mariuszw Posted January 6, 2016 Share Posted January 6, 2016 Hi, Some people were asking for recompiler I created for preparing Pentagram, so I decided to release it. z80compiler.zip is a compiler. It takes Pentagram disassembly as input and creates 6502 listing ready to be compiled by MADS. Recompiler is very simple, it just takes every single Z80 instruction and just creates equivalent 6502 code from it. Recompiler performs basic code analysis and issues warning, where it thinks code needs to be reviewed and eventually changed. Following checks are done: - usage of A register. Since 6502 uses A to emulate A of Z80 but also uses A to emulate many other instructions, a situation where Z80 instruction reads A register but previous Z80 instruction doesn't write the instruction is detected, as previous 6502 instruction may pollute A - usage of ZERO flag: on Z80, ZERO flag is affected by very few instructions, while no 6502 almost all instructions affect ZERO flag. Warning is issued while Z80 instructions read ZERO flag but previous Z80 instruction does not write it - usage of CARRY flag: check similar to ZERO flag is done. Also, since for CARRY for subtraction and comparison are reverted between Z80 and 6502, but the same for addition, recompiler inverts CARRY checks (because CMP/SBC are more common than ADD) and issues a warning when not CMP/SBC affects CARRY Recompiler does not detect self-modifying code (2 instances in Pentagram). Recompiler also issues a warning for SP (Stack Pointer) manipulation, but cannot compile code which makes tricks with the stack directly (in Pentagram, sprite drawing codes reads directly using stack pointer). Recompiler is not mean to be generic, so not all instructions are compiled. Basically it is prepared to work with Pentagram source only, while it should be expanded quite easily to support other games. It needs Z80 disassembly with code, data and pointers clearly recognized and identified in order to work. The other tool is z80run.zip. It takes binary image of Z80 code and 6502 code, and executes them, logging all accesses (reads and writes) to memory, apart from: - opcode fetching - reading/writing data on zero page on 6502 (ZP registers are used to hold Z80 registers) - stack reading/writing on both Z80 and 6502 Then, all accesses are compared to find errors. This turned out to be very effective tool to debug 6502 code. z80run uses 6502 and Z80 emulators Copyright © Marat Fayzullin. Both projects are written in C++ and compiled in Microsoft Visual Studio 2012. Mariusz. z80run.zip z80compiler.zip 22 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 6, 2016 Share Posted January 6, 2016 Sounds like an amazing utility. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 7, 2016 Share Posted January 7, 2016 Yep, interesting. On my wish list is to get Galaga going for VBXE. Candidates would be the arcade original which would need this type of work, or the NES one which is already 6502 but would need rework for the different hardware in use. 3 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 7, 2016 Share Posted January 7, 2016 Yep, interesting. On my wish list is to get Galaga going for VBXE. Candidates would be the arcade original which would need this type of work, or the NES one which is already 6502 but would need rework for the different hardware in use. Shit - you would be my hero if that happened. Z80 code and original graphics courtesy of VBXE. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 7, 2016 Share Posted January 7, 2016 The thing is I don't think there's anything for Galaga arcade other than the Rom dumps and some driver documentation for Mame. It'd be going in blind to just make an attempt based on that. Quote Link to comment Share on other sites More sharing options...
NRV Posted January 7, 2016 Share Posted January 7, 2016 (offtopic) I have not checked the site in the last years, could be more updates.. (he was trying to implement the Galaga code in C). http://pushpopmov.blogspot.cl/2012/08/galaga-z80-disassembly-uploaded.html General info: http://galaga.info/ Some of the interesting links seems to be dead, like this one.. maybe in the wayback machine. http://www.computerarcheology.com/wiki/wiki/Arcade/Galaga oh.. but this works, nice (code with comments.. also check the info about the sound of Time Pilot ) http://www.computerarcheology.com/Arcade/Galaga/ more code info: http://donhodges.com/galaga_stage_256_fix.htm I did have a backup of some source.. z80.zip 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 7, 2016 Share Posted January 7, 2016 Cheers, some nice info in there about Galaga. I can remember reading some time back, probably elsewhere about the corrupted shot data structure which allows the wait/no enemy shooting trick to work (and actually played a game in it's fullness up to the Stage 0/256 bug/crash). 1 Quote Link to comment Share on other sites More sharing options...
