RSS Bot Posted January 30, 2016 Share Posted January 30, 2016 Last time around I added jitter emulation to Stella, which became part of the official build with version 4.6.5. The jitter emulation basically moves the screen up/down in response to inconsistent scanline counts, similar to that which occurs on a real TV. I added it because people without an Atari would often write games with variable scanline counts, but not realize it until others play-tested the game on real hardware.One thing it didn't emulate was a recovery time - if the difference in scanline counts is large a real TV will take multiple frames to recover. Instead, the original implementation would recover in just a single frame - blink and you might miss it.TIA.hxxAdded a variable for recovery time: TIA.cxxAdded a constant for the threshold for triggering recovery time. I went with 5, but it can easily be changed. void TIA::initialize(){... myNextFrameJitter = myCurrentFrameJitter = myJitterRecovery = 0;...} Update the jitter logic to use the new variable and constant: common/Version.hxx:Jitter ROM:Jitter Source: If this looks good to y'all I'll submit the changes to stephena. Attached thumbnail(s) Attached File(s) Stella Jitter Improvement.app.zip (3.48MB)Number of downloads: 0 TIA source.zip (22.87KB)Number of downloads: 0 Jitter.zip (19.91KB)Number of downloads: 0 jitter.bin (2KB)Number of downloads: 0 http://atariage.com/forums/blog/148/entry-12666-jitter-3-recovery-time/ Link to comment Share on other sites More sharing options...
