BizarreBootlegs Posted January 10, 2016 Share Posted January 10, 2016 (edited) Hey, AtariAge. I'm a new user who has always had a small collection of 2600 games, usually very common NTSC ones I just enjoyed playing. Recently I've gotten into more serious collecting and have a few Quelle games and this oddity. I purchased it from Spain for about 50 euros. It came cartridge-only, without a box or game list. What I find most interesting is that I cannot find an entry for it on Atarimania. I have seen a few 160 multicarts online but with different labels and no dip-switch on the front. Now, let's get to the physical description. It has one single dip-switch on the front, which can be switched 3 ways. I don't know if there's 3 ROMs in the cart, or what the significance of the switch is. I would open up the cart and find out but the label's in good condition and I'd hate to ruin it. What I find interesting is that the label dips down a bit in 5 little sections which means that the same shell was probably used for 32-in-1 carts with actual dip-switches. Also, it takes a little wiggling to get into my Atari. It might just be the console, or the circuitboard. To select the game, you select a mode with the dipswitch and turn the Atari on and off until you find a game you like. What's annoying is that since I don't have a list it's like blindly grabbing a 2600 game from a box of them. So far I've seen Spiderman, Alien's Return, and some interesting European games I haven't seen before. I've attached scans for future reference and to aid Rom Hunter in his quest for HQ scans, and also a size comparison with a standard NTSC Tennis cart. For anyone with experience with PAL carts: is it standard for the front label to be pointing towards the end-label, instead of the cartridge slot like NTSC games? The two Quelle games I own and this multicart have their labels like this. Also, how much would this be valued at? Also, if someone can aid me on how to dump the ROM I'd be very appreciative. Thanks, BizarreBootlegs https://www.youtube.com/channel/UCKZ_Gwx3k3OAJ7tMNR05dQQ Edited January 10, 2016 by BizarreBootlegs Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 10, 2016 Author Share Posted January 10, 2016 I've sit down and played it for about 30 minutes. It's nearly impossible to find the same game twice which is making it very hard to review; also, one single ROM repeats itself many times in all 3 dip-switches. I'd imagine there are actually 160 games there, but very poorly organized and not easily found. Another ridiculous thing is when the dip-switch is at the far-right position, you will eventually find a ROM of the menu screen used in the 208-in-1 Super 2600 multicart, and when you select a game it restarts, it literally does nothing. Also, when hooked to the color TV I can't adjust the V-Hold in, it actually shows more unique games than the B&W portable TV I use so I can adjust the V-hold. Don't know if that's coincidence or some magic stuff. I am editing the review for my YouTube channel, however the gameplay footage is over 40 minutes long and is about 5 gigs large. It will take a little while to render. Quote Link to comment Share on other sites More sharing options...
atari181 Posted January 10, 2016 Share Posted January 10, 2016 http://atariboxed.com/index.php?go=detail&modul_refnumber=2161 1 Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 10, 2016 Author Share Posted January 10, 2016 http://atariboxed.com/index.php?go=detail&modul_refnumber=2161 Thanks, atari181. Now I just have to figure out how to get something I can dump the ROM on. Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted January 10, 2016 Share Posted January 10, 2016 Added: http://www.atarimania.com/game-atari-2600-vcs-160-games_28483.html Thanks! Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted January 10, 2016 Share Posted January 10, 2016 It's nearly impossible to find the same game twice which is making it very hard to review; also, one single ROM repeats itself many times in all 3 dip-switches. I'd imagine there are actually 160 games there, but very poorly organized and not easily found. Perhaps this list helps: BTW: the original version of UFI und Sein Gefährlicher Einsatz is definitely Go Go Home from Dimax, not Alien's Return. Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted January 10, 2016 Share Posted January 10, 2016 Another ridiculous thing is when the dip-switch is at the far-right position, you will eventually find a ROM of the menu screen used in the 208-in-1 Super 2600 multicart, and when you select a game it restarts, it literally does nothing. There are a few different versions of the menu rom. Does yours play the same music as 208 multicart? Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 10, 2016 Author Share Posted January 10, 2016 Perhaps this list helps: Taiwan009.jpg BTW: the original version of UFI und Sein Gefährlicher Einsatz is definitely Go Go Home from Dimax, not Alien's Return. Thanks, Rom Hunter. I also found out an odd hack of River Raid published by "Galaga" on there in which the bridge was just a bunch of gray blocks. It played normally, though. Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 10, 2016 Author Share Posted January 10, 2016 (edited) There are a few different versions of the menu rom. Does yours play the same music as 208 multicart? It took a little bit of resetting to get to it, but yeah, the tune matches with your 208 multicart. Here, I put it in a video: https://youtu.be/TPGIBrHMNcU Perhaps this list helps: Taiwan009.jpg BTW: the original version of UFI und Sein Gefährlicher Einsatz is definitely Go Go Home from Dimax, not Alien's Return. By the way, I am making a three-part series of reviewing every game on there, they're short reviews, maybe 30 seconds. So far it took about an hour to play all the games in the first dipswitch, which included some interesting hacks, maybe 1 or 2 bad ROMs and such. It's gonna take an insane time to render though. Also, I will try to get a game list to you, but I'm gonna need some help since I've got rather limited experience with European/hacked games. Edited January 10, 2016 by BizarreBootlegs Quote Link to comment Share on other sites More sharing options...
