Shift838 Posted February 3, 2016 Share Posted February 3, 2016 I'm looking for a Geneve HD Image file for use with MAME/MESS that is loaded up with the latest MDOS, tons of utilities, games, cartridges and of course the 9640 boot menu. Anyone have one they can share? Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted February 3, 2016 Share Posted February 3, 2016 In the Geneve folder on whtech, there is the mdos_gpl_util.hd, and in the 9640news folder on whtech, there is the all.hd. I never got them running, there was a thread on here about that... Where Gazoo was helping someone get his image running. http://atariage.com/forums/topic/222783-9640-news-on-one-hard-disk-image/page-1?do=findComment&comment=2941192 http://ftp.whtech.com/Geneve/9640news/all.hd http://atariage.com/forums/topic/219686-geneve-support/?do=findComment&comment=2885278 http://ftp.whtech.com/Geneve/mdos_gpl_util.hd <-- If I remember right, when I dug around in here, there were games and such... and a menu... it was just too much for me to start with... -M@ Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 3, 2016 Author Share Posted February 3, 2016 I tried the all.hd and it starts to boot but just hangs. It s hows it's 95mb. That's bigger than the HFDC can handle i think. I opened the image file in TIImageTool and was able to look at it, and it looks like it has all the 9640news disk catalogs in there. The mdos_gpl_util.hd works with no issues. it has MDos 6.71 on it too. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted February 3, 2016 Share Posted February 3, 2016 Yes. The all.hd was created by me as a collection of all 9640news disks; you cannot boot from it. But you can copy folders to your boot disk, or you mount this drive as the second one. To create a new bootable HD, you can use TIImageTool. Just create a harddisk image by "File->New->Harddisk image"; you can use the defaults, which will create a ST225 disk with 20 MiB capacity, or the maximum one with 1984 cylinders, 16 heads, 32 sectors, 256 bytes per sector (248 MiB). Then go to "Utility->Install GeneveOS". Make sure you set the correct hard disk type for MESS. For a ST225 you can use "st225"; for non-ST types just use "generic". This looks like this: mess geneve -skip_gameinfo -peb:slot8 hfdc -peb:slot8:hfdc:h1 generic -hard1 myharddisk.chd Available hard disk types are "st213", "st225", "st251", and "generic". The difference (at this time) is that the ST types have a fixed geometry which must be matching between the image file and the type, while generic is a hard disk that can magically create enouch cylinders and heads to accomodate for any kind of image file. Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted February 3, 2016 Share Posted February 3, 2016 Hi, I have converted and unpacked all available .HD-files last year, for direct access from PC. If needed, pls let me know, I can upload them to toxic server or anywhere unsupported ones: Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 3, 2016 Author Share Posted February 3, 2016 Yes. The all.hd was created by me as a collection of all 9640news disks; you cannot boot from it. But you can copy folders to your boot disk, or you mount this drive as the second one. To create a new bootable HD, you can use TIImageTool. Just create a harddisk image by "File->New->Harddisk image"; you can use the defaults, which will create a ST225 disk with 20 MiB capacity, or the maximum one with 1984 cylinders, 16 heads, 32 sectors, 256 bytes per sector (248 MiB). Then go to "Utility->Install GeneveOS". Make sure you set the correct hard disk type for MESS. For a ST225 you can use "st225"; for non-ST types just use "generic". This looks like this: mess geneve -skip_gameinfo -peb:slot8 hfdc -peb:slot8:hfdc:h1 generic -hard1 myharddisk.chd Available hard disk types are "st213", "st225", "st251", and "generic". The difference (at this time) is that the ST types have a fixed geometry which must be matching between the image file and the type, while generic is a hard disk that can magically create enouch cylinders and heads to accomodate for any kind of image file. What version of MDOS does TIIMageTool install ? Quote Link to comment Share on other sites More sharing options...
+mizapf Posted February 3, 2016 Share Posted February 3, 2016 It's called "6.50 Redistributable". Quote Link to comment Share on other sites More sharing options...
