phoenixdownita Posted April 17, 2016 Share Posted April 17, 2016 MAYday, MAYday. MAY I have your attention please!?!?! Anyone can play along but he shall put some effort, to my disMAY I noticed the results are ... MAY we say ... lacking .... try harder and MAYbe it will come out much better!!! Here: http://www.wordfind.com/contains/may/ You MAY continue now. 1 Quote Link to comment Share on other sites More sharing options...
Guitari Posted April 17, 2016 Share Posted April 17, 2016 This point is well and truely MAYd. 1 Quote Link to comment Share on other sites More sharing options...
Atlantis Posted April 17, 2016 Share Posted April 17, 2016 MAY is better than AUGUSTGood to see there is a complete production chain with guys making this happen! Thanks, all of you involved. Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted April 17, 2016 Share Posted April 17, 2016 For my own education indulge my questions a little, I heard that you are making a run of 100 with possibly a second run, so 200 carts. When Jag homebrews are done what are usually the numbers involved? Is 200 a big number or a small one? I understand that demand may be different depending on projects but you guys may have already an expectation/idea of what kind of user base is willing to back you up .... just interested in understanding the homebrew scene a little better ... needless to say the smaller that paying base the higher the cost for projects like these due to a fixed component + lack of scale to obtain better deals. I understand all that, I promise I won't try to speculate on what you're making out of it, it is not my intention or interest, just trying to gauge if we're talking a "band of brothers" kind of a scene or more like brick and mortar store attendance. Quote Link to comment Share on other sites More sharing options...
omf Posted April 17, 2016 Share Posted April 17, 2016 MAY is better than AUGUST Good to see there is a complete production chain with guys making this happen! Thanks, all of you involved. it would depends if these damn boards continue to give me issues problem: new boards new save chips eproms programmed and verified about 20 times each solder them in the board = red after a short pause after the jaguar logo de soldered the chips to check again, verified another 20 times each. both chips check out 2 Quote Link to comment Share on other sites More sharing options...
omf Posted April 17, 2016 Share Posted April 17, 2016 it would depends if these damn boards continue to give me issues problem: new boards new save chips eproms programmed and verified about 20 times each solder them in the board = red after a short pause after the jaguar logo de soldered the chips to check again, verified another 20 times each. both chips check out i think it may be to do with eprom speed, im not sure getting 50ns chips was a brilliant idea :/ Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted April 17, 2016 Share Posted April 17, 2016 i think it may be to do with eprom speed, im not sure getting 50ns chips was a brilliant idea :/ The only issue would be if the setup time is so fast that you end up with a bus contention .... what's the default MASKrom speed for the existing games? Or if some other Jag component would rely on the delay to still access the bus while the cart responds .... possible. Quote Link to comment Share on other sites More sharing options...
rayik Posted April 17, 2016 Share Posted April 17, 2016 i think it may be to do with eprom speed, im not sure getting 50ns chips was a brilliant idea :/Which ones do you have? These have worked fine for me: M27C160-100F1 and M27C160-50F1. The latest I bought is this ebay listing: http://www.ebay.com/itm/281664211000?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT I have a socketed board just for testing eproms before soldering onto another board. As to all your boards failing, that's weird. I found about 5% of the boards I got ended up being bad. I just verify all boards by socketing them first. Are you checking by putting bare board into jag? If so, I found that a lot of bare boards that red screened worked ok when in a cart shell. Lastly, is the jag still good? @@@@@@ EDIT Just noticed your using new save eeproms. Do you have an original eeprom to try with. I found bad eeproms could cause board not to work. I once got a batch of bad 93c86s which were sold as new. Quote Link to comment Share on other sites More sharing options...
omf Posted April 17, 2016 Share Posted April 17, 2016 Which ones do you have? These have worked fine for me: M27C160-100F1 and M27C160-50F1. The latest I bought is this ebay listing: http://www.ebay.com/itm/281664211000?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT I have a socketed board just for testing eproms before soldering onto another board. As to all your boards failing, that's weird. I found about 5% of the boards I got ended up being bad. I just verify all boards by socketing them first. Are you checking by putting bare board into jag? If so, I found that a lot of bare boards that red screened worked ok when in a cart shell. Lastly, is the jag still good? i have m27c160-50F1 here, but i know the jag doesnt really care what speed it is, but i was wondering if 50 was a little bit fast especially if one chip is a little slow the jag is fine as it does play other stuff i even multi metered out the cartridge edge and the pin on the chips, all appears to be fine Quote Link to comment Share on other sites More sharing options...
rayik Posted April 17, 2016 Share Posted April 17, 2016 i have m27c160-50F1 here, but i know the jag doesnt really care what speed it is, but i was wondering if 50 was a little bit fast especially if one chip is a little slow the jag is fine as it does play other stuff i even multi metered out the cartridge edge and the pin on the chips, all appears to be fine I've used 27c160-50F1 with no problem. I'll post a picture of one later when I'm home I'd look at the eeproms. Can you read and write to one it your programmer? What happens if put a stock 93c46 on the board? Quote Link to comment Share on other sites More sharing options...
rayik Posted April 17, 2016 Share Posted April 17, 2016 OMF -never mind. Your chips are probably good. Red screen after jag logo is a security verifiction failure. Since all chips pass write verification, thst's probably the problem. Nothing to do with the chips or burn. PM sent Quote Link to comment Share on other sites More sharing options...
