SpartaDOS X APT Driver for the Corvus Hard Disk Controller
flashjazzcat
Since Phaeron added Corvus emulation to Altirra, and considering the excitement which sometimes surrounds these rare vintage HDD controllers, here's an XL/XE Corvus APT driver for SpartaDOS X:
corvus_apt_driver_v.0.1.zip
This works exactly like the SIDE, MYIDE and Colleen drivers which are already in wide use. Fire up Altirra, add a Corvus via System->Devices..., boot SDX, run CORVUS.SYS and then run the APT partition editor (FDISK) in the usual fashion. Be sure to select XL/XE compatibility (ports 1+2). Volume size is very limited at the moment since only a 6MB HDD is emulated, but it's fun nonetheless.
Note: this driver uses the APT partition format, so if you happen to prep a disk (real or emulated), all your old Corvus partitions will be gone.
Not sure where this is going, if anywhere, but the next task is to tighten up the driver and make transfers a bit faster (it's very slow at the moment since modularity has resulted in a lot of subroutine calls for every byte transferred). Error checking is non-existent and I have absolutely no idea how this will fare on real hardware. The firmware tracks should be safe since the driver only does block transfers in the user area of the drive.
FDISK works transparently with the Corvus with the exception that the Firmware description string spills out of the APT device properties dialog, so I'll fix that eventually. All the APT tools I've tested work with it (APTDISK, APTDEV, etc), and you can explore the disk at the physical or logical level with KMK's excellent EDDY editor. You can even leave your Ultimate/SIDE HDD active and run it alongside the Corvus. Both devices show up in the partition editor.
Speaking of Ultimate: if you're using the new BIOS, disable joystick input in the setup menu otherwise the Corvus will move the highlight cursor for you. ;)
The driver will eventually sense if it's working on an 800 and configure itself for PORTB, and avail itself of the extra joystick ports Incognito provides in XL/XE mode. Right now, it's XL/XE only.
  • Like 6
I'm glad I was able to provide a little help. I was planning on providing more help, but I'm not a speed-coder. I was still puzzling over that pdf when you discovered that error status byte thing.
I'm just happy that we now have a driver.
Really, I think this enhances SDX nicely. We can use the newest hardware, and now, some of the oldest.
  • 1 year later...
Ah right... got you. I'll have to dig into it since there's no "detection" code at all: it just assumes the interface is present. I notice several of the status routines (adapted from the Corvus bumph we were originally working from) just loop ad infinitum waiting for bits to change, so a few timers on those should facilitate a way to get out if there's no response.
  • Like 4
  • 11 months later...
  • 2 months later...
if I can recall, the interface just polls the drive and after a set time limit, in true "corvus network" fashon it would say something like "network offline" - I think you can see it flash for a moment in one of those videos I posted. Before I figured out how to write the firmware to a drive to fix it after a low level format I would see that message all the time. Thanks to everyone who made it possible for me to enjoy a fantastic piece of computing history, and to all you guys keeping it alive for the foreseeable future. And thank you FJC!
