ginta289 Posted December 15, 2015 Share Posted December 15, 2015 Just a quick question, was centipede ever realeased in PAL territories on the 7800 as I have been unable to find a copy or is it just extremely rare. also is the US version compatibility with the PAL 7800 Quote Link to comment Share on other sites More sharing options...
Dauber Posted December 15, 2015 Share Posted December 15, 2015 Technically the US version should work, but it might screw up your display...it'll throw your vertical hold outta whack. Quote Link to comment Share on other sites More sharing options...
+save2600 Posted December 15, 2015 Share Posted December 15, 2015 Someone correct me if I'm wrong, but I'm fairly sure NTSC carts do NOT work at all in a PAL 7800 system and vice versa. It's not like the 2600 that way, where you can simply expect the wrong colors and adjust your vertical hold. On my NTSC 7800's, when inserting a PAL cart, all I get is a black screen. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted December 16, 2015 Share Posted December 16, 2015 Yes, there is a PAL 7800 Centipede. An NTSC copy will play at least partially on a PAL 7800. Mitch 2 Quote Link to comment Share on other sites More sharing options...
+slx Posted December 24, 2015 Share Posted December 24, 2015 Expect black and white and some screen offset with NTSC games on a PAL machine/TV. Gesendet von meinem iPhone mit Tapatalk Quote Link to comment Share on other sites More sharing options...
ColecoNoob Posted December 26, 2015 Share Posted December 26, 2015 Someone correct me if I'm wrong, but I'm fairly sure NTSC carts do NOT work at all in a PAL 7800 system and vice versa. It's not like the 2600 that way, where you can simply expect the wrong colors and adjust your vertical hold. On my NTSC 7800's, when inserting a PAL cart, all I get is a black screen. I have a copy of JOUST for my PAL Atari which I bought on eBay from a british seller to make sure I will receive a PAL cartridge. What I got was obviously a NTSC module because the label is b/w and states "Pro System". The reason why I tell you this is that it works in my PAL system without flaws. Coincidence I guess Quote Link to comment Share on other sites More sharing options...
+Mitch Posted December 27, 2015 Share Posted December 27, 2015 Joust for the 7800 uses the same cart label for both NTSC and PAL versions. For that matter, so do all of the Atari released games for the 7800. Occasionally you will see a difference in copyright date and printing location, that is all. PAL 7800 games generally have a P sticker on the back of the cart but it comes off sometimes. Mitch Quote Link to comment Share on other sites More sharing options...
ColecoNoob Posted December 29, 2015 Share Posted December 29, 2015 OK so it seems that my "P" sticker just came off Quote Link to comment Share on other sites More sharing options...
Jaynz Posted December 29, 2015 Share Posted December 29, 2015 OK so it seems that my "P" sticker just came off Ewwwww... See a doctor! 1 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted December 29, 2015 Share Posted December 29, 2015 Someone correct me if I'm wrong, but I'm fairly sure NTSC carts do NOT work at all in a PAL 7800 system and vice versa. About a decade ago a thread was started which listed the results of 7800 NTSC cartridges running on a 7800 PAL machine. The results vary. A similar thread was started a couple of years ago, revisiting the issue. As noted in the aforementioned linked threads, while there are some NTSC cartridges that will run on a PAL 7800 console, original 7800 PAL cartridges can never run on an original* NTSC 7800 console due to the lack of the encryption key signature for PAL 7800 cartridges that NTSC 7800 consoles require. *If an original NTSC 7800 console BIOS is replaced with a 'universal' or PAL/Euro one with Asteroids, or some other customized mod, then it is possible for PAL games to at least attempt to possibly run on an NTSC 7800 console; see Best Electronics 7800 BIOS swap "OS upgrade" for example. I've seen as far as the copyright notice displaying from a Commando PAL cart running under a NTSC console with such a modification. 2 Quote Link to comment Share on other sites More sharing options...
davyK Posted January 16, 2016 Share Posted January 16, 2016 (edited) Confirming that Centipede got a PAL release. I have a copy cart only. Lovely game actually. Edited January 16, 2016 by davyK Quote Link to comment Share on other sites More sharing options...
