gladders Posted November 18, 2015 Share Posted November 18, 2015 Does anyone know if an Amiga 500 power brick will work with an Amiga 500 Plus, or would it kill it? Ta very much Quote Link to comment Share on other sites More sharing options...
RobertB Posted November 19, 2015 Share Posted November 19, 2015 Yes, an A500 p.s. will work on an A500+. FCUG celebrating 34 years this month, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm Quote Link to comment Share on other sites More sharing options...
carlsson Posted November 24, 2015 Share Posted November 24, 2015 All desktop Amigas from the 500 to the 1200 have the same pinout and voltages. The lighter, switched mode power supplies to later Amiga 500 and the 500+ are rated for slightly higher effect than the previous as well as later suppies, so back in the day some Amiga 1200 users preferred to use a 500 supply as it would give a little extra juice for your power hungry expansions. Quote Link to comment Share on other sites More sharing options...
Laner Posted December 7, 2015 Share Posted December 7, 2015 (edited) To piggyback on this discussion; I have an A1200 with an ACA 1231 expansion (68030, 42Mhz, 64MB) which came with a custom power supply from Amigakit. Now, it works fine, but the fan in the PSU is ridiculously loud. I *also* have an A600 power supply which seems to work fine with the expanded A1200 - it will run AGA games via WHDLoad, etc. Will this cause problems if I continue to use it? Edited December 7, 2015 by Laner Quote Link to comment Share on other sites More sharing options...
RobertB Posted December 8, 2015 Share Posted December 8, 2015 Laner wrote: > I have an A1200 with an ACA 1231 expansion (68030, 42Mhz, 64MB) which came with a custom power supply from Amigakit. Now, it works fine, but the fan in the > PSU is ridiculously loud. Why don't you replace the fan with a quieter one? > I *also* have an A600 power supply which seems to work fine with the expanded A1200 - it will run AGA games via WHDLoad, etc. Will this cause problems if I > continue to use it? Hmm, a bit under-powered but if you are not having any problems (like no boot-up or partial boot-up) with that combo, then you are good. Truly, Robert Bernardo Fresno Commodore User Group http://www.dickestel.com/fcug.htm Quote Link to comment Share on other sites More sharing options...
Laner Posted December 8, 2015 Share Posted December 8, 2015 Laner wrote: > I have an A1200 with an ACA 1231 expansion (68030, 42Mhz, 64MB) which came with a custom power supply from Amigakit. Now, it works fine, but the fan in the > PSU is ridiculously loud. Why don't you replace the fan with a quieter one? The power supply does not have a typical 3 pin fan connector - the existing fan leads are soldered directly into the board, and my soldering skills are non-existent. And I had the A600 supply readily available. But I may look for someone to do the mod eventually. Thanks for weighing in! Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted December 15, 2015 Share Posted December 15, 2015 The power supply does not have a typical 3 pin fan connector - the existing fan leads are soldered directly into the board, and my soldering skills are non-existent. And I had the A600 supply readily available. But I may look for someone to do the mod eventually. Thanks for weighing in! Wire cutters and electrical tape it is, then! Quote Link to comment Share on other sites More sharing options...
towmater Posted December 23, 2015 Share Posted December 23, 2015 I put one of these under my A500's floppy drive. No noise, no problems using it so far. Bad idea? It seems too good to be true. http://www.amazon.com/gp/product/B00HLCT9HK Quote Link to comment Share on other sites More sharing options...
carlsson Posted December 23, 2015 Share Posted December 23, 2015 Possibly the -12V is on the weak side with the picoPSU. I read the manual, and it states it has a max load of 0.05A with peak at 0.1A, while original Amiga power supplies are rated for 0.1A on that signal. The difference is hair thin though, and frankly I don't know what the Amiga uses the -12V for. The specs for +5V and +12V are more than enough. I take it you made some internal modification or pull out a cable to connect to the power input on the motherboard? Quote Link to comment Share on other sites More sharing options...
towmater Posted December 25, 2015 Share Posted December 25, 2015 I take it you made some internal modification or pull out a cable to connect to the power input on the motherboard? I put a standard wall-wart dc jack next to the joystick ports, and wired the psu outputs directly to the original psu's input (so that original jack still works as well.) I wanted it to be minimally invasive. I use a beefy 1V 3A laptop power brick to supply voltage. Quote Link to comment Share on other sites More sharing options...
