Fairchild Channel F Repair
I have a Fairchild Channel F that I believe has a problem with the psu. I've found a few things online that seem to match my issue.
When I power it on I get a garbled image onscreen and the tv still prduces the static sound.
Although I was able to find some info indicating the issue was with the psu, I have not found any info on how this problem might be corrected.
I have attached a pic of the video output on a CRT.
If anyone has any ideas, please let me know. I really want to get this old sytem up and running again.
If the issue come from the power supply, I'll suspect bad capacitors.
Old system from this era will likely use different voltages; 12V, 5V for the RAM at least.
Your issue is more likely located on the RAM/ROM supply, so the 5V line.
So your first task is to locate the power supply output, and check the voltages.
Here are schematics :
Fairchild-Channel-F-Schematic---Page-1.p
As I suspected, there are 12V, 5V and a -5V for the RAM.
The schematics seems to show that voltage are fed into the motherboard by a connector, so that make your measuring easy.
If you get 12V, 5V and -5V (on load) then the issue is likely on the motherboard.
If one of those voltages are wrong, or all of them, then the failure is into the PSU.
I can't help you much more. I have an European VCS so the PSU, power requirement and hardware configuretion might differ enough. I'll try to get pictures anyway if you need them.
