ascrnet Posted January 4, 2018 Share Posted January 4, 2018 Hi, someone knows how to make it work in ubuntu. since it executes the commands of the page, it is installed but how do I execute it correctly? abel@DellTux:~/.local/bin$ sudo pip install numpy The directory '/home/abel/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag. The directory '/home/abel/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag. Requirement already satisfied: numpy in /home/abel/.local/lib/python2.7/site-packages abel@DellTux:~/.local/bin$ sudo pip install omnivore The directory '/home/abel/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag. The directory '/home/abel/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag. Requirement already satisfied: omnivore in /home/abel/.local/lib/python2.7/site-packages Requirement already satisfied: pyparsing in /home/abel/.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: atrcopy>=3.1.0 in /home/abel/.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: pycrypto in /home/abel/.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: numpy in /home/abel/.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: configobj in /home/abel/.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: jsonpickle in /home/abel/.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: bson<1.0.0 in /home/abel/.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: future in /home/abel/.local/lib/python2.7/site-packages (from atrcopy>=3.1.0->omnivore) Requirement already satisfied: six in /home/abel/.local/lib/python2.7/site-packages (from configobj->omnivore) Requirement already satisfied: pytz>=2010b in /home/abel/.local/lib/python2.7/site-packages (from bson<1.0.0->omnivore) regards Quote Link to comment Share on other sites More sharing options...
playermissile Posted January 4, 2018 Author Share Posted January 4, 2018 I think I've fixed it. Try: pip install omnivore and it should install version 0.15.1. Quote Link to comment Share on other sites More sharing options...
ascrnet Posted January 4, 2018 Share Posted January 4, 2018 Hi playermissile, ok, uninstall it and reinstall it, but it gives error : sudo pip uninstall omnivore sudo pip install omnivore The directory '/home/abel/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag. The directory '/home/abel/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag. Collecting omnivore Downloading Omnivore-0.15.1.tar.gz (3.5MB) 100% |████████████████████████████████| 3.5MB 245kB/s Requirement already satisfied: numpy in /usr/local/lib/python2.7/dist-packages (from omnivore) Requirement already satisfied: atrcopy>=6 in ./.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: pyatasm>=1.3 in /usr/local/lib/python2.7/dist-packages (from omnivore) Requirement already satisfied: jsonpickle>=0.9.4 in ./.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: bson<1.0.0 in ./.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: configobj in ./.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: pyparsing in ./.local/lib/python2.7/site-packages (from omnivore) Requirement already satisfied: wxpython in /usr/lib/python2.7/dist-packages/wx-3.0-gtk2 (from omnivore) Requirement already satisfied: future in ./.local/lib/python2.7/site-packages (from atrcopy>=6->omnivore) Requirement already satisfied: pytz>=2010b in ./.local/lib/python2.7/site-packages (from bson<1.0.0->omnivore) Requirement already satisfied: six>=1.9.0 in ./.local/lib/python2.7/site-packages (from bson<1.0.0->omnivore) Installing collected packages: omnivore Running setup.py install for omnivore ... done Successfully installed omnivore-0.15.1 abel@DellTux:~$ omnivore Traceback (most recent call last): File "/usr/local/bin/omnivore", line 76, in <module> main(sys.argv) File "/usr/local/bin/omnivore", line 53, in main from omnivore8bit.plugin import OmnivoreEditorPlugin File "/usr/local/lib/python2.7/dist-packages/omnivore8bit/plugin.py", line 7, in <module> from omnivore.framework.plugin import FrameworkPlugin File "/usr/local/lib/python2.7/dist-packages/omnivore/framework/plugin.py", line 6, in <module> from envisage.ui.tasks.api import TaskFactory File "/usr/local/lib/python2.7/dist-packages/envisage/ui/tasks/api.py", line 2, in <module> from .preferences_pane import PreferencesPane File "/usr/local/lib/python2.7/dist-packages/envisage/ui/tasks/preferences_pane.py", line 4, in <module> from traitsui.api import Controller File "/usr/local/lib/python2.7/dist-packages/traitsui/api.py", line 36, in <module> from .editors.api import ArrayEditor File "/usr/local/lib/python2.7/dist-packages/traitsui/editors/__init__.py", line 23, in <module> from .api import ArrayEditor File "/usr/local/lib/python2.7/dist-packages/traitsui/editors/api.py", line 24, in <module> from .code_editor import CodeEditor File "/usr/local/lib/python2.7/dist-packages/traitsui/editors/code_editor.py", line 37, in <module> class ToolkitEditorFactory(EditorFactory): File "/usr/local/lib/python2.7/dist-packages/traitsui/editors/code_editor.py", line 49, in ToolkitEditorFactory mark_color = Color(0xECE9D8) File "/usr/local/lib/python2.7/dist-packages/traits/traits.py", line 522, in __call__ return self.maker_function( *args, **metadata ) File "/usr/local/lib/python2.7/dist-packages/traits/traits.py", line 1236, in Color return ColorTrait( *args, **metadata ) File "/usr/local/lib/python2.7/dist-packages/traitsui/toolkit_traits.py", line 8, in ColorTrait return toolkit().color_trait(*args, **traits) File "/usr/local/lib/python2.7/dist-packages/traitsui/toolkit.py", line 169, in toolkit _toolkit = _import_toolkit(toolkit_name) File "/usr/local/lib/python2.7/dist-packages/traitsui/toolkit.py", line 83, in _import_toolkit return __import__(name, globals=globals(), level=1).toolkit File "/usr/local/lib/python2.7/dist-packages/traitsui/wx/__init__.py", line 26, in <module> import toolkit File "/usr/local/lib/python2.7/dist-packages/traitsui/wx/toolkit.py", line 55, in <module> from pyface.wx.drag_and_drop \ File "/usr/local/lib/python2.7/dist-packages/pyface/wx/drag_and_drop.py", line 94, in <module> PythonObject = wx.DataFormat('PythonObject') File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_misc.py", line 4840, in __init__ _misc_.DataFormat_swiginit(self,_misc_.new_DataFormat(*args, **kwargs)) TypeError: in method 'new_DataFormat', expected argument 1 of type 'wxDataFormatId' abel@DellTux:~$ regards Quote Link to comment Share on other sites More sharing options...
