Atari Charles Posted November 26, 2015 Share Posted November 26, 2015 Superbanking SB-if you write a game 32K up to 1MB it doesn't require a rewrite of the bankswitching, you just expand the program and keep on going. Based on the board you use of course. You could use SB to write an 8K game or up to 1 MB if you wish. The key is being able to make games as small or as large as you like. 1MB seems to be the limit with current technology. 256k seemed to be the limit both in the program and in hardware, until more recently. Quote Link to comment Share on other sites More sharing options...
fb39ca4 Posted December 1, 2015 Share Posted December 1, 2015 Can you please explain further? I thought the largest bankswitching scheme was 3F, with 512KB? Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 1, 2015 Share Posted December 1, 2015 Probably he is referring to this. Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted December 1, 2015 Share Posted December 1, 2015 To answer your question try to understand this: Bankswitching is a trick in which a larger storage chip is divided in multiple equal parts. Most of the time, the game console can only see 1 part(a bank). Which bank is seen by the console is controlled by the cartridge pcb. The pcb has some logic chips which will change the selected bank depending on a trigger(condition) What this condition is, is chosen by the designer of the pcb. This can not be changed within the software. A cartridge gets a very limited amount of data from the console. Basically the only thing a cartidge can tell is 1)if it gets power, 2) what the location of the last byte was that was accessed, 3) what data bits were send during a write. This is not much to go by, so most cartridges would select a bank by hotspots in memory. In that case each bank has its own unique memory location that will trigger the bank being selected. Another way would be to combine a hotspot with the data bits. That would trigger depending on the byte being written. If I'm not mistaking then the system where this Superbanking is based on, will use a very basic counter. you can only advance one bank furter each time. The good thing is, there is NO limit in the design. The limit is decided by the size of the storage chip and the counter. But for most games this is useless since changing to any bank besides the one directly after the current one, will take too long. Unless you add other ways of triggering there is no fast way to jump to other banks. Now for the simple answer... there is no real limit. But besides a multicard for 2k and 4k games, I see no use for this bankswitching. a small note for noobies: cartridges like Melody and Symphony are a different story. They contain processors that run there own software. They can adapt to the needed bankswitching because deep inside is a processor faster and more powerfull then the one in the Atari itself. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted December 1, 2015 Share Posted December 1, 2015 My new bankswitch board is not linear, you can select any bank within 256K, it supports super banking in two different ways, because it also supports a SARA chip. I did not want to go beyond 256K, because it would require a CPLD, or 2 PLD's, which is not cost effective and requires a lot more soldering. http://atariage.com/forums/topic/219144-new-homebrew-board-coming-soon/?p=3204573 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 1, 2015 Share Posted December 1, 2015 CPUWIZ boards also have batari BASIC support with is basically (ha!) the only other choice for Atari 2600 development. UPDATE: Thank you RevEng Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted December 1, 2015 Share Posted December 1, 2015 (edited) He was referring to a particular board which uses a bankswitching that he calls Super banking. I'm not known to this particular board or what method of bankswitching it exactly supports. But of what I read in the other post, it is based on F0 (megaboy). Which is nothing more than a counter triggered by accessing 1FF0. I'm not sure if the information in the other post was correct though. It actually confuses me since the name Superbanking was already in use for the banking your(meaning CPUWIZ's) new PCB supports. Within the homebrew community we have a few boards that support large roms. I'm not sure if at current time any have been build with more than 256 banks, but I know of a few that do support 256k and which can be triggered to switch to any bank with a single opcode. To add to the list, Blinky's MDMC supports 256 4k banks, which would result in 1MB of rom storage. I have yet to make a rom this size, but it is possible. If you look at MDMC then you will notice that it has very much in common with SB. The one thing it does lack is CE RAM. Edited December 2, 2015 by DrWho198 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted December 2, 2015 Share Posted December 2, 2015 (edited) Now for the simple answer... there is no real limit. But besides a multicard for 2k and 4k games, I see no use for this bankswitching.I see some super-unrolled code and data which maybe shaved off a few cycles in a kernel here and there. At the cost of a lot of bankswitching and extreme code/data redundancy. Probably something like DPC(+) would be the better alternative here. Else, for games, you need more RAM to be able to utilize that much ROM efficiently. E.g. you can design a really huge world map, but without RAM it becomes static and boring. So without RAM, this bankswitching is IMO more or less limited to storing bigger amounts of data which require little code (e.g. digital audio or video). Edited December 2, 2015 by Thomas Jentzsch 1 Quote Link to comment Share on other sites More sharing options...
DrWho198 Posted December 3, 2015 Share Posted December 3, 2015 (edited) I now realize that I mixed up what was mentioned in the oher post (Mega Board) with Super banking which was also mentioned there. It just made no sence to me. It was this Mega Board that I was refering to, that seems to be useless unless you want to make a 4K game multicard. Superbanking on the other hand is not useless, it is about the same as MDMC but supports less banks. Although as you mentioned Thomas, for developing a single game on these carts, RAM should be added. But I don't think most poeple would use such big storage for a single game anyway. I have been thinking about adding ram to an MDMC though, but I have other things on my mind right now. Besides, that would make the logic more complex anyway. Edited December 3, 2015 by DrWho198 Quote Link to comment Share on other sites More sharing options...
