dalves Posted November 12, 2015 Share Posted November 12, 2015 I've just bought an Intellivision ECS off eBay. I've read that you can do some basic programming with it, but you'll need a cassette drive to save your data. I was wondering if anyone knows what kind of cassette drive would be compatible with the ECS? Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 12, 2015 Share Posted November 12, 2015 Just about any cassette deck with a mic-in and earphone-out should do, if I recall correctly. That said, you might also consider hooking it to your PC's sound card, saving your games to WAV files. Instead of punching record on a tape deck, record the game to a WAV file. Later, to load it, play back the WAV file. Just requires a couple patch cords from the local electronics store, and simple play/record software on your PC. 1 Quote Link to comment Share on other sites More sharing options...
+doctorclu Posted November 12, 2015 Share Posted November 12, 2015 The patch cords with a PC is perhaps the best way. AND, if you have a Cuttle Cart 3, few cables and loop back adapter (some assembly required) you can call a BBS or even telnet out to the interwebs on your ECS. http://atariage.com/forums/topic/168660-intellivision-as-serial-terminal/page-4?hl=serial&do=findComment&comment=3224607 But you reminded me I wanted to try some programming on the ECS. Thanks for that. Quote Link to comment Share on other sites More sharing options...
DZ-Jay Posted November 13, 2015 Share Posted November 13, 2015 Just about any cassette deck with a mic-in and earphone-out should do, if I recall correctly. As someone who had an ECS back in the day, and who used the save/load feature, I can attest that this is correct. I used whatever tape-deck I had on hand. Mic-in/earphone-out, both using audio "mini" plugs (mono/single-stripe). It worked, though it wasn't very reliable. -dZ. 1 Quote Link to comment Share on other sites More sharing options...
intvnut Posted November 14, 2015 Share Posted November 14, 2015 As someone who had an ECS back in the day, and who used the save/load feature, I can attest that this is correct. I used whatever tape-deck I had on hand. Mic-in/earphone-out, both using audio "mini" plugs (mono/single-stripe). It worked, though it wasn't very reliable. -dZ. Yep, that's effectively what we used also. Ironically, my dad bought us a Mattel Aquarius cassette drive to use with it, and we could never get it to work at all. But, the more generic cassette deck I used with my TI-99/4A worked just fine. It was Texas Instruments branded (the Texas Instruments Program Recorder), but it was just a rebadged unit from GE. Since then, I've used other, similar generic decks with both the TI-99/4A and the ECS. I will say the TI-99/4A was far more forgiving than the ECS. The ECS wants the tape just right. The TI-99/4A accepts a little more variance. Quote Link to comment Share on other sites More sharing options...
