towmater Posted November 29, 2015 Share Posted November 29, 2015 (edited) So I ordered a Jerry USB mouse adapter and a GBS8220 RGB to VGA board. I have two Amiga monitors so I don't need to use VGA. I've always wanted the GBS board anyway so hopefully it works out... these things cost next to nothing so not much risk in it.Y you might have to use the pin-header on the GBS, I could never get it to work properly with the 15-pin input (with the 500 only.) Edited November 29, 2015 by towmater Quote Link to comment Share on other sites More sharing options...
bbking67 Posted November 29, 2015 Author Share Posted November 29, 2015 yeah ill use the header... seems to be the way to go. Quote Link to comment Share on other sites More sharing options...
bbking67 Posted December 30, 2015 Author Share Posted December 30, 2015 So i got my Amiga up and running... cleaned up some battery goo from the memory expansion (desoldered the battery). It seems to work. The floppy works (I have one bootable disk). JerryUSB was not liking my Microsoft optical mouse but it works ok with a Kensington. Lots to learn. Haven't wired the GBS up yet (original monitor works perfectly though). 1 Quote Link to comment Share on other sites More sharing options...
desiv Posted January 7, 2016 Share Posted January 7, 2016 So i got my Amiga up and running... cleaned up some battery goo from the memory expansion (desoldered the battery). It seems to work. The floppy works (I have one bootable disk). JerryUSB was not liking my Microsoft optical mouse but it works ok with a Kensington. Lots to learn. Haven't wired the GBS up yet (original monitor works perfectly though). Congrats.. Yeah, I have a GBS on my A1200.. (Wired to the header) Worked fine and I have it on a KVM (only switch the V part of that tho) with my PC to save some desk space. It works pretty good. Higher res Workbenck looks decent... That said, I prefer my 1084S on my A1000 for gaming usually. Problem there is my A1000 doesn't do PAL... I might go back to a 1084S (I have 2) for my 1200 eventually. Something about CRTs.. desiv Quote Link to comment Share on other sites More sharing options...
towmater Posted January 24, 2016 Share Posted January 24, 2016 I bought one of those 1970VX lcd monitors that the AtariST group is raving about, and that with the $20ish Amigakit VGA connector ended up giving me a much better picture than GBS. Quote Link to comment Share on other sites More sharing options...
RobertB Posted January 24, 2016 Share Posted January 24, 2016 (edited) bbking67 wrote: > Is there a good way to interface with a modern LCD monitor or TV? Instead of finding a scandoubler and installing one in each of my Amigas (except for the A3000, of course), I went the other way and bought a modern LED monitor that can scan down (multi-scan) to the 15 KHz video of the Amiga. I bought a BenQ BL912 VGA monitor. With the RGB-to-VGA adapter, the BenQ BL912 displays a beautiful picture on an A1000, A500, A2000, and A3000 (adapter not needed). I haven't tested it yet on my A600 or A4000 yet, because both are down at the moment. Then there is the smaller BenQ BL702A cousin, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm Edited January 24, 2016 by RobertB 1 Quote Link to comment Share on other sites More sharing options...
Nebulon Posted January 25, 2016 Share Posted January 25, 2016 bbking67 wrote: > Is there a good way to interface with a modern LCD monitor or TV? Instead of finding a scandoubler and installing one in each of my Amigas (except for the A3000, of course), I went the other way and bought a modern LED monitor that can scan down (multi-scan) to the 15 KHz video of the Amiga. I bought a BenQ BL912 VGA monitor. With the RGB-to-VGA adapter, the BenQ BL912 displays a beautiful picture on an A1000, A500, A2000, and A3000 (adapter not needed). I haven't tested it yet on my A600 or A4000 yet, because both are down at the moment. Then there is the smaller BenQ BL702A cousin, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm That is very cool. Do you know of any other modern displays that support 15 KHz? Quote Link to comment Share on other sites More sharing options...
bbking67 Posted January 26, 2016 Author Share Posted January 26, 2016 So I haven't had time to wire up my GBS yet, but I do have some old NEC MultiSync LCD's that might work... one is an AccuSync. This would be neat if it worked. I need to find a nice project box for my GBS as I don't want to leave it exposed. I think I'll wire it up with a fan of some kind. Quote Link to comment Share on other sites More sharing options...
RobertB Posted January 27, 2016 Share Posted January 27, 2016 Nebulon wrote: > Do you know of any other modern displays that support 15 KHz? According to the thread on Amibay.com (where I found the info on the BenQ BL912 and 702A), other monitors are: BenQ BL2205PTAcer v226hqlNEC 1970NXp (for bigbox amigas you need buffered adapter.)DELL Ultrasharp 2311hDELL 2001FP (those made before June 2005)Planar 1520M Truly, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm 1 Quote Link to comment Share on other sites More sharing options...
Laner Posted January 30, 2016 Share Posted January 30, 2016 Hm... I have a 2001FP at my desk at work. Might need to smuggle that home one night. Quote Link to comment Share on other sites More sharing options...
Nebulon Posted February 1, 2016 Share Posted February 1, 2016 Hm... I have a 2001FP at my desk at work. Might need to smuggle that home one night. Or you could bring your Amiga to work! Yep, if I worked for a place that had Amiga-compatible flat-panels, I'd be sure to short-list myself for the time when they eventually replace their old screens with new ones. Quote Link to comment Share on other sites More sharing options...
Nebulon Posted September 29, 2018 Share Posted September 29, 2018 Here's a pretty long list of monitors that scan to 15kHz: http://15khz.wikidot.com/ Quote Link to comment Share on other sites More sharing options...
Nebulon Posted September 29, 2018 Share Posted September 29, 2018 So I ordered a Jerry USB mouse adapter and a GBS8220 RGB to VGA board. I have two Amiga monitors so I don't need to use VGA. I've always wanted the GBS board anyway so hopefully it works out... these things cost next to nothing so not much risk in it. The Jerry mouse adapter is cool. I tested it out on an A500 some time ago. Another similar product (but without the dual connection ability) is this one. It supports multi-button game pad controllers: https://retro.7-bit.pl/?lang=en&go=projekty&name=rys_mkii Quote Link to comment Share on other sites More sharing options...
