but it is a lot better than it was. I also painted the Action buttons on the controllers and put in an LED to the right of the power switch. It doesn't look too bright in the pics but it looks alright in person. Let me know what you think. Anybody else do any paint jobs lately? 1 Quote Link to comment Share on other sites More sharing options...
+KylJoy Posted November 5, 2016 Share Posted November 5, 2016 Its a Darth Vader O2! 1 Quote Link to comment Share on other sites More sharing options...
metarog Posted November 5, 2016 Share Posted November 5, 2016 Ha ha... I didn't even consider that but you are right! Quote Link to comment Share on other sites More sharing options...
