Power Supply snap-crackle-pop...
morelenmir
If anybody is interested, I will soon have available 30 XL/XE power supplies. They are 5V, 2A and use a Neutrik 7-pin DIN with cast aluminum housing and gold pins. $15 each, $5 will ship one or two in the USA (so $20 for 1 shipped, $35 for 2 shipped).
I'll potentially be in for two
I would never cheap out on power supplies, especially avoid cheap iPhone / iPad counterfeit chargers.
There's a reason why these are so cheap, much less components.
They are house fires waiting to happen.
http://www.righto.com/2014/05/a-look-inside-ipad-chargers-pricey.html?m=1
I would second that!
The chap who does the EEVBlog once dismantled what turned out to be a fake Apple USB charger... Scary just to think about plugging that thing in. Its a very interesting video and well worth checking out.
I wouldn't recommend a USB charger, but the 5V switching mode power supplies that come with many routers are designed for constant use at higher current.
I have a few 5V/2A power supplies that came with D-Link routers which should be suitable for this type of application, since they don't use any USB handshaking to be able to deliver >500mA.
I'm guilty of using cheap knock off chargers myself.I've replaced a MacBook charger with a cheap one, eventually the charger failed catastrophically. Being curious I broke opened up the case and one of the electrolytic caps had a decent sized hole in it. Scary to think that I used that thing for a year and half.
Apart from being dangerous to use, the manufacturers remove necessary components from the design to bring down costs which result in under-performance (they often don't deliver the necessary performance as claimed in their specs & suffer a lot of problems ( AC ripple, overheating causing components to exceed their max ratings & eventually fail )).
