interesting effect
w1k
Hi. Thanks, seems great but sadly I can't see them now.
Are they rotating?
Can you please change to black and white to have a better distinct dark to bright and like the original? Just because most of A8 darkest luminance, the 0, are too bright (two good colours for luminance 0 that 'fool eyes' as an almost black are colour 9 and 14).
:thumbsup:
Edited by José Pereira
Something like this?
A little turbo basic XL program, run attached ATR image.
It's not exactly the same, but IMHO close enough ;)
Altirra comes up with a corrupt error when trying to access/run that .atr file.
[Was using an Altirra 2.0 - changed up to 2.7 which runs it fine.}
Only looked at ver 2.0 --- I do think it looks good.
I wonder if it can be worked to include tessellations as such - to have it slowly changing into something else? Like Escher's fish into birds kind of thing. It won't be something easy to work on - but if you experiment with it, maybe it can lead to interesting animations and such like?
All kinds of interesting possibilities can open up or not?
Harvey
Edited by kiwilove
Yes, I found it. Data is 25600 bytes, and the TBB program is only appr. 1 kB at max.
@ dmsc
Simple, but interesting. It is possible to write the data table directly into memory as a binary file. You made a small TBB file, and you can write it from page 64. Then only change the 3 LMS indexes on the display list per frame.
@ dmsc
Don't tell me it's animation !? I would be disappointed ;)
I was on the way to make it with half Kb of animation data (for 8 angles) and rest done with code...
@ dmsc: You get a trophy for "first published" :)
I tried modifying for different modes but it's no good as it relies on inverse video.
Would be nice to see it in Gr. 2 albeit with the chunky pixels that come with it.. or bigger crosses in Gr. 0 but it might mean less angles due to character shortage.
Attached is a version with twice big crosses: disk.atr
Sadly, adding more angle steps uses more than 128 characters, so it is not possible with the current approach.
Awesome! Saved me a day ;)
Would you share details about how many chars,angles you used and such?
Last one has 64 frames, with 12 angle steps for the quarter turn.
@ dmsc
Yes, but then you need to keep track of the 4k boundaries, so the program would be more complicated. I opted for the simpler approach :)
Attached is also the C++ program used to generate the animations. At the start you can try modifying the definitions to try different animations, the program also writes images with the frames. Note the if the character count is more than 128, the output is invalid.
gen.zip
  • Like 4
Hi!,
NOT WORKING ON REAL HW
Sorry, but I tested in my Atari 800XL before posting, so I know that works on real hw.
These ATR's are actually XFD files with NO atr header. So use Atari800 Plus Win emulator and convert to ATR files.
That could be the problem, didn't know the header was needed. I use sio2linux, there it works ok.
Here are the 3 ATR with proper headers.
crosses.atr
crosses2.atr
cross-big.atr
Thanks for that!
Excellent code. Much can be learned from such a small program.
I think both versions look very effective.
Maybe have an option to change the colours or go into random colour mode?
[it does change colours - if you leave it running long enough - but it would be good to have this happening sooner or manually changeable].
Have variable speed animation,
if possible? Random maybe.
Harvey
Edited by kiwilove
