Banquo Posted December 1, 2015 Share Posted December 1, 2015 I just spotted this on ebay and I can't figure out what it is. I've never seen one like it before and I can't find any information about it at all. It's a fat PS2 but it has a top loading door in addition to the tray. Is this something incredibly rare or just some homemade design someone has come up with? Quote Link to comment Share on other sites More sharing options...
Reaperman Posted December 1, 2015 Share Posted December 1, 2015 (edited) It's an aftermarket case top for swapping disks while the system is on. I've got one on my main ps2. I'd imagine that there's also a very large hard drive attached to that network adapter to match the rest of the setup. Edited December 1, 2015 by Reaperman 6 Quote Link to comment Share on other sites More sharing options...
leods Posted December 1, 2015 Share Posted December 1, 2015 Just for Information, There's actually a mod for the Slim that lets you install an HD in it. There's soldering and wiring involved of course, and a bottom half with space for the HD. You also Need an extra power supply to make the HD run. Quote Link to comment Share on other sites More sharing options...
Skippy B. Coyote Posted December 12, 2015 Share Posted December 12, 2015 Wow, I used to have that exact same casing on my old PS2! As Reaperman mentioned it is an aftermarket top case, but to give you a little more info the company that made them was called Swap Magic. The cases came with a Swap Magic boot disc that you'd use to start up the system, then once it was running you could open up the top, remove the disc, and swap in any import game you wanted to play. It was an easy and convenient way to play imports without having to solder in a mod chip. 2 Quote Link to comment Share on other sites More sharing options...
SSG Posted December 15, 2015 Share Posted December 15, 2015 That is a neat mod. I still prefer the fat ps2 in its original case compared to the slim model I have now. Quote Link to comment Share on other sites More sharing options...
No_one_from_nowhere Posted December 16, 2020 Share Posted December 16, 2020 I just picked one of these babies up on fb marketplace. Didn’t come w boot disc. Any ideas on how I can get it to work without it? Quote Link to comment Share on other sites More sharing options...
Video Posted December 20, 2020 Share Posted December 20, 2020 Neat. Never saw that, I would have said clone system if others hadn't already said what it was. I remember the disc swap, but had the ps2 slim version which was just a spring to hold the open door switch down while you swapped the disc. Never much used it, had a few dbz games that didn't make it here at the time, but not much else. Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted December 20, 2020 Share Posted December 20, 2020 (edited) On 12/16/2020 at 8:28 AM, No_one_from_nowhere said: I just picked one of these babies up on fb marketplace. Didn’t come w boot disc. Any ideas on how I can get it to work without it? Don't think so, you need the boot disc as it sends the command to stop the disc spindle from turning after loading the boot info, thus allowing you to well, "Swap Discs". I have one myself along with the Swap Magic discs. To make use of a top loading console to play backups you simply need the boot discs BUT that said, I believe you can load the same SWAP DISC type of program directly from a memory card but I do not have much experience with that. Edited December 20, 2020 by OldSchoolRetroGamer update Quote Link to comment Share on other sites More sharing options...
0078265317 Posted December 23, 2020 Share Posted December 23, 2020 Here is a slim version. https://www.ebay.com/itm/254814402514 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted December 23, 2020 Share Posted December 23, 2020 (edited) And a fat. https://www.ebay.ca/itm/224085979419 https://www.ebay.co.uk/itm/114588015968 Edited December 23, 2020 by 0078265317 Quote Link to comment Share on other sites More sharing options...