+Philsan Posted January 8, 2016 Share Posted January 8, 2016 A ZX Spectrum adventure game (The Hobbit) would be easier to port for the recompiler? Quote Link to comment Share on other sites More sharing options...
mariuszw Posted January 8, 2016 Author Share Posted January 8, 2016 A ZX Spectrum adventure game (The Hobbit) would be easier to port for the recompiler? Hobbit exists for C64 and Plus4, so no need for recompiling Z80 version. I see a problem with preparing hires multicolor graphics, however. Mariusz. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 9, 2016 Share Posted January 9, 2016 For what it's worth, VBXE can be helpful there. I used blits to totally remap the graphics in Quadrillion. I initially rewrote the game to use Atari's linear mapping but some nasty bugs crept in, so I just resorted to leaving it as is and doing about 8K worth of memory moves per frame. Not that it's helpful for standard hardware. Though in narrow DMA you can emulate a C64 type bitmapping using multiple character sets. 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted February 2, 2016 Share Posted February 2, 2016 Uj thanks for Wratchchild in pointing me to this! Quote Link to comment Share on other sites More sharing options...
nitrofurano Posted December 26, 2017 Share Posted December 26, 2017 how ldir looks like from there? i’m really curious! Quote Link to comment Share on other sites More sharing options...
mariuszw Posted December 28, 2017 Author Share Posted December 28, 2017 how ldir looks like from there? i’m really curious! Nothing fancy ldir ldy #$00 ldx z80_b beq ldir_last_page ldir_loop lda (z80_hl),y sta (z80_de),y iny bne ldir_loop inc z80_h inc z80_d dex bne ldir_loop ldir_last_page lda z80_c beq ldir_end ldir_last_page_loop lda (z80_hl),y sta (z80_de),y iny cpy z80_c bne ldir_last_page_loop ldir_end stx z80_c stx z80_b tya clc adc z80_l sta z80_l bcc *+4 inc z80_h tya clc adc z80_e sta z80_e bcc *+4 inc z80_d rts 1 Quote Link to comment Share on other sites More sharing options...
shanti77 Posted January 19, 2018 Share Posted January 19, 2018 Have anyone compiled files (.exe) from this project? Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted January 19, 2018 Share Posted January 19, 2018 Yes, it was ok in VS 2017 Community edition to build the z80compiler. If anyone interested, I was looking at gb-disasm and able to take something such as the GameBoy R-Type rom and produce z80 code from that which can be compiled with some additions to the z80compiler to support extra instructions in the GB's processor. Quote Link to comment Share on other sites More sharing options...
nitrofurano Posted February 16, 2018 Share Posted February 16, 2018 (edited) i’m curious about trying it! (perhaps this tool will help me a lot doing for 6502 what i have made for z80, using Boriel’s ZX-Basic Compiler!) if anyone tried to compile it on GCC (GNU/Linux), please share makefiles! Edited February 16, 2018 by nitrofurano Quote Link to comment Share on other sites More sharing options...
nitrofurano Posted February 16, 2018 Share Posted February 16, 2018 Yes, it was ok in VS 2017 Community edition to build the z80compiler. If anyone interested, I was looking at gb-disasm and able to take something such as the GameBoy R-Type rom and produce z80 code from that which can be compiled with some additions to the z80compiler to support extra instructions in the GB's processor. see that GameBoy CPU is more based on 8080, not Z80! (the removed opcodes makes it retroincompatible with Z80, but not 8080) Quote Link to comment Share on other sites More sharing options...