playermissile Posted January 4, 2018 Author Share Posted January 4, 2018 It seems to be using the system wxPython which is an older version. From the command line, can you try pip install "wxpython>=4.0b2" and run it again? Hopefully that will download the latest version of wxPython and put it in the python library directory. Quote Link to comment Share on other sites More sharing options...
ascrnet Posted January 4, 2018 Share Posted January 4, 2018 Hi playermissile, thank you very much for the help and improve the installation, I only want to say that for the compilation of the wxpython library you will need development libraries including libgstreamer, libwebkit and libgtk-3-dev. sudo -H pip install omnivore Collecting omnivore Requirement already satisfied (use --upgrade to upgrade): pyparsing in /usr/local/lib/python2.7/dist-packages (from omnivore) Requirement already satisfied (use --upgrade to upgrade): numpy in /usr/local/lib/python2.7/dist-packages (from omnivore) Requirement already satisfied (use --upgrade to upgrade): pyatasm>=1.3 in /usr/local/lib/python2.7/dist-packages (from omnivore) Requirement already satisfied (use --upgrade to upgrade): jsonpickle>=0.9.4 in /usr/local/lib/python2.7/dist-packages (from omnivore) Collecting wxpython (from omnivore) Using cached wxPython-4.0.0b2.tar.gz Requirement already satisfied (use --upgrade to upgrade): configobj in /usr/local/lib/python2.7/dist-packages (from omnivore) Requirement already satisfied (use --upgrade to upgrade): atrcopy>=6 in /usr/local/lib/python2.7/dist-packages (from omnivore) Requirement already satisfied (use --upgrade to upgrade): bson<1.0.0 in /usr/local/lib/python2.7/dist-packages (from omnivore) Requirement already satisfied (use --upgrade to upgrade): six in /usr/local/lib/python2.7/dist-packages (from wxpython->omnivore) Requirement already satisfied (use --upgrade to upgrade): future in /usr/local/lib/python2.7/dist-packages (from atrcopy>=6->omnivore) Requirement already satisfied (use --upgrade to upgrade): pytz>=2010b in /usr/local/lib/python2.7/dist-packages (from bson<1.0.0->omnivore) Building wheels for collected packages: wxpython Running setup.py bdist_wheel for wxpython ... done Stored in directory: /root/.cache/pip/wheels/45/56/c8/5edcc423a6c3458c2c32fcf649b55b05c17f9f6dcb52d5bd7b Successfully built wxpython Installing collected packages: wxpython, omnivore Successfully installed omnivore-0.15.1 wxpython-4.0.0b2 You are using pip version 8.1.1, however version 9.0.1 is available. You should consider upgrading via the 'pip install --upgrade pip' command. abel@DellTux:~$ omnivore regards Quote Link to comment Share on other sites More sharing options...
playermissile Posted January 4, 2018 Author Share Posted January 4, 2018 Yes, sorry about the README being out of date. I will update it to include all the library dependencies. Glad you got it working! 1 Quote Link to comment Share on other sites More sharing options...
mechanerd Posted January 7, 2018 Share Posted January 7, 2018 Great utility.!!Been looking for something like this in the past few months.Just hacked out a Star Raiders trainer mod.Shields take all hits, no damage. Energy drain greatly reduced. Full speed engines takes same amount as speed 2. Title screen edited directly with text window was handy. Discovered "M" key to select alternate target. Never knew about that feature. 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted July 10, 2023 Share Posted July 10, 2023 Is there an equates file that matches the disassembly output? -Thom Quote Link to comment Share on other sites More sharing options...
greggj Posted August 4, 2023 Share Posted August 4, 2023 any plans to update it? I tried compiling it on macOS Today - and libatari800 fails. I did open GitHub issue - but we all know how these work 1 Quote Link to comment Share on other sites More sharing options...
