Binarygeek Posted January 21, 2016 Share Posted January 21, 2016 Hi all In desperation, I turn to the forum... I have a couple of Atari ROMS zipped into a single file on my PC that I need converted to an .ATR file. They are just a couple of Atari ROMS that I need to get on an Atari floppy that I can't seem to figure out yet how to do. I can get them on a floppy from the ATR file using APE/Pro Systems. I have used the APE program extensively, but only to convert from ATR to floppy, not from floppy to an ATR file (designed custom OS last year, and took the MAC/65 output and used APE to print out source code and to take 16K ROM file and burn it to the USB chip burner...took chip and re-inserted it into Atari. I don't think I ever needed an ATR file). If anybody could please convert the attached file (ATRme.rar) to an ATR file I would be most grateful. Hopefully I'll be able to figure it out soon, but until then I could really use some help. Thanks all, folks. Rick ATRme.rar Quote Link to comment Share on other sites More sharing options...
fujidude Posted January 21, 2016 Share Posted January 21, 2016 Hi all In desperation, I turn to the forum... I have a couple of Atari ROMS zipped into a single file on my PC that I need converted to an .ATR file. They are just a couple of Atari ROMS that I need to get on an Atari floppy that I can't seem to figure out yet how to do. I can get them on a floppy from the ATR file using APE/Pro Systems. I have used the APE program extensively, but only to convert from ATR to floppy, not from floppy to an ATR file (designed custom OS last year, and took the MAC/65 output and used APE to print out source code and to take 16K ROM file and burn it to the USB chip burner...took chip and re-inserted it into Atari. I don't think I ever needed an ATR file). If anybody could please convert the attached file (ATRme.rar) to an ATR file I would be most grateful. Hopefully I'll be able to figure it out soon, but until then I could really use some help. Thanks all, folks. Rick Here you are: result.atr Quote Link to comment Share on other sites More sharing options...
Binarygeek Posted January 23, 2016 Author Share Posted January 23, 2016 Thanks fujidude So what would a request for some firmware have to do with a 26 hour or so troubleshooting binge on the MegaSpeedy? Well, simply that the MegaSpeedy would not work when placed in the 1050 Duplicator mode...it would simply time out and die (in retrospect, I thought the MegaSpeedy designers had a sense of humor about the 1050 Duplicator). All other aspects worked as described. I feared that my MegaSpeedy might be defective. Finally, I noticed that after the ridiculous step-motor start up sequence of the Duplicator, that the read-write head landed OUTSIDE the track zero sensor, never allowing the track zero to register and the start-up sequence to fail. By adjusting the track zero (something I did not have to adjust after running and passing the 1050 Disk Diagnostics, something I did not have to do before I modified the drive, or I did not have to do with ANY other 1050 MegaSpeedy ROM), did the MegaSpeedy finally work Jeez, what a waste of time. Rick Quote Link to comment Share on other sites More sharing options...
tjlazer Posted January 23, 2016 Share Posted January 23, 2016 (edited) Get ATR Util 1.13! You can edit and make ATRs really easily, works on Win 7, not sure on newer versions. Should work http://ftp.pigwa.net/stuff/collections/holmes%20cd/Holmes%202/PC%20Atari%20Utils/ATR%20Util%2095%201.13/index.html http://atari.kensclassics.org/a8emulators.html Edited January 23, 2016 by tjlazer Quote Link to comment Share on other sites More sharing options...
vitoco Posted January 25, 2016 Share Posted January 25, 2016 Get ATR Util 1.13! You can edit and make ATRs really easily, works on Win 7, not sure on newer versions. Should work I've always had some issues with that tool, mainly with the paths of the Win directories as source or destination folders, sometimes it works, sometimes it complains with an error message... I'm not sure if it depends on the Windows version or language. There is another tool called MakeATR, but it lacks the ATASCII/ASCII conversion, useful to transfer plain text files with EOL (char 155/$9B) to the PC and viceversa. Quote Link to comment Share on other sites More sharing options...
1050 Posted January 25, 2016 Share Posted January 25, 2016 It actually has to do with spaces or other 'illegal' characters in the file name of the ATR. When I can send it a filename without spaces, it loads it fine. With spaces and I have to go thru the open file dialog box which it then opens with no problems. Wants to use the last folder a successful launch was done in too, if I find a decent solution I'll post something about it. Quote Link to comment Share on other sites More sharing options...