nitrofurano Posted February 16, 2018 Share Posted February 16, 2018 i tried this now: guest@macbookair:~/Downloads/z80to6502/z80compiler$ gcc -o z80compiler z80compiler.cpp In file included from stdafx.h:8:0, from z80compiler.cpp:4: targetver.h:8:10: fatal error: SDKDDKVer.h: No such file or directory #include <SDKDDKVer.h> ^~~~~~~~~~~~~ compilation terminated. guest@macbookair:~/Downloads/z80to6502/z80compiler$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 17.10 Release: 17.10 Codename: artful guest@macbookair:~/Downloads/z80to6502/z80compiler$ i don’t know what might be missing there Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted February 16, 2018 Share Posted February 16, 2018 SDKDDKVer is from the Windows SDK libraries which you're not going to have from gcc. stdafx.h also indicates this is from a Visual Studio generated project and hence that's what should be used to build it. It shouldn't take much to port this code though, so take out the inclusion of stdafx.h and seem what breaks and patch from there. Quote Link to comment Share on other sites More sharing options...
nitrofurano Posted February 16, 2018 Share Posted February 16, 2018 guest@macbookair:~/Downloads/z80to6502/z80compiler/z80compiler_gccattempt02$ gcc -o z80compiler z80compiler.cpp In file included from z80compiler.cpp:5:0: z80compiler.h:3:10: fatal error: resource.h: No such file or directory #include "resource.h" ^~~~~~~~~~~~ compilation terminated. guest@macbookair:~/Downloads/z80to6502/z80compiler/z80compiler_gccattempt02$ Quote Link to comment Share on other sites More sharing options...
antrykot Posted February 16, 2018 Share Posted February 16, 2018 (edited) I doubt it is possible to compile this code with GCC as it isn't standard C++ and uses the MFC library for no good reason. Also it exhibits undefined behavior so it's not worthy of being compiled anyway, it will likely crash. But it should be possible with some effort to translate it into standard C++. Replace CString with std::string (or maybe std::wstring), CStringArray with std::vector, qsort with std::sort, and so on... Edited February 16, 2018 by antrykot Quote Link to comment Share on other sites More sharing options...
nitrofurano Posted February 16, 2018 Share Posted February 16, 2018 (edited) i guess that, from what i have seen around (projects at github and alike), with some code “cleanup”, it might be possible to have exactly (or almost exactly) the same code compilable, as from gcc, as from vs - but i’m saying this without having enough experience on this, my gcc experience isn’t better than compiling “hello world”, and on vs (which i never had installed at home, and perhaps never will, for lots of reasons ) is totally null... btw, perhaps is there some kind of code compatibility layer as library, that would help to smooth such situation? Edited February 16, 2018 by nitrofurano Quote Link to comment Share on other sites More sharing options...
nitrofurano Posted February 16, 2018 Share Posted February 16, 2018 But it should be possible with some effort to translate it into standard C++. Replace CString with std::string (or maybe std::wstring), CStringArray with std::vector, qsort with std::sort, and so on... i’m afraid that, for me, humbly saying, it seems far less difficult to convert the whole code to Python or Lua, than doing this! (anyway, thanks for the motivation!!!! ) Quote Link to comment Share on other sites More sharing options...
mariuszw Posted February 16, 2018 Author Share Posted February 16, 2018 Hi @nitrofurano, I'm glad you are interested in my work. My tool can be compiled with Microsoft Visual Studio only, as it uses MFC. It could be ported to plain C++ as antrykot suggested, but it certainly requires some work, and knowledge of both MFC and stc C++. Please keep in mind however, that with my tool you first need full Z80 program listing. Then, for translated program, additional work must be done to make the program work correctly (as compiler is not meant to produce working output). Then, the code is very suboptimal, so it requires lots of manual work and good 6502 experience to get good performance out of compiled program. I'd suggest using one of high level languages to port your work from Spectrum to Atari. You will find more details here: http://atariage.com/forums/topic/275385-what-modern-high-level-languages-are-available-for-the-8-bit-atari/. You may consider FastBasic, or Mad Pascal. Mariusz. 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted February 17, 2018 Share Posted February 17, 2018 (edited) I've managed to strip out the MFC dependencies from the c++ source such that only the z80compiler.cpp is required, note that this is some extension WIP to tackle the output of gb-disasm.I can build (g++ -std=c++11 z80compiler.cpp -o z80compiler) and run this against some z80 source both under cygwin64 on Win10 and an ubuntu 16.04 LTS VirtualBox VM. z80compiler_nonMFC.zip Edited February 17, 2018 by Wrathchild 4 Quote Link to comment Share on other sites More sharing options...
