Decimal to Hex Conversion Tooling?
First Spear
Hey all. I have a long string of numbers in a text file. I am looking for a program or technique to convert all of the values to hex equivalents in Windows, changing them in the text file. Before I go off in the weeds and code something, I thought I would ask what the gurus are using. The values are used in IntyBASIC. It's kind of academic since Decimal values work, but it is inconsistent where the rest of my programs use Hex.
Thanks.
604  , 570  , 570  , 570  , 570  , 570  , 538  , 538  , 508  , 339  , 339  , 339  , 339  , 320  , 339  , 339  , 339  , 320  , 320  , 320  , 452  , 508  , 538  , 570  , 320  , 359  , 538  , 427  , 452  , 427  , 427  , 403  , 403  , 403  , 718  , 718  , 761  , 761  , 339  , 678  , 678  , 761  , 427  , 452  , 508  , 640  , 640  , 761  , 761  , 761  , 678  , 678  , 678  , 678  , 678  , 604  , 604  , 604  , 854  , 854  , 905  , 905  , 678  , 905  , 854  , 761  , 854  , 807  , 718  , 678  , 678  , 678  , 678  , 678  , 678  , 678  , 718  , 718  , 718  , 761  , 761  , 807  , 807  , 807  , 807  , 807  , 807  , 807  , 807  , 807  , 718  , 678  , 678  , 678  , 678  , 678  , 640  , 640  , 640  , 640  , 640  , 640  , 640  , 640  , 320  , 320  , 320  , 427  , 427  , 427  , 403  , 403  , 380  , 302  , 302  , 285  , 285  , 285  , 285  , 285
Here ya go :-
$025C, $023A, $023A, $023A, $023A, $023A, $021A, $021A, $01FC, $0153, $0153, $0153, $0153, $0140, $0153, $0153, $0153, $0140, $0140, $0140, $01C4, $01FC, $021A, $023A, $0140, $0167, $021A, $01AB, $01C4, $01AB, $01AB, $0193, $0193, $0193, $02CE, $02CE, $02F9, $02F9, $0153, $02A6, $02A6, $02F9, $01AB, $01C4, $01FC, $0280, $0280, $02F9, $02F9, $02F9, $02A6, $02A6, $02A6, $02A6, $02A6, $025C, $025C, $025C, $0356, $0356, $0389, $0389, $02A6, $0389, $0356, $02F9, $0356, $0327, $02CE, $02A6, $02A6, $02A6, $02A6, $02A6, $02A6, $02A6, $02CE, $02CE, $02CE, $02F9, $02F9, $0327, $0327, $0327, $0327, $0327, $0327, $0327, $0327, $0327, $02CE, $02A6, $02A6, $02A6, $02A6, $02A6, $0280, $0280, $0280, $0280, $0280, $0280, $0280, $0280, $0140, $0140, $0140, $01AB, $01AB, $01AB, $0193, $0193, $017C, $012E, $012E, $011D, $011D, $011D, $011D, $011D
Not checked!
Thanks playa, but I need to do this a lot, so I am looking for a (command line) tool that will do it.
Here ya go :-
Not checked!
Thanks.
I typically employ custom Perl scripts to do this sort of work for me. If you have Perl installed, I can whip up something quick for you.
-dZ.
If you have access to sed, awk and od (i.e. Linux, *BSD but also present in Msys for Windows or other type of coreutils or binutils), you can get rather far with this little script. The bug lies in that you get a leading comma on each row and that od only groups eight hexadecimal numbers per row (unless you add the -w parameter to get more bytes per row), so you might want to concatenate rows afterwards.
#!/bin/sh
sed -e 's/,/\n/g' $1 | awk '{ high = int($1/256); low=$1-(high*256); printf "%c%c",low,high }' | od -An -x | sed -e 's/ / ,\$/g'
exit 0
Edited by carlsson
I usually just use bc and vi under Linux, myself, if it were just a one-off. Or, like dZ says upthread, whip up a Perl script to do it if I have many to do. All of these are available under Windows, but aren't really Windows-native solutions.
With Perl, something short like this might work, if your input consisted solely of lines with decimal numbers separated by commas and whitespace:
while (<>)
    my @data = split /\s*,\s*/;
    if (!@data)
        print $_;
        next;
    my @hex = map { sprintf '$%04X', $_ } @data;
    print( join( ',', @hex ) );
Sure, we could code-golf that into less code, but you get the idea.
  • 3 weeks later...
You can also do that in a browser console, using either FireBug or the built-in debugging tools which are usually accessible by pressing F12.
[ 604, 570, 570, 570, 570, 570, 538, 538, 508, 339 ].map(function(n) { return '$' + n.toString(16); }).join(', ')
(list shortened for readability)
In recent versions of Firefox, the content of an alert box can be selected and copied to the clipboard (that may be true for other browsers but I don't know for sure). Therefore, you can also put that directly in the address bar of a non-blank page:
javascript:alert([ 604, 570, 570, 570, 570, 570, 538, 538, 508, 339 ].map(function(n) { return '$' + n.toString(16); }).join(', '))
(You may have to add 'javascript:' manually. It gets automagically truncated after a copy/paste of the whole string, at least in my version of Firefox.)
