Which websites to use towards 7800 console repairs?
PhoenixMoonPatrol
Having a variety of annoying problems with the 7800 nowdays. Have a power switch thats almost dead. Have to press with all my might to get the machine to register on and off presses. Also having problems with some of the older 2600 games fitting snugly. Games like Centipede for example are a nightmare to insert and pull from the cartridge port.
Is there one site out there that specializes or atleast does good quality work towards Atari 7800 repair? Maybe even one that performs mods for you also?
Since if I'm going to ship it off I may as well get my moneys worth and have it modded abit. If you guys know a handful of going referred to sites I'd appreciate the info. I realize Google is my friend and I can do the research but at this point i wanna go by first hand experience from users within this forum.
Thanks.
Edited by PhoenixMoonPatrol
Contact cleaner on power switch. dont press it hard slide your finger from side to side on the power button works like a charm.
carts not fitting just wiggle them in they all fit. I never understand people that say they do not fit. wiggle and press hard they all work. If something snaps you fixed it.
Want composite modded? like no artifacting the rf gives and problems with sound levels on pokey games? I dont! So I leave it RF. Not many repair sites as they dont break down like intellivions colecos and 5200's.
Jinks: Well by mods I meant something like an RGB mod. I already have an AV mod and it looks good but its either the tv I'm using or the mod itself but I find it looking abit washed and a tad abit blurry. I have a Sega Saturn hooked up to the same tv via composite and it looks good so it must be the 7800 then. Guess I'll Google a site to see if they offer RGB.
Ok I'll give the contact cleaner a shot. I use to be able to power it on by hitting the corner of the switch but its gotten allot worse in the last week. Will apply the cleaner some later today,thanks.
Most my 2600 games fit ok but there are around two that dont play nice. Maybe theyre damaged but as far as I can see all looks normal. I'll go through more of the games tomorrow and see for sure how the rest handle. is Centipede known to have issues? Ripping that game out of the port is like trying to pick up Thor's hammer,its that bad. I try to wiggle and loosen the problem carts but Centiede is a no no.
LoTahan: I have one of those, use to use it on another 7800 and yeah its a nice step up.
The power button is working much better after using WD40. And sliding your finger over the power button from side to side while power it on seems to be a good trick. Little thins like this really make a big difference,wow. Thanks for the great advice. It feels good to be able to use the 7800 again.
Your not supposed to use WD40 as a contact cleaner. Get yourself some Electronic contact spray cleaner with lunbricant, and use compressed air afterwards. If you want to lube a switch (plastic) use WD40 on a q-tip.
Antony
I was under the impression there was only the 2600RGB, i never heard of a 7800 rgb mod yet?
K,I'll try to grab some tonight. But the WD40(for better or worse) did do the trick,very nicely too. But does it damage the switch in the long run? Well regardless I'll grab the contact cleaner tonight. Thanks for the warning.
Antony
I was just putting it out there was all,I haven't seen anyone with one either. Was sorta hoping someone here knew of a site that did RGB work on a 7800.
I'd love to go RGB since it makes a hell of a difference on my Yurkie enhanced Colecovision console :-o
I have a modded AV 7800 that I did. And you are correct in that at first, the audio is out of balance between the Pokey and TIA audio. But somewhere in this forum is a post where this was discussed and by changing where the audio connects to the motherboard, you get the Pokey audio back to where it should be. Mine sounds great with LHE mod board installed. Just not as impressed with the LHE s-video output off my 7800 as I am with the s-video off my 5200 or Sega systems.
Ahh I see. The WD40 does a nice job but didn't know it east at the console over time.
Still haven't found any contact cleaner yet. Sucks living in a small town sometimes.
WD40 attacks some plastics over time.
The coax adapter shown is still RF.
The switches are quite easy to replace with minimal soldering skills required. You can purchase replacement switches from Console5 at the link below:
http://console5.com/store/tactile-switch-12mm-x-4-5mm-atari-7800-power-pause-select-reset.html
Because you want to clean electrical contacts and keep them free of oily residue which attracts dirt and dust & sludge etc. WD40 is a great lubricant but is oily over time and creates a sludge. Electrical contact cleaner w lubricant, cleans contacts and free's up all the crap yet lightly lubricates parts as well. I use KRYLON Electrical contact cleaner with lubricant on all my stuff, automotive and gaming consoles and never has failed me yet. It has fixed many colecovison controllers i have with button issues on the spot as well as directional parts as well.
Hope this helps
Good luck, Anthony
Edited by tonyankyfan1
Goto WAL MART, pick up a can of CRC electrical contact cleaner, If you cant get the KRYLON. $4 bucks
