MotoRacer Posted December 21, 2015 Share Posted December 21, 2015 (edited) So I bought an already modded Xbox from Goodwill recently. It boots up in Evolution dashboard just fine, and will play retail games just fine (and the burned copy of some college football game that came with it in the drive already). I'm looking to get some component cables for the system, so I can play my games I just bought in a higher resolution. But it seems I need to go to the MS Dashboard to change the resolution it's outputting. (No option to do so in Evolution) When I click on MS Dashboard, it cycles, but comes back to Evolution. I'm assuming this is because the dipswitches on the external PCB board obviously have the modchip still on. How do I turn it off so I can go to the main MS dash? I'm not really too keen on these sort of mods, and just want to play retail games on the thing (only cost 9 bucks, which is why I picked up the system). But I obviously don't want to accidentally reflash the thing or something, and kill the system. It's in nice physical condition, and the disc drive is as smooth as butter. I don't want to trash it by just flipping switches willy nilly. Right now the four dips are in the following order 1_____2_____3_____4 ON__OFF___ON___OFF Thanks for the help in advance. Hopefully someone still knows how these silly things work. Edited December 21, 2015 by MotoRacer Quote Link to comment Share on other sites More sharing options...
jhd Posted December 22, 2015 Share Posted December 22, 2015 I cannot answer your question, but how did you determine that the Xbox had been modded (before you purchased it)? Was there some external indication, or did you just get a $9 console, and was pleasantly surprised? I frequently see original Xbox consoles at thrift shops (albeit for rather more than $9), but I have idea how to tell if any have been modded. Quote Link to comment Share on other sites More sharing options...
Starscream Posted December 24, 2015 Share Posted December 24, 2015 (edited) So I bought an already modded Xbox from Goodwill recently. It boots up in Evolution dashboard just fine, and will play retail games just fine (and the burned copy of some college football game that came with it in the drive already). I'm looking to get some component cables for the system, so I can play my games I just bought in a higher resolution. But it seems I need to go to the MS Dashboard to change the resolution it's outputting. (No option to do so in Evolution) When I click on MS Dashboard, it cycles, but comes back to Evolution. I'm assuming this is because the dipswitches on the external PCB board obviously have the modchip still on. How do I turn it off so I can go to the main MS dash? I'm not really too keen on these sort of mods, and just want to play retail games on the thing (only cost 9 bucks, which is why I picked up the system). But I obviously don't want to accidentally reflash the thing or something, and kill the system. It's in nice physical condition, and the disc drive is as smooth as butter. I don't want to trash it by just flipping switches willy nilly. Right now the four dips are in the following order 1_____2_____3_____4 ON__OFF___ON___OFF Thanks for the help in advance. Hopefully someone still knows how these silly things work. I think 4 is to turn modchip on/off. BUT, if the hard drive isn't "locked" to the motherboard, then turning off the modchip will give you an error when you go to boot to original xbox dash. If there is a way to browse the hard drive(should be thru Evo dashboard) find the original xbox dash .exe and try to start it from there. With all that being said, I really see no point in you using the xbox without the mod chip on. On the Evo dash, you should be able to switch video output. You can still play retail games and the chances of you screwing up the mod are 0% if you don't go dicking around with files. Edited December 24, 2015 by Starscream Quote Link to comment Share on other sites More sharing options...
MotoRacer Posted December 24, 2015 Author Share Posted December 24, 2015 I think 4 is to turn modchip on/off. BUT, if the hard drive isn't "locked" to the motherboard, then turning off the modchip will give you an error when you go to boot to original xbox dash. If there is a way to browse the hard drive(should be thru Evo dashboard) find the original xbox dash .exe and try to start it from there. With all that being said, I really see no point in you using the xbox without the mod chip on. On the Evo dash, you should be able to switch video output. You can still play retail games and the chances of you screwing up the mod are 0% if you don't go dicking around with files. I can't figure out how to swap the resolution. I went through all the (very few) menus, nothing talks about resolution or output. Quote Link to comment Share on other sites More sharing options...
MotoRacer Posted December 24, 2015 Author Share Posted December 24, 2015 I think 4 is to turn modchip on/off. BUT, if the hard drive isn't "locked" to the motherboard, then turning off the modchip will give you an error when you go to boot to original xbox dash. If there is a way to browse the hard drive(should be thru Evo dashboard) find the original xbox dash .exe and try to start it from there. With all that being said, I really see no point in you using the xbox without the mod chip on. On the Evo dash, you should be able to switch video output. You can still play retail games and the chances of you screwing up the mod are 0% if you don't go dicking around with files. it had that little mini PCB sticking out the side of the system connected by wires. That's how I knew. That and when I powered it on, the power LED was modded to switch to red upon boot. 1 Quote Link to comment Share on other sites More sharing options...
Starscream Posted December 24, 2015 Share Posted December 24, 2015 You really can't hurt anything by tuning switches on or off. Basically, 3 of the switches are for bios and 4th is to turn off chip. The bios ones may boot to different dashes or maybe one is set with the original XB dash. Or maybe a large bios was made and uses 2 or 3 banks(switches). Anyways, switch away. Quote Link to comment Share on other sites More sharing options...
MotoRacer Posted December 27, 2015 Author Share Posted December 27, 2015 (edited) You really can't hurt anything by tuning switches on or off. Basically, 3 of the switches are for bios and 4th is to turn off chip. The bios ones may boot to different dashes or maybe one is set with the original XB dash. Or maybe a large bios was made and uses 2 or 3 banks(switches). Anyways, switch away. I tried turning the first on switch off, and then both off. Never booted to MS Dashboard when I clicked on it. Maybe I need to turn them off then turn the system on. Not sure if I'm doing this wrong. I'll have to keep poking at this. Edited December 27, 2015 by MotoRacer Quote Link to comment Share on other sites More sharing options...
xenomorpher Posted December 27, 2015 Share Posted December 27, 2015 If the hard drive is upgraded, there might be a chance that they never bothered putting the MS dashboard on it. I'm not sure if XBMC will allow you to boot up retail games in a better resolution or not. Most games are 480p, but where those component cables shine are with emulators. Quote Link to comment Share on other sites More sharing options...
Starscream Posted December 27, 2015 Share Posted December 27, 2015 I tried turning the first on switch off, and then both off. Never booted to MS Dashboard when I clicked on it. Maybe I need to turn them off then turn the system on. Not sure if I'm doing this wrong. I'll have to keep poking at this. You would need to turn switches off before turning system on. Like I said before, I am pretty sure switch 4 is to turn mod chip off. Let me know what ya find. Quote Link to comment Share on other sites More sharing options...
MotoRacer Posted December 27, 2015 Author Share Posted December 27, 2015 You would need to turn switches off before turning system on. Like I said before, I am pretty sure switch 4 is to turn mod chip off. Let me know what ya find. Right now, I'm waiting on some cables to get the system working on my new monitor. I'll test it again once I get that in and this is all re-hooked up . Thanks for the help, btw. Hope it works. Quote Link to comment Share on other sites More sharing options...
MotoRacer Posted December 30, 2015 Author Share Posted December 30, 2015 Fourth switch did it. Thanks! Quote Link to comment Share on other sites More sharing options...
