mbd30 Posted November 28, 2015 Share Posted November 28, 2015 The picture is dark on my CRT when I first turn it on and gradually becomes brighter when I leave it on. It's noticeable in some games. When I first turn on the TV, the first stage in "Battletoads" is brown. Only after the TV has been on for some time does it appear green like it should. Quote Link to comment Share on other sites More sharing options...
fiddlepaddle Posted November 28, 2015 Share Posted November 28, 2015 Usually that tends to happen more and more as the picture tube gets older. Also, early model tubes took longer to warm up...same thing with old radios, or anything based on vacuum tubes. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 28, 2015 Share Posted November 28, 2015 (edited) old CRT, even soild state ones took a good few moments to warm up, modern ones are pretty much instant on and may point to something starting to fail (like a cap or a fet) edit: and even on the old CRT's it wouldnt just be one color it would be the whole tube Edited November 28, 2015 by Osgeld Quote Link to comment Share on other sites More sharing options...
CatPix Posted November 28, 2015 Share Posted November 28, 2015 It's normal on earlier TV, mostly the ones with most or all-analog circuitry. Because they are getting old mainly, but it's also normal. It's also what make them more durable, as they put less stress on the components. If you start to see colors that take more time to warm up, it's probably because some capas are getting off. Quote Link to comment Share on other sites More sharing options...
MotoRacer Posted November 29, 2015 Share Posted November 29, 2015 Yeah, they don't just "come on" like modern HDTVs. Typically just about 3-4 seconds before they come on strong, though I have an old Sony Trinitron that must be on it's last legs as it takes much longer than that, and even when it comes on isn't full bright. I'd throw it away, but I can't bring myself to. Quote Link to comment Share on other sites More sharing options...
BillyHW Posted November 29, 2015 Share Posted November 29, 2015 Yeah, CRTs always took a bit to warm up. Older LCDs too. Only when they switched to to LED backlights was it practically instant on. 1 Quote Link to comment Share on other sites More sharing options...
MotoRacer Posted November 29, 2015 Share Posted November 29, 2015 Yeah, CRTs always took a bit to warm up. Older LCDs too. Only when they switched to to LED backlights was it practically instant on. I still remember our family's first LCD screen. It was a 4:3 ratio unit, with a casing that made it look like a perfect match to a Compaq Presario 7000 series from 1997, haha. Took forever to "warm up", even when new, and the brightness level was laughable at best. I think it was made by Dell, but I can't be sure. It was white/beige with the largest base and thickest bezel you ever did see. Quote Link to comment Share on other sites More sharing options...
Eltigro Posted November 29, 2015 Share Posted November 29, 2015 Could the older LCDs taking a while to brighten up be because they were lit by older fluorescent bulbs/lights? I know those older light bulbs (like used in table lamps or whatever) can take some time to come up to full brightness sometimes. (Don't know too much about construction of LCDs, but know that some are fluorescent, some plasma, and some LED...) Quote Link to comment Share on other sites More sharing options...
BillyHW Posted November 29, 2015 Share Posted November 29, 2015 Could the older LCDs taking a while to brighten up be because they were lit by older fluorescent bulbs/lights? I know those older light bulbs (like used in table lamps or whatever) can take some time to come up to full brightness sometimes. (Don't know too much about construction of LCDs, but know that some are fluorescent, some plasma, and some LED...) Yes, that's exactly it. Quote Link to comment Share on other sites More sharing options...
Osgeld Posted November 29, 2015 Share Posted November 29, 2015 dunno I have a year 2000 NEC LCD monitor, still fires directly up even though being used tens of hours a day for over 14 years Quote Link to comment Share on other sites More sharing options...
MotoRacer Posted November 29, 2015 Share Posted November 29, 2015 dunno I have a year 2000 NEC LCD monitor, still fires directly up even though being used tens of hours a day for over 14 years That's awesome. NEC made some good stuff back then. Doesn't surprise me. Quote Link to comment Share on other sites More sharing options...
Nutsy Doodleheimer Posted December 1, 2015 Share Posted December 1, 2015 That was typical for CRT televisions. I remembered back in the 80's we had a Sony tv. Once it was turned on the colors on the screen looked inverted but after a few minutes they went to normal. I had an Emerson 13" tv long ago and there was a small green dot on the screen and after a few minutes, that went away. Quote Link to comment Share on other sites More sharing options...