Rom Hunter Posted January 10, 2016 Share Posted January 10, 2016 (edited) Thanks, Rom Hunter. I also found out an odd hack of River Raid published by "Galaga" on there in which the bridge was just a bunch of gray blocks. It played normally, though. Yes, it's found on many multi-game V-carts. Edited January 10, 2016 by Rom Hunter Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 10, 2016 Author Share Posted January 10, 2016 Yes, it's found on many multi-game V-carts. I do remember seeing a few of those games on there, like Pac Kong and "Teeth Brush" I mistakenly referred to Teeth Brush as Tooth Protectors while playing the game which I'll have to correct in editing. Still trying to beat the first level of Bi! Bi! Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted January 10, 2016 Share Posted January 10, 2016 Yours is a different version. I believe it matches the one the Spirantho had (the dots instead of numbers). I have a photo on one of my computers somewhere that he took. It hasn't ever been dumped. The other version I recall is the menu screen from Sku_u on the console the unknown DataAge? Game was found on. Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 10, 2016 Author Share Posted January 10, 2016 Yours is a different version. I believe it matches the one the Spirantho had (the dots instead of numbers). I have a photo on one of my computers somewhere that he took. It hasn't ever been dumped. The other version I recall is the menu screen from Sku_u on the console the unknown DataAge? Game was found on. Ah, okay. Sounded similar. Now I really need to find out how to dump it Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 11, 2016 Author Share Posted January 11, 2016 The seller who sold me this is also selling a bunch of other cartridges, including Fantastic Game and more VCase bootlegs. A total cost of the ones I want to buy is 125 euros, or $136.49. Would immediately buy them but don't have the money right now The seller ships pretty quickly and cheaply (15 euros) considering it's from Spain, the one I have came in like 1 and a half weeks. 1. A Fantastic Game cart with 6 dip-switches (possibly 64 games?) 2. A "128 in One" V-Case 3. and what appears to be two copies of "128 in 1 Game" V Case Quote Link to comment Share on other sites More sharing options...
iwan-iwanowitsch-goratschin Posted January 11, 2016 Share Posted January 11, 2016 Added: http://www.atarimania.com/game-atari-2600-vcs-160-games_28483.html Thanks! You are welcome as always! Quote Link to comment Share on other sites More sharing options...
Schitti Posted January 11, 2016 Share Posted January 11, 2016 (edited) Hi BizarreBootlegs, many thanks for the better scan from the 160in1 cart. http://www.atariboxed.com/index.php?go=detail&modul_refnumber=2161 i hope you have found the "fantastic game" title and the other "vcase bootlegs" in our database? We currently have many Fantastic Game titles in the database, therefore it is difficult to say anything about it. Not all carts with "Fantastic Game" labels were sold within a "Fantastic Game Box". you can find them also in Italy in Marpes Boxes and Taiwan Boxes. If you need some help to identify the other carts, do not hesitate to ask. Edited January 11, 2016 by Schitti Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 12, 2016 Author Share Posted January 12, 2016 The first part out of 4 reviewing the far left dip-switch is out: https://www.youtube.com/watch?v=oyR4xhE_HN0 Quote Link to comment Share on other sites More sharing options...
atari181 Posted January 12, 2016 Share Posted January 12, 2016 I have a boxed copy of this 1 Quote Link to comment Share on other sites More sharing options...
BizarreBootlegs Posted January 12, 2016 Author Share Posted January 12, 2016 I have a boxed copy of this Strange, I don't remember seeing 3D Tic Tac Toe. Quote Link to comment Share on other sites More sharing options...
