Hellraiser Posted January 20, 2016 Share Posted January 20, 2016 Hi, I know there is a arduino TAP player ,tapuino, for the C64, I was wondering if it could be possible to build a arduino CAS player for the A8? Found this but it doesnt really show a lot or give any information about it. Anybody have any idea about this? Quote Link to comment Share on other sites More sharing options...
dakidski Posted January 20, 2016 Share Posted January 20, 2016 Not sure. Try asking this guy: http://arduitapemarkii.blogspot.dk/ Quote Link to comment Share on other sites More sharing options...
popmilo Posted January 20, 2016 Share Posted January 20, 2016 I know there is a arduino TAP player ,tapuino, for the C64, I was wondering if it could be possible to build a arduino CAS player for the A8?Looks like simple hardware design and software for c64 version is opensource on github, should be easy to convert for atari... Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 21, 2016 Share Posted January 21, 2016 Since Atari uses the same interface and really the only extra for doing disk is the /Command line, it takes away from the need to do a tape emulator. I'm not sure if any existing standalone types do cassettes. The thing is when you have something like an SIO2SD that can do turbo disk loads at probably 100 times standard tape speeds, you ask yourself why you'd want to bother. Quote Link to comment Share on other sites More sharing options...
mr-atari Posted January 22, 2016 Share Posted January 22, 2016 Yeah, I build an SIO2Arduino myself and implemented some code to support .CAS files in c++ Then compiled and shot the new code in my little PCB. Works as a charm. :-) The extra code must be in multiple tabs of the SDRIVE-source. I can zip and upload my code, but the pin-layout is not the same as a stock Arduino-setup..... Also my c++ knowledge is very limited (hey, I'm an Atari-guy), so my patching of the code may be worth a laugh or two.... I also added 2 jumpers to select 600 or 850 baud playback (for standard OS) or 4800 baud with/without ultra short gaps for MyBIOS. So yes, it can be done. 3 Quote Link to comment Share on other sites More sharing options...
