Sega Genesis to Atari 7800 controller adapter for sale
grips03
  • 2 weeks later...
Guys, get in on these NOW. I am telling you that they are so worth it. Using a Genesis controller with both buttons functional is an incredible experience on the 7800. Night and day from the original pro controllers or even the Euro controller. I purchased a second one because I can't play the 7800 without them now!
  • 3 weeks later...
  • 1 month later...
  • 2 months later...
Greetings Grips,
Do any of you all know if these adapters will work the the Colecovision as well? I understand that the keypad would not work, but do these adaptors allow for 2 buttons on a Colecovision? A game like Cosmic Avenger, Nova Blast use 2 buttons that need to be pressed at the same time to produce fire and bombs at the same time.
A game like Ninja Princess needs both buttons pressed at the same time to perform a 3rd action in this game its Ninja Magic.
I am looking for a good solution to play Genesis controllers on my Coleco.
Any insight you can give me would be great!
Thank you very much.
Greetings Grips,
These adapters are only for Genesis controller ---> Atari 7800. Won't do anything for Colecovision.
Edited by grips03
I have an odd question. Would this adapter work for use with a Commodore computer? As far as I recall it is not recommended to use a Genesis controller directly with a Commodore (say a C64 for example) because it can burn out the port for one reason or another...although I cannot remember the exact issue. For that reason I never connect Genesis pads to it. I just wonder if this adapter would make a Genesis controller "safe" to use...
Actually, here's more on that issue:
http://atariage.com/forums/topic/256707-sega-genesis-controller/?hl=%2Bgenesis&do=findComment&comment=3609399
Revenge adapter does not do anything to help Genesis to Commodore, it only helps Genesis to 7800.
You want something like the picture below, from page 47 here:
https://www.scribd.com/document/8945979/Commodore-World-Issue-05
Does Commodore output +5V VCC signal on pin 7? If not, there won't be a power supply for the adapter to translate the signals.
  • 1 month later...
Interested in 2 x 12 inches each if you make a batch 5 please.
Thanks!
I'm no longer making them, however if you want to make a couple for yourself, here is the PCB and parts list:
https://www.oshpark.com/shared_projects/tzB557NP
Please don't make to sell on eBay, etc. This is for non-commercial use only.
for those who want to make their own Revenge adapter:
A simple Schematic and pinout diagram will do, preferably in PNG format as I lack the software to decipher this. I can fabricate my own breadboards with supplies (through hole please) from my local radioshack...
BTW, thanks for sharing your stuff. :thumbsup:
only the PCB design was mine, the circuit design is from:
http://www94.pair.com/jsoper/7800_gen_adap.html
this where you will find the schematic
It appears all his solutions used logic chips. EDIT: Nevermind, they're just quad PNP transistors. Prolly easier to just use discrete components for the BCE.
  • 9 months later...