+LS650 Posted April 17, 2016 Share Posted April 17, 2016 (edited) Phoenixdownita - a typical homebrew run these days might run anywhere from 50 to 200 copies, with 100 copies typically being made. There's not much profit to be made: it's strictly an effort by a handful of Jag fans who do it for love of the hobby. The average effort is usually a couple of guys working off a table in the garage or den. Edited April 17, 2016 by ls650 4 Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted April 17, 2016 Share Posted April 17, 2016 Phoenixdownita - a typical homebrew run these days might run anywhere from 50 to 200 copies, with 100 copies typically being made. There's not much profit to be made: it's strictly an effort by a handful of Jag fans who do it for love of the hobby. The average effort is usually a couple of guys working off a table in the garage or den. Is the number dictated by practicality or because after 100/200 units the 2 guys could go bonkers? (I can see that happening) I ask because over at smspower.org a few years ago I was able to buy a gender-adapter for a Jap SMS, turns out the guy was sitting on the first batch of connectors made some 3Y earlier. I am not sure how many he made but I found it interesting that after 3Y they were still available .... either the interest was misjudged or it was the minimum batch anyway. Anyway thanks for confirming the ballpark numbers. @omf all the best in finding the culprit of all your woes, solder-desolder gets very old very quickly. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted April 17, 2016 Author Share Posted April 17, 2016 Is the number dictated by practicality or because after 100/200 units the 2 guys could go bonkers? (I can see that happening) I ask because over at smspower.org a few years ago I was able to buy a gender-adapter for a Jap SMS, turns out the guy was sitting on the first batch of connectors made some 3Y earlier. I am not sure how many he made but I found it interesting that after 3Y they were still available .... either the interest was misjudged or it was the minimum batch anyway. Anyway thanks for confirming the ballpark numbers. @omf all the best in finding the culprit of all your woes, solder-desolder gets very old very quickly. The contract with The Bitmap Brothers is for a set number of units, which I will not disclose, not only because then people will start blabbing it all over ebay listings 6 months down the line to inflate their resale value, but because I can't. 5 Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted April 17, 2016 Share Posted April 17, 2016 The contract with The Bitmap Brothers is for a set number of units, which I will not disclose, not only because then people will start blabbing it all over ebay listings 6 months down the line to inflate their resale value, but because I can't. OK, I didn't see that coming, hopefully the number is generous enough wrt the community and it won't be a problem right away. ....hidden meaning .... there's chance for more than one run .... but as you said you are not at liberty to disclose to avoid scalping ... I really hope the final price would be right also for ass-cheap subjects like me Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted April 17, 2016 Share Posted April 17, 2016 = red after a short pause after the jaguar logo @CJ: Is this a MEMCON setting issue? Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted April 17, 2016 Author Share Posted April 17, 2016 @CJ: Is this a MEMCON setting issue? Not if all the other carts work Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted April 18, 2016 Share Posted April 18, 2016 The contract with The Bitmap Brothers is for a set number of units, which I will not disclose, not only because then people will start blabbing it all over ebay listings 6 months down the line to inflate their resale value, but because I can't. Well hopefully there will be enough to go around 1 Quote Link to comment Share on other sites More sharing options...
Gaztee Posted April 29, 2016 Share Posted April 29, 2016 The game will be available to play for anybody going to play expo Blackpool tomorrow (30th) I will be in the RCM area. 5 Quote Link to comment Share on other sites More sharing options...
omf Posted April 29, 2016 Share Posted April 29, 2016 (edited) The version i made for gaz has an issue with the hiscore saving but will be good enough for the have a go format of play expoI have currently manufactured 112 boards, i have a box thatthey are being put in that can hold probably another 25, i will continue to make boards until gaz comes down for a visit on the 10th of next month to collect themAll boards have been tested and work although some users may get some red screen issues due to flux splashes on the cart connector, not much i can do about that apart from brasso each board which im not going to do. As i say each board has been tested to get to the title screen. These boards use a legit cart header so if it boots it wont crash later on.See attached picture for amount doneAfter this box is full i am calling the first batch done as i need a rest after this. Edited April 29, 2016 by omf 12 Quote Link to comment Share on other sites More sharing options...
Rick Dangerous Posted April 30, 2016 Share Posted April 30, 2016 I am so incredibly stoked for this release. I can't wait to play Xenon 2 on my Jag! Quote Link to comment Share on other sites More sharing options...
Gaztee Posted April 30, 2016 Share Posted April 30, 2016 8 Quote Link to comment Share on other sites More sharing options...
Sapicco Posted April 30, 2016 Share Posted April 30, 2016 My jaguar has been lonely. It also looks forward to this release and getting more play! 1 Quote Link to comment Share on other sites More sharing options...
rayik Posted May 1, 2016 Share Posted May 1, 2016 All boards have been tested and work although some users may get some red screen issues due to flux splashes on the cart connector,Just curious, why are you fluxing the boards. I've make a lot using just flux core solder with no problem with a fine chisel tip about 1/3 the diameter of the stock hakko fx988d tip. Not saying you should do that. Just curious why you are applying flux. Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted May 1, 2016 Share Posted May 1, 2016 IMG_20160428_120851.jpg Do we have a price that can be announced? [i presume the gaz that will handle the sale is you, here, if not please apologies] All boards have been tested and work although .... Care to share what was the issue you faced a couple of weeks ago with the EPROM speed? Just as a way to share a lesson learnt if any. Quote Link to comment Share on other sites More sharing options...
